Question about Sceptre X20G-Naga II 20.1" Flat Panel LCD Monitor
TV Universal Remote Codes
What are the Universal Remote Codes for this tv? I tried the following codes assigned to the remote I am using but none of them work: 1217, 1360, 0878 and 1599
Any suggestions? I already emailed the company that supports this remote (Atlas DVR day-1055 universal remote).
Thanks,
Demok
  • demok Apr 02, 2008
    Yeah sorry, I forgot to mention that I did that already. :) I can power it off & on, but that's it.
    Master:
  • 518 Answers
Most remotes have a "Code Search" function. Try that and if it doesn't work then it's not compatible.
Hope that helps...
Geno
Posted on Apr 02, 2008
Lost the remote to my philips HTL2101A and it has no power button, so i can't use a programmable remote.
It should still be possible to use a universal remote to power on your TV.
Some universal remote instructions will say that the device has to be turned on in order to properly program the remote. This is not necessarily true, and you should still be able to use the universal remote to find a preset that will at least turn your TV on so you can then follow the instructions for the remote to find the exact preset that will work with every button on the remote.
First, look in the instruction booklet of the universal remote for the section of preset codes. It should be a huge list of 3-5 digit numbers with corresponding device names. There should be at least one or several for Philips devices. Find the code that matches your device.
Then, follow the instructions to program in that code. Should be something like: Hold down a certain button until the light on the remote blinks. Enter the code. Press another button to program the remote for that code. Keep in mind every universal remote is different and will have different steps to follow, but all generally work the same way.
At this point you'll want to just try the POWER button on the remote. If your TV turns on it means the code you entered is the correct code, or at least close to the right one. If it's not the exact correct code some of the other buttons won't work or will command your TV to do the wrong thing.
If your TV does not turn on with the first code you tried, you will need to program the remote with on of the other Philips codes. Just follow the same instructions you used to enter the first code and try another one from the list. Try the POWER button with each of the codes used until the TV turns on.
If none of the Philips codes work you will need to follow the universal remote's instructions to cycle through all of the codes (I have had to do this before). There should be another section of instructions that tell you how to do this. Again, try the POWER button for every code until the TV turns on. Once the TV is on, you will want to follow the instructions for the remote as normal to find the exact code preset that will work correctly with your TV.
If all else fails you might want to purchase a remote that is at least newer than the TV you are trying to operate because an older universal remote may not have the correct preset for a newer device.
I hope this helps! Good Luck!
Dec 15, 2015 | Philips HTL2101A/F7 40 Watts Sound Bar
I lost my remoe and manuel.I went to walmarts and bought a universal remote taht say its compatable with Broksonic..I will not work..want turn tv on or off? any sugestions?
U should turn on the tv ON manually by the tv power button to get the tv ON and used all the codes that was provided by the universal remote user manual for the ur tv brand Broksonic.U must follow the directions carefully and enter each codes correctly,the correct universal codes for tv is enter,ur tv will able to work by the tv universal remote power button will able to turn the tv off/on of the tv set.If none of the tv universal codes that was provided by the universal remote user manaul for ur tv brand Broksonic don't work.Just return the thing to Walmart and get ur money back.Try website like Remotes.com to buy the tv original remote,than 100% will work for ur tv set.
Aug 17, 2011 | Broksonic SC20145 20 in. TV/VCR/DVD Combo
Hello i have a toshiba md9dm1 tv/dvd combo and i lost my remote I have a universal ge remote none of the codes work Do you know the code for my tv/dvd combo?
hi,
If you remote is a 4 digit one then the codes are
0394, 0924
If the remote is a 3 didgit one then the codes are
394, 902
MANUALLY ENTERING CODES
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the
INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR,
DVD, etc.). For AUX, press AUX then the device button you are assigning to
AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the
GE Universal Remote. After your code is entered the INDICATOR LIGHT will
turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER
button. Your device should turn off
OK
Aug 03, 2011 | Toshiba MD9DM1 9 in. TV/DVD Combo
Universal codes sylvania need tv
Universal codes are in ur tv univeral remote manual already.None of those codes work for ur tv brand.None of the codes people give u will work either.Return the universal remote where u bought it.Try website like Remotes.com to buy the tv original remote.
Jun 11, 2011 | Sylvania LC370SS8 Television
Bought a 42pc3d-ud Lg Plasma tv from someone without a remote so i bought a new remote. i do i program it
This is a universal remote u bought wright?Check ur tv remote owner manual follow the instructions and program in ur tv universal remote codes for ur tv universal codes.If none of the tv universal codes of ur tv model will work,return it.Try website like Remotes.com to buy the tv original remote or very close compatible to the original one.
Jun 04, 2011 | LG 42PC3D 42 in. Plasma Television
I need the codes for a GE universal remote for a Daewoo TV
Welcome to FixYa!
You can try the following GE Universal Remote codes for Daewoo TV:
0130
0004
0009
0100
0005
0138
0043
0140
0039
0252
0279
0444
0080
0042
0058
0017
0010
0126
0018
0127
0019
2. Press and hold the CODE SEARCH/SETUP button on the remote until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR, DVD, etc.). For AUX, press AUX then the device button you are assigning to AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER button. Your device should turn off.
If none of the codes listed work for your device try the Code Search method described below.
USING CODE SEARCH FUNCTION
If your TV, VCR, DVD, etc. does not respond after you have tried all the codes for your brand or if your brand is not listed, try searching for your codes by following the steps below.
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR LIGHT lights, then release.
3. Press and release the device button for the device you are programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will blink once then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
4. Press and release POWER until your device turns off. Wait at least 2 seconds between each time you press POWER. Important: You may have to press POWER up to 250 times.
5. When your device turns off press the ENTER button (Should your remote model not have an ENTER button, then press the OK button.) The INDICATOR LIGHT will go off.
Thank you for using FixYa!
Have a great day.
Jas247
Apr 20, 2011 | Televison & Video
I need a remote code for a rca remote for the olevia remote control can you help
Unfortunately Olevia is one of those t.v. brands that is not compatible with many universal remote controls. They make a Universal Learning Remote specifically available from Olevia on their web site that may solve your problem if your universal remote control turns out not to be compatible with your Olevia television.
As for what codes you can try, there are many, and the codes depend on your universal remote control brand. Many times, an RCA code will work for Olevia televisions, so you should try the RCA codes that come with your universal remote first, before trying any of these other codes.
If you have a Dish Network Universal Remote you can use code 506 or 127.
Direct TV remote codes vary by model number on the remote control, but the following codes work with most Direct TV remotes: 506, 127, 11144, 11240, 11331, 11610
Cable Vision use code 506
Charter and Movie Box remotes you can use 1144 or 1178
Comcast codes are 11144, 11240, 11331, 21075, 10159, 10154, and 10088
Cox code is 1610
Brighthouse remote codes are 1610, 1144, 1240, and 1331
Time Warner remote codes are 1610, 1144, 1240, 1331, 432, and 1610
If none of these brands are what you are looking for as far as your Universal Remote Control is concerned, many universal remote controls will work with Olevia televisions if you use the codes found under the RCA, LG, Phillips, and Yamaha in the code listing included with your remote control.
Jul 25, 2009 | Televison & Video
Code for a tv remote
if u have a universal remote and none of the codes seem to work after trying all the codes and non still don t work follow these steps
1. make sure the power on the TV is turned on
2 press and hold code button until it flash twice
3 then press the TV mode button until the light flashes the press
4 power button until TV powers off
Feb 13, 2009 | Daewoo DTQ-20U4SC 20" TV
Comcst remote control code not working
look on the label on the back of your Emerson TV. Read the small print and see if there is a possible different manufacturer that actually made the Emerson TV. Just because it says emerson doesn't mean emerson made it. Also if no luck there try the UL listing code and search that code to the UL listing website. That may help also.
C-Dog
Feb 12, 2008 | Emerson EWF2703 27" TV
Need code for sanyo tv
Welcome to FixYa.
SANYO TV Codes: 0154, 0159
Please be informed that the codes vary with different make and model of the universal remote that you have. If none of the codes above work, please post back with make and model of your universal remote included.
Thank you for using FixYa.
Jas247
Sep 01, 2007 | Sanyo DS31590 31" TV
Sceptre X20G-Naga II 20.1" Flat Panel LCD Monitor Logo
538 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
