Connecting my HP ScanJet 5200C scanner to my HP Pavilion Home pc
To connect this scanner with my PC, apparently, according to HP, I have to chain scanner and printer off same parallel port. If so, what part number do I need---or is there a simpler way to accomplish this connection without chainning the printer and the scanner?
Thanks for your help
Kemperassoc@hotmail.com
  • Rookssailor Apr 02, 2008
    Thanks, HaMAR,
    This is an old problem, and I have not really needed a scanner---but now I do---and the darn thing needs a special fitting to install. Back 4 years ago when I set out to install this first, I remember a tecky at Best Buy telling me he thought I could install it using a USB hookup. I'm game to try it. I would need a different cable, wouldn't I.? Where would the cable FROM the scanner be connected?---and what cable should I buy? Sure appreciate your help on this, HaMAR.
    Rookssailor
  • larrybrown Apr 30, 2009
    I have an older HP 5200 scanner. I have the usb cable but dont have the original multi prong cable( sorry I dont know my tech jargon)
    The software while downloading tells me I cant use the USB cable.
    I cant find any information on where to get the multiprong . Does anyone have an idea on how to obtain this thing.
    Thanks
    Larry
    Problem Solver:
  • 9 Answers
Rookssailor,
I don't think you can (successfully) run this scanner off the paralell port. I'm drawing on memory here but I think this scanner has serial and usb ports. If you are running Windows XP, use the USB hookup. If you are running Windows 95, 98, Milliniaum then you might want to use the serial port. At any rate the scanner software should be installed before you plugin the scanner.
If I'm completely "full of it" and you really want to use a Paralell connection then you might want to use a paralell to USB adaptor (Belkin, perhaps others make one of these).
haMAR
Posted on Apr 01, 2008
My HP ScanJet 5200C doesn't work with my new HP computer. Do I have to install a driver, or...
Access the manufacturer's web-site: http://support.hp.com
and enter '5200C' and do the search.
Select the device-drivers for the Operating System that is installed on your new HP computer.
Download & install.
Sep 23, 2010 | HP Scanjet 5200c Flatbed Scanner
I changed my Pc and I don t have an install cd for my hp scanjet 3970.Ca you help me?
Here you are:
http://www.driverstock.com/download-HP-3970-driver/10-7-4669/index.html
Ok be sure to select the coresponding windows and type the security code accordingly.
Good luck
Uttam
Jan 26, 2010 | HP ScanJet 3970 Flatbed Scanner
HP 5200c scanjet - get black page
yes, your fluorescent bulb is burned out and you cannot buy a spare. Sorry
Oct 11, 2009 | HP Scanjet 5200c Flatbed Scanner
The type of scanner that can be used for canofile for windows?
CAnon 5020 is a good scanner, but requires SCSI card interface (Adaptec 2940- 50 pin card). Insrtal this card and use CapturePerfect, you will get good results.
S. Mohan,Chennai, India
Jul 05, 2009 | Canon Canofile For Windows Full Version...
At scaning time show
Hi
I take it the scanner is connecting to your pc okay? the paper need to engage in the feeder. Try just putting one piece of a4 copy paper in the scanner and seeing if that will register as beng paper in the document feeder.
Kind regards Liz
Feb 19, 2009 | HP Scanjet 7800 Pass-Through Scanner
Unable to scan using HP Scanjet 3200C in Win XP Pro
Hi Shantala,
HP advises that, on some systems, the scanner hardware may get into an error state that will keep the scanning software from finding the 3200c ScanJet. If your scanner still isn't found after installing this driver and software update, please follow the directions below:
  1. Unplug the power cable from the 3200c ScanJet.
  2. Unplug the parallel cable(s) from the 3200c ScanJet.
  3. Shut down the PC and wait for ten seconds.
  4. Plug in the power cable to the 3200c ScanJet.
  5. Plug in the parallel cable(s) to the 3200c ScanJet.
  6. Power your PC on.
If you still have the problem, uninstall the driver from device manager, and download and run this .exe file version of the driver instead.. and if necessary, repeat the above steps..
ftp://ftp.hp.com/pub/softlib/software4/sj648/sj-1436-3/sj648en.exe
Hope this helps
Chris (ziraffa)
Dec 22, 2008 | HP ScanJet 3200C Flatbed Scanner
Windows Vista Driver for HP Scanjet 3200C
Help me I need vista 32 bit driver for my hp scanjet 3200c.
Thank you
Oct 24, 2008 | HP ScanJet 3200C Flatbed Scanner
HOW TO CONNECT SCANJET 5470c to computer
Hope you have a hp 5400 software CD which will install the programme of the scanner to your PC. Once this is done then you will be able to connect and operate your scanner with PC.Your PC should have a USB port to connect the scanner with it.
Ajit bhutani
May 20, 2008 | HP Scanjet 5470c Flatbed Scanner
Hp scanjet 5200c does not power on
check your adapter or power cable first.
Mar 20, 2008 | Office Equipment & Supplies
287 people viewed this question
jasbo
jasbo
