Question about Brother FAX-1020 PLUS Plain Paper
Brother fax 1020 B9 error
I cannot fax a page, the page moves down half way then machine stops the transmission and advises it is a B9 problem.
    Genius:
  • 3,422 Answers
Click HERE to download the user manual and then view the troubleshooting steps your problem will be solved.
Goodluck,
Please don't forget to rate he solution.
Posted on Apr 03, 2008
  • 113 Answers
Try a good cleaning-" B9 " means it cannot see the page your trying to send
    Master:
  • 555 Answers
Drivers for your printer can be downloaded here.
Hi there, I have brother 1020 fax and clients are
No, the scanner block is defective. I think it's time for a new fax machine.
Apr 18, 2010 | Brother FAX-1020 PLUS Plain Paper
HOW CAN I STOP THE MACHINE FROM PRINTING AN ERROR REPORT AND WASTING A PAGE OF RIBBON
The brother fax machine will always print out a transmission report when there is a failure to send a fax.
There is no way to turn this feature off.
The closest option to this is turning transmission reports off, but this will still print out a message when the fax does not go through properly.
Mar 25, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
What is error code b9 mean on the brother fax 1030?
Hello :
B9 Light emission intensity error of the LED array .
Check CIS unit (scanner device) or check main PCB .
According the error either one of these units can be faulty or a lose connection but getting to these would require you take apart most of your fax machine . Maybe it's time to purchase a new fax machine .
good luck .
rate please !
Mar 18, 2010 | Brother FAX-1030e Plain Paper Thermal...
Fax Brother 1020
SOUNDS LIKE YOU ARE USING REFILLS? IT IS BEST TO USE THE CART WITH E FILM ALREADY IN IT  GOOD LUCK
Jan 26, 2009 | Brother FAX-1020 PLUS Plain Paper
OUTGOING FAX ERROR CODE: NG
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
To do this:
Press Function/Set, 3, 9.
This should take you to MEMORY TX
and MEMORY TX: ON?
Then press either the left or the right arrow (< or >) to switch on or off, and press Function/Set.
For the next fax transmission only, press < or > to select
NEXT FAX ONLY and press Function/Set.
This will mean you don't add any more to the memory and may be able to send faxes. There is a possibility that you will only be able to fax using manual transmission, but at least you should be able to use the machine to fax at all!
I apologise if the jargon is confusing, just try to go through the process one step at a time and you should be fine.
Hope this helps :)
Chris (ziraffa)
Dec 13, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Receiving multiple page fax on Brother Intellifax 4100e
it may be the memory, try switching to direct printing instead of going into memory, if it prints you should change the memory.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother fax1020
start by inserting a document into machine and press the copy button. if come out ok then check your phone line to see if it's live and plugged into the right slot marked "L" and not phone. if still not able to fax try to call that number using a regular phone and listen for the high pitched squeeling noise.
hope this helps.
Thank You,
Mikey
Apr 03, 2008 | Brother FAX-1020 PLUS Plain Paper
Brother 1020 Fax Technical Problem
If all page are coming out blank there is only one possibility. The Thermal Head (basically heats the ink on to the paper) has failed. It should be a relatively cheap fix but like you said the machine is know over five years old.
Feb 18, 2008 | Brother FAX-1020 PLUS Plain Paper
Transmission Verification Report
HI Shelia. THere is a button marked as "function" on your fax machine and got to "set up". Press that and select the "print out" group. When you get in there you will see "reports"... select that and it will let you get into your reports mode. Make sure you have transmission turned off. You can set it up to print out every 50 faxes...that seems to work best for most people. You may have to dig around in those menus...but its in there. I just don't have one sitting in front of my right now. If you still can't find it, email me back and I will look monday when I am back at the shop.
Nov 16, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother FAX-1020 PLUS Plain Paper Logo
302 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
