Misubishi ws-55711 rear projection crt. Looks like the green tube has gone out of alignment. The two tubes red and blue have one image and green tube has a curved image. What is the solution. The tv is about five years old, had a perfect record prior to this problem.
Have you looked at replacing the convergence memory chips in your TV? The part # will be stk392-110 or possibly stk392-120? There will be 2 of these parts on a board standing upright. The part # will be printed on the part.
Posted on Apr 01, 2008
HOW DO YOU ADJUST RED,GREEN,BLUE TUBES
If your talikng about alignment that is done through the Convergence feature. If its the color balance youre refering too its most likley indicating that the CRT coolant needs replacment as that will make the red Tube dominate and wash out both blue and green colors untill they appear dull and dim.
Feb 17, 2011 | Philips 60PP9352 60" Rear Projection...
Picture is distorted, kind of looks like a 3D image without the 3D glasses.
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 31, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Image is off ... green red and blue not aligned
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 26, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Hooked up PS3 to system and when watching DVD's the right side of the picture is blurry and appears doubled, like an old 3D movie without the red and blue glasses. When watching TV everything looks fine.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Jan 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have and 65" Mitsubishy HDTV model WS-65511 serial :118393 I never had a problem before but las week i was watching a program and sudenly a second blue image was on the scrren, i decided to open the...
there just might be a slight chance an adjustment of g2 high voltage to the blue tube might help however there is a good chance there is a problem with the tube
Oct 15, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Convergence adjustment aligns red and blue picture tubes to align with fixed green tube. Green image appears to skewed (possibly out of focus) in one direction making it impossible to get red and blue...
Ur tv convergence are dead.U know how to solders?Must replaced the 2 STK convergence ICS,some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 04, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Red and blue color on TV is aligned but blurred, green is ok
U have a CRT Tube coolant problems.Tries Websites MCMElectronics.com,Tv reapair World.com to buy CRT tube coolant to recharge ur CRT.
Feb 26, 2010 | Sony KP-46WT500 46" Rear Projection...
Mitsubishi WS-55711 Green sagging
replace the convergence ics again.sounds like you got a bad ic.realigned the green convergence geometry after reinstalling the ics.you will need to go into the techician service menu and go into the cross-hatch pattern to do the alignment.
May 27, 2009 | Mitsubishi WS-55711 55" Rear Projection...
I have the mitsubishi 55711,i have a double image
This is a V-21 Chassis common, with these symptoms, for failure of the convergence amps. This set uses two STK 392-110 Sanyo amps mounted on a heat sink and hard to miss. They're a 40 pin ic about the size of a half pack of cigarettes.
It has also been my experience that two or more of the yoke return resistors need to be replaced, most commonly R8c21 and R8c22, both are 3.9 ohm 1w but test all of them for reliability.
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
May 14, 2009 | Mitsubishi WS-55711 55" Rear Projection...
Jvc tv picture quality
sounds like your crt tubes...meaning Red, Green and Blue are out of alignment...or possibly 1 of the crt's is burned out.
Jan 29, 2007 | JVC AV-48WP30 48" Rear Projection...
Open Questions:
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
