Question about Bissell Vacuums
I have a Bissell 3760-2 and while vacuuming it just shut off. The vacuum was plugged in and was on. Thought it might have quit because of the filters, so I cleaned them out and still does not work. Please help I'm totally clueless about this thing. Thanks Tony
    Master:
  • Bissell Master
  • 894 Answers
Hello, this is Ava with Think Crucial.
Most Bissell vacuums have Thermal Motor Protection which is a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting. When the motor cools for approximately 30 minutes, the thermal protector automatically resets and cleaning may continue. If the cleaner will not turn on or the thermal protector continues to activate, your cleaner may need servicing.note: The thermal protector controls the main vacuum motor only, not the brush motor. If the thermal protector activates, the brush will continue to operate normally; however, there will be no suction.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Posted on Oct 02, 2017
  • 17 Answers
SOURCE: bissell cleanview vacuum poor suction
The next thing that you need to do is replace the belt. Even if it's not cracked or worn, many times it's too loose, and it won't turn to rotor efficiently.
Believe it or not, just replacing the belt may be all that you need to do!
Posted on Jul 07, 2009
  • 97 Answers
SOURCE: We have a Bissell Revolution Lift-Off Turbo 3760-1
these belts need to be changed every 6 months regardless of the way they look.
Posted on Jul 20, 2009
Vac Belts
  • 701 Answers
SOURCE: Bissell Pet Hair Erase does not vacuum.
It is because the belt is worn or stretched and needs to be replaced. Here are the belts you need and the manual which has instructions:
Bissell Pet Hair Eraser Belts and Manual
Posted on Dec 30, 2009
  • 5370 Answers
SOURCE: I have a bissell vacuum
The filter if its dirty in gives bad smell.Also if it gets worn out or very old it gives bad smell.Many other users too have noticed this bad smell.Replacing the filter helped many other users too. The worst part being smell of the filter once it goes bad it stays bad and fills the room with a nasty rotten smell. ----------- Also you try cleaning the filters.As you mentioned in your question that you have already tried this but try to clean the filter as per the instructions mentioned in the service manual.And see if that reduces the bad smell. The manual specifically states not to use a mild cleaning agent while washing the filters, you may wash the filters in cold or warm water using a scented mild detergent, and make sure to remove any excess water in the filters since this is what normally creates the horrible smelling odor after it has been washed and dried.Also let the filter get completely dried up before you refit the filter again.If its fitted wet the bad odor smell comes.You can use hairdryer to dry the filter quickly.Check out if this is helping.Thanks.Helpmech.
Posted on Dec 10, 2010
  • 53 Answers
SOURCE: Model #3760-2 Bissell upright vacuum-
Is the noise coming from the belt area, ie. beater bar, or does it sound like it is coming from the motor itself? It is possible there is something caught in the brush roller.
When you turn the roller off, does the noise go away?
Posted on Dec 20, 2010
Need a new belt for a bissell lift off revolution turbo
Hi Dale, sorry to hear the belt has broken. Now is a good time to order filters for orders that are $30 or more receive free shipping. Here's a quick link to ordering one.
http://www.bissell.com/parts/?sc=search2&searchtext=3760
Jan 26, 2013 | Bissell Cleanview Helix Deluxe Bagless...
Brush won't turn bissell vacuum 3760-4
No there is no separate fuse, when you did this you caused the drive motor to overheat, this destroyed the belt as you have seen and likely burned out the motor for the brush head..
Dec 06, 2011 | Bissell Vacuums
Model #3760-2 Bissell upright vacuum- making very loud noise when running. Cleaned all filters- no difference
Dec 20, 2010 | Bissell Vacuums
Bissell 3760-4 is running extremely loud.Any soulutions Please help!
Mine too! Have you fixed the problem or just given up. It's so loud it sounds like a piece of shop machinery that requires ear protection!
Nov 23, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
I would like to know where i can get a manual for the bissel 3760-4 model. i bought this used and i would like a book on parts i might need down the line. thank you.
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Aug 12, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
I would like to know where i can get a manual for the bissell 3760-4 model. i bought this sweeper used and i would like to get a book on the parts . thank you for your help
I have a 3760 lift off bissell. Replace the torn
Did you get the right belt size? The belt you should have bought is this one:
Bissell 3760 Belt
Nov 08, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
Need tel number for manual
You listed this under a Bissell Lift-Off so I am assuming your looking for a Bissell manual. You can reach Bissell at (800) 237-7691or you can download your manual below. Your unit should be a 3750 or a 3760.
http://www.bissell.com/Product_Search.aspx
Dec 15, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Vacuums Logo
292 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
