Question about Epson Stylus Photo 1290 InkJet Printer
Ink Levels not showing
Alhough i have genuine Epson cartridges installed, there's no ink levels showing. Anyone come across this before?
  • 2 more comments
  • elzwood Apr 03, 2008
    Windows XP 2002 Service pack 2.
    thanks.
  • elzwood Apr 06, 2008
    Levels now showing, thanks for helping out.
  • Lynnk Apr 16, 2008
    I have the same problem with Epson 1290 printer, but using Vista. Unfortunately the ink ran out, but after I replaced a cartridge the red light went out, but it still won't print. I think they're not communicating that the ink has been replaced!
    I've found that I have to install the printer driver via Vista to have it work OK, but this problem remains. Any help appreciated, since I can't afford another printer!
  • Anonymous May 13, 2008
    NI INK LEVELS SHOWING
    Genius:
  • 1,447 Answers
What operating system are you using? are you getting an error light on the printer?
Posted on Apr 02, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 05, 2008
    trash and reinstall the printer driver and dl driver from epson site. if the status monitor will not show still update me.
    After reinstalling the printer and status monitor doesnt show still, uninstall driver from add and remove program one more time and follow this steps
    Now we need to remove specific references to the product in the registry.
    1. Click on START, then RUN.
    2. In the RUN window, type in REGEDIT and press OK.
    3. In the upper menu bar click on FILE, then EXPORT.
    4. In the window that comes up, SAVE IN should be set to DESKTOP.
    5. In the FILE NAME section at the bottom of the window type in REGBACKUP.
    6. EXPORT RANGE should have a dot next to ALL.
    7. Click on SAVE.
    8. Look at the column on the left.
    9. Click on the “+” sign next to HKEY_CURRENT_USER
    10. Click on the “+” sign next to SOFTWARE
    11. Click on the “+” sign next to Epson
    12. Click on the “+” sign next to PRINTER
    13. If you see a reference to your printer's model, right click and delete it.
    14. Click on the “-“ signs next to PRINTER, EPSON, SOFTWARE, HKEY_CURRENT_USER to close up this branch.
    15. Click on the “+” sign next to HKEY_LOCAL_MACHINE
    16. Click on the “+” sign next to SOFTWARE
    17. Click on the “+” sign next to EPSON
    18. Look for a folder with the name of your printer model. Right click on it and Delete it (if you don’t see it, then don’t worry about it).
    19. Scroll down and look for a folder named PRINTER and click on the “+” sign to the left of it.
    20. Look for a reference to your printer model. Right Click on it and delete it.
    21. Click on the “-“ signs next to EPSON, SOFTWARE, HKEY_LOCAL_MACHINE to close up this branch.
    22. Close the registry editor.
    then reinstall the driver that you downloaded from the web.
    if issue persist pls update me
    dont forget to rate solution. thanks!!
SOURCE:
How to read ink levels in an epson nx110
All Epson printers (well, the ink ones) have a small utility built-in called the STATUS MONITOR. If you click on the MAINTENANCE tabbed page in the Properties, you can start this just by clicking on the item. It will show the ink levels. Normally, this status monitor should start up whenever you print - with an option to show the ink levels, as they do not auto appear when printing, compared to the option shown above. Note that the monitor does NOT actually shown the real ink levels as the chips on the cartridges and the internal electronics within the printer simply work on the number of prints made - so often when showing empty - there will in fact be ink left unused inside the cartridges. For this reason alone, worth your while getting some refillable cartridges and bulk ink (normally in 100ml bottles - so you would get equivalent about 10+ refills and save lots of hard earned dosh!) but you would also need an inexpensive chip resetter. My advice is get the refillables with ink (most compatible inks are as good as - some better - than Epson's own expensive original cartridge inks) and when one cartridge shows requires replacing, you remove all the cartridges, fill them all, reset the chips and replace - that way you show all as full and on ly have one cleaning cycle - thus also saving lots of ink normally wasted when replacing one cartridge - each requiring a cleaning cycle and loss of other inks. I have no idea where in the World you live so cannot recommend a supplier - just use ebay.com or amazon.com to find suitable suppliers convenient to yourself.
May 29, 2014 | Epson Stylus Multifunction Inkjet Printer/...
Deskjet F2100 Cannot get estimated ink cartridge levels to show remaining ink levels. Following instructions from HP solution centre but function does not appear to work. Genuine Hp cartridges hp21 &...
Hello, make sure the golden contacts from your cartridges are clean. If you say your cartridges are Genuine (OEM) and not for use check the valability date on the cartridge (just above the golden contacts). If your cartridges are clean (I am referring to the contacts), OEM (made by HP) and still in the valability range you can take them to the reseller you both them and ask for a refunt or a replace.
Jul 09, 2011 | HP PSC 1610 All-In-One InkJet Printer
I have just changed all the ink's in an Epson d120
If you replaced with "genuine" ink-cartridges, then it should report "full".
If you replaced with "refilled" ink-cartridges, then the company that refilled forgot to "reset" the electronics inside the ink-cartridge, in order to report "full".
Or, perhaps, the software "toolbox" that came with the printer has a button "I have installed new cartridges, please re-verify the ink-levels" ??? Click that button.
Nov 27, 2009 | Epson Stylus D120 Network Edition ultra...
My printer has a new ink cartridge but does not recognize the ink
What model printer do you have and can you list the print cartridge?
Also have you selected on the onboard printer menu that you have inserted a new cartridge?
Jul 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Ink levels ok on control panel but will not print
DID YOU REMOVE THE TAPE FROM THE ELECTRONIC CONTACTS?
May 27, 2009 | Epson Stylus CX5200 All-In-One InkJet...
Can't see ink levels
Re0install the driver on your pc in the control panel. when it lists all the printers, chosse the one named (M) driver. This installs a different driver, which includes a button to Get ink levels...
Oct 28, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Ink
See my answer to your similar question:
t is possible that the ink cartridges in your printer (especially applicable if you are using refilled or compatible carts) can not be read by the printer. Some compatible cartridges have a failure rate as high as 30% and so it is very possible that the machine either does not see the cartridges or can not read them.
Replace the cartridges with genuine Epson ones and try again. The genuine ink will also help to clear any hardening cheap ink in the print head.
Apr 02, 2008 | Epson Stylus C43SX InkJet Printer
Epson c43sx current ink levels not shown in the properties
Epson Stylus Photo 1290 InkJet Printer Logo
2,554 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
