Question about Brother SX-4000 Typewriter
Replacing correction ribbon on Model SX4000 Broether typewrwiter
I am all thumbs. Have been trying for nearly 2 hours to get the thing in. Half the time the supply reel drops down inside the machine and gets twisted. This thing has frustrated me to the point where I'm ready to trash the whole thing !!!
  • 2 more comments
  • yomomma3 May 14, 2008
    HELP
  • Anonymous May 14, 2008
    can't install correction ribbon on brother GX6750
  • Anonymous Jun 13, 2008
    The black part of the inside typewriter where the correction tape is will not stay down in the typewriter causing it to not type
  • Anonymous Aug 07, 2008
    Can install correction ribbon, but it does not seem to work.
    Scholar:
  • 183 Answers
Check answer to "custumers500" for answer to this problem.
Posted on Oct 28, 2008
SOURCE:
IBM Wheelwriter 2, the bottom half of the letters are not printing. It is not the ribbon because I have changed it out.
Two things come to mind for this problem. First try pushing down firmly on both ends of the black rubber platen roller. Sometimes the black plastic latch on either side may break causing one side of the roller to lift up causing partial print. The other possibility is the ribbon is not lifting correctly. A technician can adjust the ribbon lift. After typing a few letters, take the ribbon out and look at the letters on the ribbon.Are they in the middle of the ribbon or are they at the top or bottom of the ribbon? middle of ribbon is correct.
Mar 01, 2016 | IBM Lexmark Personal Wheelwriter 2...
INSTALLING CORRECTION TAPE ON A BROTHER SX4000 TYPEWRITER
try to see it in the sides or it might be in the bottom of the machine in some models remove the older and replace the newer.
Aug 25, 2008 | Brother SX-4000 Typewriter
How to replace the daisy wheel
Remove the ribbon and L/O tape, pull the black lever by the P/W towards you, lift out P/W.
DickyO
Oct 28, 2014 | Brother Sx4000 Portable Electronic...
I bought an sx4000 typewriter on line and there was no manual. I wish to activate the 16 character display so I could track my typing....help
To toggle the Line by Line mode, press Alt + Operate (written above the key, on the key is Reloc and BS 1/2). There are three options that you can rotate through Off, Auto, and L/L. (Auto only displays the text for correcting for specific things - like a line that will be centered between the margins.)
Brother has the manual for this at their site: http://www.brother-usa.com/manuals/default.aspx?PGID=10&R3ModelID=SX4000 . The direct link to the manual is http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_SX4000_EN_219.PDF .
I hope this helps.
Jul 01, 2011 | Brother Office Equipment & Supplies
TYPE WRITER DISPLAYS BUT WONT TYPE ANYTHING
There are many "WONT TYPE ANYTHING" symptoms and reasons, like:
is the ribbon installed? Is it installed correctly? Is the carriage moving?
Some description of your concern would be of great help.
I guess you don't have the User Manual.
Here you'll find the PDF version of the manual.
Good luck.
May 11, 2011 | Brother SX-4000 Typewriter
The correction tape is not working properly. Wheelwriter 1000
If everything was working befor the ribbon & L/O change Either the L/o is not properly attached to the ribbon or the ribbon and or L/O are old. Make some corrections then remove and look at the L/o, if the letters are near the center of the L/O the problem is the ribbon or L/o is old, if the print is on the top of the tape it is not properly attached to the ribbon or not coming out or the cassette properly.
If you have a fresh set or another T/W that works swap the ribbons and look at how they are attached.
For a picture ngo to lexmark.com and click your way to publications you will find a downloadable manual there.
DickyO
Jan 23, 2010 | Lexmark Wheelwriter 1000 Typewriter
Datacard sp25 ID card Printer printer about half of the picture is this a printer problem or a ribbon cartridge problem?
you need consider:
1) it should be no gap between roller--ribbon--card and base when it printing need enough pressure on the card. if not enough pressure it could be printing bad.
2) the ribbon move under the roller might be not normal, to check or adjust it
3) the ribbon near the end, need to change
hope it help you
May 12, 2009 | Datacard SP25 Printer
1) Use the [SPACE BAR] or [BACKSPACE] to move the carrier to the center of the platen.
2) Open the top cover
3) Remove the cassette ribbon, if installed
4)Pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen, and lift it up and out.
5)Pass the new tape through the left guide, behind the ribbon guide, and out through the right guide. The rough (sticky) side of the tape should face the platen.
6) Attach the feeder spool to the pin on the left
7) Attach the take-up spool to the pin on the right
8) Turn the take-up spool counter-clockwise until a small amount of white tape has wound around it.
9) Replace the cassette ribbon and close the top cover.
10) Press [CODE] + [RESET] to move the carrier to the previous position.
Mar 19, 2009 | Brother SX-4000 Typewriter
Royal Portable typewriter ribbon
Hi, I have a Royal Companion Portable from 1940's. I bought new ribbons at mytypewriter.com (select the "Royal Portable" ribbon). It fits. Anyway if it doesn't it's not an expensive mistake, but I researched this and apparently all vintage Royal Portables have the same standard ribbon. Worked out in my case. Good luck!
Apr 09, 2008 | Office Equipment & Supplies
I have a brother SX4000 at work and I am having a hard time getting the correction tape on. Can you help with any instructions?
Jan 29, 2008 | Brother SX-4000 Typewriter
Brother SX-4000 Typewriter Logo
93 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
