Question about Samsung SMH7178STD Microwave Oven
No heat for microwave
Do you know the part no. for the heating element for the Samsung SMH7178STD? I didn't know microwaves had heating elements.
  • 185 Answers
Its probally the magnatron
Posted on Jun 28, 2008
  • Anonymous Oct 13, 2008
    its the magnatron
  • 871 Answers
The heating element is like a bulb for the microwave. there is no part number though. actually, what you need to do for that isa manually take it out and brign it to a electronics shop. i do not advise you to do this becuase it is dangerous. have someone who is certified electrician do this.
Posted on Apr 02, 2008
SOURCE:
Samsung microwave runs when door is closed
1.check fuse
2.check relay (microwave oven magnetron)
May 11, 2014 | Samsung SMH7178STD Microwave Oven
Turntable is working but no heat
Heating element problem.Either element is cracked or its connections are loose.You will have to heck with meter, to confirm, whether its element or its shorted wire to the elements.---------Thanks.
Apr 21, 2011 | LG Microwave Ovens
I have a samsung smh7177ste/be microwave that will not heat. Every thing seems to be working as normal
The problem is one of three things, the magnetron "common issue" or the high voltage capacitor and diode can be a factor, the above mentioned work together to heat food. Depending on the nature of the repair, parts and labor can run as high as a new microwave oven.
Mar 02, 2011 | Samsung SMH7178STD Microwave Oven
Samsung smh7178std won't heat, replaced fuses, connections, tested transformer, tested capasitor,
probably the magnetron could also be the diode on the capaciter. they have a 7 year warranty on the magnetron.
Apr 22, 2010 | Samsung SMH7178STD Microwave Oven
My samsung SMH7178std microwave doesn't heat anything up. it makes a buzzing sound after i set timer and press start.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jgk
Feb 10, 2010 | Samsung SMH7178STD Microwave Oven
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
Samsung MW SMH7178STD Not Heating
I would think it may be a failure of the cook relay on the board, since the noise is quieter.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Sorry i can't help more. This will need troubleshooting.
Aug 05, 2008 | Samsung SMH7178STD Microwave Oven
No heat!
you have to replace the heating element for that old microwave. its already been 3 years. sometimes this do happens because of the use and this is the solution.
Apr 01, 2008 | Samsung SMH7178STD Microwave Oven
Microwave Ovens Logo
401 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Steve Allison
Steve Allison
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
