FixYa.com
Tags:
Printers
Generic problem for all Printers
E MACHINE T1115. I CAN'T
posted by calliemarie on Apr 01, 2008
E MACHINE T1115. I CAN'T INSTALL AN ALL-IN-ONE EPSON STYLUS COLOR PRINTER. THE INSTALL NEW HARDWARE WIZZARD SAYS THE PRINT SPOOLER IS NOT WORKING, BUT THERE ARE NO DETECTIBALE PROBLEMS, WHEN I CHECK HARDWARE DEVICES.I TRIED TO MANUALLY START THE SPOOLER BUT I RECEIVED AN ERROR 1068: THE DEPENDENCY OR GROUP FAILED TO START.
THERE IS AN OLD LEXMARK PRINTER ON THE COMPUTER, I UNINSTALLED ALL PROGRAMS ASSOCIATED WITH IT, BUT IT IS LISTED ON PROGRAMS BUT NO MEMORY WITH IT.
Comment by calliemarie, posted on Apr 02, 2008
Mattazon, Please send your respnse to:
llcoxir@bellsouth.net
I am at my home computer, where I can print the instructions. If I did this right, then I will download the "Windows Server 2003 Resource Kit Tools Kit," and run cleanspl.exe as directed.
Comment by calliemarie, posted on Apr 03, 2008
Mattazon, I'll let you know how it works.
Thanks.
Comment by calliemarie, posted on Apr 06, 2008
Mattazon,
This worked. Thanks so much for the help!!
After I typed in the prompt & restarted the computer, I was able to "uninstall ," the Lexmark Printer and install the new one.
Great Job!!
Calliemarie.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
FixYa! (100)
mattozan
Rank:Guru Guru
Rating: 87%, 88 votes
The command should have a few more spaces.
You can copy and paste the next line into the command window, or just type it exactly as it appears below (with all spaces intact):
sc config spooler depend= RPCSS
Comment by mattozan, posted on Apr 07, 2008
Fantastic! I'm glad I was able to help!
Rating Locked! (?) calliemarie has rated this solution as FixYa!
Solution #2
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Mattazon
I tried your recommendation:
Go to-> Run and type cmd
that should be, (type "cmd") (do I actually put in "type cmd or only cmd?)
Then hit return (when I hit return, a black box came-up-C:\\documents and settings\connie hall-the curser was blinking at the end of this, instead of on the next line) Was it fully loaded?
Then you instructed me to type: scconfigspooler= RPCSS then hit return to reboot the computer. I did this but the computer still didn't load the hardware. I just wanted to make sure i typed the right command. please respond.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: HP DeskJet F380 All-In-One Printer HP Photosmart C3180 All-In-One InkJet Printer HP OfficeJet 7410 All-In-One InkJet Printer HP Officejet J5780 All-In-One InkJet Printer HP PSC 1610 All-In-One InkJet Printer HP PSC 1210 All-In-One InkJet Printer HP Officejet Pro L7780 All-In-One InkJet Printer
Can you Help with these Printers problems?
Zebra Z6M Plus Thermal Label Printer
Error conditon ribbon out
I am getting the message in the... Answer This...
HP Deskjet F335 All-In-One InkJet Printer
new computer, same printer
I got a new computer and have... Answer This...
Printers
Error #6A00 paper jam
Error #6A00 paper jam Answer This...
Printers
ink cartridges slide side to
ink cartridges slide side to... Answer This...
Printers
lexmark z611 nedd the driver
lexmark z611 nedd the driver to... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
