I have a model P56740BG and it won't turn on. I push the on button and the green light comes on and goes out but the unit does not come on. What cane I do?
    President:
  • 1,779 Answers
You could possibly have a defective High Voltage Splitter , these are common failures with RCA's. It's not something you can repair yourself. It's not an expensive repair. I would say about $150.00 if that's the problem.
Posted on Apr 01, 2008
SOURCE:
Computer won't turn on
this is only a guess sally yoour PSU need to be replaced.
Apr 09, 2013 | HP Omni Pro 110 XZ822UT AllInOne
Mitsubishi VS-70707 rear projection TV
DOES THE LIGHT BLINK IN A PARTICULAR PATTERN?
Jan 31, 2008 | Mitsubishi WS-55807 TV
When I push the on button the green light comes on for second or two then goes out.(will not stay turned on long enough to even get a picture on the screen.Mitsibishi Model # WS-55315
This set has a self check feature--if set has been unplugged it clears the error buffer--plug in and try to turn on set.
When green light comes on and then goes off ON THE FRONT OF THE SET press and hold BOTH the menu and input(device) buttons at same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat the code for a total of five times.
Let me know what error code you find and I will explain it.
May 27, 2012 | Mitsubishi Televison & Video
Kindle Touch won't start
Bad battery, needs changed.
Nov 09, 2017 | Computers & Internet
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
I have no power, i called a repair man, he said unplug it then push the reset button...i get a blinking green light for a few seconds...now what?
The set if it has a DM unit when unplugged should blink for 70 seconds and allow you to turn on.
If it does not, if when you try to turn on green light comes on and goes off---do the self check:
Press and hold both the menu and input buttons for 5 seconds and release both; power light should blink a two digit error code at least 5 times. 2 blinks, pause and 2 blinks is the most common.
If the set has a reset button on the front it has a DM unit---built in receiver--even if it fails the green power light will blink nonstop.
Again, if you try to turn on and green power light comes on and then goes off---do the self check and let me know what you find.
If this information was helpful rate this solution as "very helpful" as I do this here for free.
Also let me know what you do or do not find as I am here to help you.
REGARDS, SD TECH
Aug 11, 2010 | Mitsubishi WS-65511 65" Rear Projection...
It will not turn on by remote green light comes on then goes off
replaced bad caps in def module caps will have the top bowed.
Nov 04, 2009 | RCA HD52W59 HDTV Projection Television
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Ekse
