Question about Refrigerators
Electrolux oven door
Hello we have take electrolux oven door off lifted the catch on each one and removed door from oven.
the spring loaded catches have locked and we cannot put the door back on
can they be released
thanks
  • 26 Answers
I think your talking about the door hinges. If that is it, just pull to25% open position and slide the door back on them.
Posted on Apr 01, 2008
Alarm saying racks are in is wrong, since racks are out. Won't allow me to lock for cleaning.
There must be some sort of spring loaded catch at the side or back that registers whether the rack is in or out. Yours will be stuck shut with debris, which is presumably why you are cleaning the oven :>)
Dec 02, 2015 | Electrolux Ovens
My machine has the door lock light on and wont start, the door is locked as i have to press the release to open it!
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.
You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jun 26, 2010 | Hotpoint Aquarius WD63 Front Load...
Oven door won't stay closed
You don't state the exact model but on every oven I've ever fixed this problem on it's a broken door striker catch. Depending on your model, the catch will either be in the oven door or in the oven body; usually they're straightforward to replace but on older ovens spares can be almost as rare as dodo ****. Usually what breaks is a hardened tempered metal spring, so when they're not available as spares I can usually visit a local spring making company and get someone to make one up as a one-off using the fragments of the old one as a pattern. After the catch has been replaced the striker itself (usually a specially shaped pin) may need to be adjusted to engage correctly once more. Undoing the lock nut and screwing it in and out adjusts the depth, and is done after the striker catch has been adjusted side to side or up and down to meet the centre of the striker.
Mar 04, 2010 | Imperial Ovens
Cant get oven door back on
Oven doors are made to lift off for routine maintenance but there might be problems if the spring load hinges are not disabled before pulling the door off the body.
There should be a catch which holds the hinge in the open position but if it is the release position (i.e. the state in which it is in for normal use), the I would expect the hinges to snap into the closed position when the door is removed from the body.
To rectify this, hold each spring loaded arm in the position it would be in the "door open" position and move the catch into the position which prevents the arm springing back when they are released.
It should now be possible to fit the door to the cooker.
When the door is fitted, release the catches.
Dec 17, 2009 | Whirlpool RF3020 Electric Kitchen Range
The cord on my electrolux Epic 6500 has been pulled too far out and will not rewind. How can I access the cord reel to rewind?
There are two keys holding the body together, underneath the bumpers on the side of the vac. With the bag door open these keys when gripped with pliers will slide forward to release the body panels.
Before opening the vac, gently push the cord back inside the housing.
2 possibilities:
If the spool rotates and allows the cord to push in , the body must be disassembled, and the cord winder removed and the spring reloaded. This is tricky work. you will need to wind the entire cord onto the spool, then load 3.5 rotations onto the coil spring for tensioning, then reassemble. It's a bit like working on a land mine of you're new at it. Wear safety glasses.
BUT if the spool is locked from the outside and the cord wont push in or pull out, a fine , long blade screwdriver can be inserted diagonal to the body through the cord slot and with luck you can lift a cog of the spool releasing tension and the rewind will work. try that first , but be gentle . You must release the cord spool allowing a a dog ear catch cog to release inside by gently lifting upwards.
Post back to say how you made out,
Or look for an AERUS Electrolux service shop.
Sep 27, 2009 | Electrolux Epic 6500 Vacuum
Kitchenaide KGST307 cracked inner oven window.
Open your oven door and look at the hinges. You should see a drop down thumb lock on each hinge that you pull down and after you do so, lift up on the door as to close. The door will catch on these thumb locks and then at this point continue to lift up on the door as you pull the door out at the bottom. Reverse directions to reinstall.
Apr 05, 2009 | KitchenAid KGST307 Gas Kitchen Range
Hotpoint aquarius 1000wm 20 I have to bash front door to start
I do not think it is the door lock that is faulty, more likely to be a weak or broken door spring or broken door catch.
I would replace these first,and then if it is still the same, then replace the door lock.
To replace the spring and or handle catch, undo all the screws that secure the 2 halves of the door, and prize apart the 2 halves,
Replace the spring and catch, reassemble the door.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
New Cornu Fe Stove - Oven door pops open
I had the exact same issue with my Cornue Fe (only on the right hand side oven). The other symptom I noticed was that the door itself didn't close as smoothly as the left hand side oven.
Take a look at the alignment of the "post" sticking out from the oven relative to the spring loaded catch on the door. These need to be *very* well aligned vertically in order to keep the door closed as it heat cycles. You'll notice that the post has a depression at the end of it (furthest away from the door). The door catch has an upper and lower spring loaded roller that is supposed to "catch" on both sides of the depression. If you are misaligned vertically, then only one side of the catch will be applying sufficient force to the depression.
In my case, the post and the catch were misaligned by about 4-6mm. In fact, I noticed that repeated opening & closing of the door was actually causing some wear on the upper roller of the catch. To fix, I needed to raise the door, which was accomplished by adjusting the hinges.
I removed the door from the oven, which can be done by removing the screws on the hinges. The hinges consist of a bottom & top knob that slot into the door (similar to the way refrigerator hinges work). The hinges themselves are made of ~1/4" metal (could be stainless, but it's relatively soft stainless). I put the lower hinge in a vise (appropriate covering to prevent scratching) and *gently* bent it up to adjust the door upwards. Putting it back together required some help (the door is heavy), but after a bit of work it was all back. Thankfully the alignment was right the first time. This whole process took about 20 minutes.
In my case, I suspect that either the wife or kids had put too much weight on the door at some point and bent it out of alignment. The problematic door had about 4-6mm of "play" between the top and bottom hinges prior to my adjustment--the working door had zero "play". You might want to check to see if you have any such play before you do this work (you can either look at the hinge itself or simply lift up on the door at the hinge point to see if it moves). If you don't have this same play, but you do have misalignment, then you'll need to adjust both top and bottom hinges.
The other possiblity is that you might have a weak spring in the catch mechanism. You can check that by gently pushing a flat head screwdriver in between the two rollers and feeling for how much force is required to separate them.
Of course, you can also just call the La Cornue service folks and have them check it out.
Mar 21, 2008 | Kitchen Ranges
Replacing the oven door
I just fixed this. Rest the bottom of the door on a rug and push the long arm down by foot, as it is spring loaded it needs a lot of force. Once it is down slip the catch of the smaller arm on to the hook. Both sides will now be the same and you insert the door gently into the oven. Hope this helps.
Harenn
Mar 11, 2008 | AEG B8139-4-M Electric Single Oven
Refrigerators Logo
581 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
