Question about Kenmore 51562 / 51564 / 51569
Kenmore refrigerator water dispenser problem
Our kenmore refrigerator is about 5 years old. Within the past year we have noticed that the water dispenser will dispense something with the water that looks like a wet piece of paper. If you let it stick to the side of your glass, it eventually looks slimy. You can also lift it out of the glass and it seems to be some sort of slime. It has nothing to do with the filter. We have changed the filter several times in the past year with no change to the algae/slime. It seems to be on the sides of the tubing that runs through the refrigerator before being dispensed. Any suggestions on how to get rid of whatever it is?
  • 1 more comment
  • R_RR Apr 21, 2008
    We too have a kenmore refrigerator, and it's only about 2 yrs old. We noticed the slimy substance in our water a few months ago, and thought changing the filter would correct the problem. Unfortunately, it did not, and we now have a technician coming out later this week to take a look at it. We're guessing it's slime, but really have no idea. Just hope there is a simple, inexpensive, solution.
  • HouClp May 01, 2008
    we also have slime in our kenmore refrigerator water dispenser the sears repairman told us to remove the water filter because it was removing the chlorine from our water source causing the algae to grow in the water line. so,what good is this refrigerator if you can't use the water filter? Never heard of this problem in any other brand refrigerator.I will be contacting Sears for a rebate towards the purchase of another brand refrigerator!
  • TerryMcAfee Feb 10, 2009
    I have a similar problem but the "slime" in my case is tiny green particles / floaters that appear to be algae. I'd like to flush the system with bleach but can't figure out how to do it. Any suggestions?
SOURCE:
  • 111 Answers
SOURCE: kenmore refrigerator water dispenser problem
SORRY TO SAY THIS BUT IT SOUND LIKE YOU HAVE BLACK ALGEA IN YOU WATER SYS WHICH IS GOING TO REQUIRE A TECH TO REPLACE ALL THE TUBING IN YOUR WATER INLET SYS TO GET RID OF IT. GOOD LUCK AND CONTACT APPLIANCE SERVICE CO. P.S. DON'T DRINK THE WATER OR USE THE ICE IT WILL CAUSE MEDICAL COMPLICATIONS
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on May 30, 2008
  • 46 Answers
SOURCE: Water dispenser won't stop dispensing water!
Hi I dont have the knowledge of your fridge, but I'm just going to throw this idea your way , please forgive me if im wrong :)
Perhaps the problem is due to syphonage, the discharged liquids are creating a vacuum along the line.
Did you reposition the height of any supply hoses ? none of them should be above/higher the outlet source itself.
You could also try installing a inline reverse flow suppressor
(small plastic filter that only allows one-way direction of flow.
Posted on Jun 14, 2008
larryyb
  • 291 Answers
SOURCE: Water dispenser in the door is dispensing water very very slow.
check and see if the ice is fully formed or look hollow / if hollow then run you a new water line to frig / if cubes are full then replace water valve.
Posted on Nov 26, 2008
  • 531 Answers
SOURCE: Taste of water from water dispenser has "plastic taste"
you have to flush dispense water on till taste gone
Posted on Apr 02, 2009
woodchuck789
  • 4070 Answers
SOURCE: Kenmore s/s f/f; ice dispenser working; water dispenser not
If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it doesleave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there.
Posted on Oct 02, 2009
556124 refrigerator. Ice/water disp. shorted out.
Your problem may be with the dispenser electronic control board. This is an issue that should be handled by an appliance service company.
Feb 22, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
3 year old kenmore top freezer, won t defrost ''no ice'' buildup behind the freezer panel I removed. no clicks on the defrost test, same result for method #2. The ice maker works ok when freezer is at...
your freezer had a heater and a bi metal behind its pannel. if they won't work properly than you would face problem like this.......contact your service authority. it cannot be solved by your own
May 14, 2009 | Kenmore Refrigerators
Kenmore refrigerator Model No. 106.56839600 water dispenser
Hi
The water is kept cool in reservoir in the fridg. Remove the inlet tube push for water check pressure better worse? Work your way back to valve
good luck
Apr 12, 2017 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore 106.71299100,water freezes on floor of freezer,drain line freezes,I have opened drain with hot water etc.then problem returns in about one month. the refrigerater is 6 years old and this problem is...
You have a partially plugged drain, causing water to flow too slowly. Try reaming out the drain with a long stiff wire until water flows thru it like a faucet. You may have to unplug the unit for a day to get every part warm enough. Hope this helps!
Jan 28, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
The top shelve of kenmore refrigerator stay too cold
I think my problem seems better now that I"ve lowered the temp to almost off. Oh by the way, what made you think I have a side by side. What I do have ias a 10 year old single door kenmore.
Jan 09, 2009 | Kenmore 25.1 cu. ft. Side-By-Side...
May 30, 2008 | KitchenAid KSRS25IL Side by Side...
Kenmore frigde not dispensing water
Replace the water valve.On the back at the bottom you replace the part the water line is attached to.In the pix i'll show you what a typical valve looks like.754d79f.jpg
May 29, 2008 | Kenmore 53092 / 53094 Side by Side...
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
Kenmore 51562 / 51564 / 51569 Logo
1,217 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
