Have older computer - Gateway E-4400. This am, instead of a happy boot, get three beeps at the boot and black screen. is it dead?
    Sergeant:
  • 349 Answers
Maybe but try this first:
If the PC posts
(power on self test) and you see stuff on the screen, no matter how short , do the following: (this checks for a software problem)
· when booting up press F8 and when you get to the menu, boot up into safe mode,
· then restore the pc back to a date before you had the problem, and/or remove any program you installed prior to you having the problem,
if that don't work Try
· a boot-able anti virus disc use it to check for any viruses , if not
· try a recovery disc, or operating system disc ,
· both disc's will try to access the hard drive. if they do not work,
· (nothing has changed) nothing comes on the screen.
if PC does not post:
(then it is a hardware problem)
· Remove any hardware you may have installed prior to you having the problem.
· remove the ram and clean the gold edges both sides, with rubbing alcohol or a pencil eraser,
· and re-insert them, (not an ink eraser as it will do damage)
· swap them around if you have more than one, try one at a time.
· if you only have one, borrow one from a friend or try the ram in your friends laptop ,if that's possible,
· or take the ram to your local pc shop and ask them to check it for you (they may do that for you)
· if you can establish that the ram is ok, and recovery /system disc's do not work, then it is most likely, that the motherboard has failed .
· Generally a dead hard drive would not stop the PC from posting.
good luck with that and let me know how you get on.
Terry
Posted on Apr 02, 2008
SOURCE:
Dell error code 4400:011B
..have you used the System Restore to go back a few weeks or months? This will clear up everything. There has to be a restore point somewhere in the c: drive
Mar 21, 2014 | Dell Dimension Computers & Internet
Gateway GM5442 PC Desktop Won't Boot!
3 BEEPS -RAM
Guest Posts: n/a 01-24-2005 We had a power failure in the office this weekend. All the systems are back
up and running fine, except for the receptionists. It's a Gateway
Professional Series. P4 1.3 Ghz. It is giving me three beeps. No boot up
screen and no video source (monitor light stays yellow instead of turning
green). I looked up the beep code and it says three beeps means the ram
needs reseated. Which I have done several times. Also, I have just put in
one stick in difference seats. I have also reseated all the cards at least
three times. I have switched the jumper to try to boot into setup mode.
Nothing there either. Popped out the cmos battery and put it back in. No
good either.
Has all the ram been fried? The fan on the cpu is still spinning. The cd-rom
ejects. I can't hear the hard drive spinning. I guess I can swap the hard
drive for a different one.
Anything I'm missing? YEP
http://support.gateway.com/s/MOTHERBD/INTEL/m00262/beepcode.shtml
Apr 06, 2012 | Gateway GM5442 PC Desktop
Computer will turn on but will not boot up
Dear,
Did this situation come with any beep sound. Because, most of the time, in this situation; the computer beeps. Here are some codes. Check if any of these condition apply to your system.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Gateway 510XL (2800446) PC Desktop
Intel D815EEA: Won't Boot / Blank Screen / Three Beeps
3 short beeps means Base 64K RAM failure.
try to replace the RAM.
Jun 24, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
When booting up after the logo the computer goes to black screen. There are no beeps at start up. When starting in safemode it stays with black screen with the safe mode written in the corners
In safe mode try pressing ctrl+alt+del, then go to task manager-->applications-->New task, then type: explorer.exe Now your desktop should appear. you could also try running: msconfig In the same way, and see wether explorer.exe is still in the startup. Adding it again will permanently solve your problem. I hope this helps, Yannick.
Jun 13, 2009 | Dell Dimension 4400 PC Desktop
Motherboard beeps three times, computer won't boot up
Your computer is experiencing memory problems. Turn power off, remove and reseat the memory chips, and try it again. If not successful, try different memory chips. Also could be power supply problem
Jun 13, 2009 | Gateway 506GR PC Desktop
NO POWER
If you have changed the power unit and the computer is still not powering up, then it is quite likely there is a motherboard fault - probably in the power management circuitry, which expects the power_good signal from the power unit at a precise moment in the boot up process. A fault in the power management circuitry would prevent the computer from beginning its boot-up process.
Do the fans in the power unit come on when the computer is switched on? If they don't - this suggests a power unit problem. If the power unit fans do start working but the computer still doesn't boot, this suggests either a faulty or 'dry' connection (easy checked) or a motherboard fault.
If your computer 'works' but nothing is displayed, try pressing Control+Alt+Delete. If it then boots up it suggests a power unit problem. If not .. we come back to the motherboard again.
A low wattage power unit can cause the problem you describe. Every 128 Mb of Ram needs 4 watts of power. Add more for the motherboard (up to 30 watts..) then the floppy/hard drive/dvd etc .. If the power unit can't supply the necessary wattage, it won't boot. The older 250-300 watt power units aren't suitable for modern computers with XP/Vista. Ideally, you should be looking at 400 watts plus -it will tell you on the power unit.
Though to be honest, it does sound like a motherboard fault.
The only other thing that can cause a computer not to boot up (though it will begin the boot up process) are other faults ... When you switch on does it actually display anything on the screen .. and are there any 'beeps'? 1 beep indicates everything is ok .. 3 short beeps and 1 long beep indicate a memory problem (and the computer won't boot..). 8 beeps indicate a video problem (and nothing will be dislayed on your screen). Same with 9 beeps .. which indicates a bios fault - and the computer won't continue the boot process.
If you have nothing .. no power whatsover ... it comes back to the power unit/mainboard. If you're happy that the new power unit you have put in is ok ... suspect the motherboard. If you have access to any unwanted or 2nd hand motherboard ... connect that. If your computer boots up ... its the original motherboard at fault.
Alternatively, rather than replace bits and pieces at random to cure the fault, take your computer along to a computer shop. It will take them minutes to test it for you and identify the fault.
May 17, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway 2" monitor won't display
blown capacitors this can be fixed I can help or advise you how to do it but it will require soldering internal components.
Mar 04, 2009 | Gateway FPD2275W LCD Monitor
Gateway E-4200, Pentium III, Win XP, Nothing Showing On Monitor
The beeps are usually an error code meaning either the RAM or video card has went bad or are not properly seated. Leaving it out as you did could have caused the parts to come unseated when you moved the unit. Try reseating the RAM & video card and then retry booting. Hope this helps & please remember to rate my answer. Thanks.
Jan 10, 2009 | Gateway E-4200 Notebook
Open Questions:
Computers & Internet Logo
53 people viewed this question
Ekse
Alun Cox
