Question about GE Advantium SCA2000B Microwave Oven
Door Switch- SCA2001 FSS 02 GE Advantium 220v
Everything worked on my oven (halogen lights, turn table) except the microwave. An appliance man opened up the front panel and noticed the leads on the top door switch were slightly burnt (brown color under the plastic sleeve but the plastic is not damaged). He did not disconnect anything. He adjusted the position of the switch and everything worked. A week later, same thing happens. The microwave door is hard to open and has been from the start. I have opened the front panel (power is off) and see the upper door switch is not snapped into place and I can't figure the position it needs to be in. It appears to enter the white plastic holder on a 45 deg angle but the white plastic clip does not snap anywhere on the switch.
It is not the same as the lower door switch because the plastic holders are not the same.
How does the switch fit in the socket?
Thank you for your time and consideration.
Anthony D. Saba
sabatony@aol.com
    Genius:
  • 3,587 Answers
A parts diagram would be useful here..let me go see what's available
Posted on Apr 01, 2008
Problem with the GE Advantium (model sca1001fss01) Convection / Microwave Oven Everything works except the microwave. It makes a sound like its working, table turns, but does not heat or cook.
sounds like the magnetron. Youll have to have a technician replace it. if you have a warranty just call the company and they should take care of you.
Jan 29, 2011 | GE Advantium 120 Convection/Microwave Oven
Re: "my GE Advantium SCA2001
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 31, 2010 | GE Advantium 120 Convection/Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Advantium 120 Interior light is out. How do I replace?
Here ya go... this fella did a good job and replaced the bulb for $4.95 vs $180.00 for the service call parts and labor. This is With pictures and how to steps down the page.
http://www.instructables.com/id/GE-Advantium-Microwave-Halogen-Lightbulb-Replaceme/
Thanks for using FixYa.
Kelly
Apr 09, 2010 | GE Advantium 120 Convection/Microwave Oven
Replace fuse on GE Advantium Speedcooker Oven
there is a fuse located underneath the outer cover, its called a ceramic fuse and is of cartridge type about 1" long by 1/8" diameter and has a white body and 2 silver ends and you can take it to a hardware store they have them but make sure to get correct amperage rating 15 or 20 amp
Sep 05, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium Microwave section doesn't work.
The primary interlock switch on my Advantium has failed twice. The replacement part is available at: appliancepartspros.com part no. for my Advantium was AP2622452 and it cost $11.74 + $6.95 shipping.
For what it's worth, my nylon connector and wire covering were also scorched a bit but the last primary interlock switch lasted me for over a year.
Please note that I am not an expert at repairing appliances and that I assume no responsibility or liability for any attempt you may make to repair your own appliance.
May 30, 2009 | GE Advantium SCA2000B Microwave Oven
Oven part works fine, microwave runs but doesnt heat
bad micro switch in door handle, 79.95 for GE man to check,9.61 for the part and changed it myself
Apr 15, 2009 | GE Advantium SCA2000B Microwave Oven
Advantium Bulb replacement
You are describing the little bulb in the front. The speedcook light is a different bulb
See: http://www.instructables.com/id/GE-Advantium-Microwave-Halogen-Lightbulb-Replaceme/
Apr 12, 2008 | GE Advantium SCA1000H Convection /...
GE Advantium SCA2000B Microwave Oven Logo
322 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
