The maunals you seek can be found at the link I have included below. But you will have to locate your Model Number on the back of the TV. The manuals also cose $4.99 each.
dear,i also had suffer from it's service menu code. in some days ago i had been seeing a web site, their was had every service menu.then i got your sansui tv model.your sansui "ctvk2k21"model's in the IC no. is "tda9370ps/n3/a/1932" service menu is press "menu(from remote) & 0,3,2,3(from remote)".for more information call me for in any electronics gagged problem.
It should hook up like a regular VCR does. A short cable from the OUT on the back of the dvd player to the cable hookup on the back of the tv.
You can also use audio/video wires (3 wire cable). Somewhat same method...connect 3 wires to audio/video OUT of the dvd player to COMPONENT section on the back of the tv. Should be color coded to match colors on the 3 wires.
Hope this helps some. It is difficult to explain. Good luck!
I assume you are saying that the DVD player only has RCA jacks. It would be good to know if the DVD player has Component output as that is the preferred output. You will know this if the RCA jacks on the DVD are color coded green, blue and red.... You would by a set of component cables, hook to DVD matching colors and then find the same color code on input of the TV. You must also run the red and white cable from the DVD output to the TV input for audio. The input on the TV would be labled component in or input and a #. Simply select the input, or source button on remote to select the input that matches your choice and all should function. If there is no component on the DVD output and only a composit hook up (color code by yellow, red, white) again just match that to the corresponding input on the TV.
