Question about ViewSonic N3250W Television
No audio i believe everything is hooked up fine but i have no audio at all. My cable is run through the hdmi cord so i am even more perplexed. Can anyone help me with this problem?
  • mcpsny Oct 17, 2008
    I have the same problem, Only on the dvd player and saterllite receiver
Hi Have Vizio Flat Screen and a Denon 3803 receiver. The Tv a Vizio 65 Inch flat screen was here. Out of the wall is a power cord and red,blue,green monster cable. Red and Blue is audio and green video I...
Red, Green and Blue cables together typically denotes a component video signal - an Analog, High Definition transportation for video. This cable does not carry audio, you need another cable to hook up audio between the DVR and receiver. You can use either an RCA stereo cable (red and white), optical-audio, HDMI, or a whole plethora of other audio cables. I would recommend optical or HDMI to get the most out of your system.
Jul 16, 2010 | Denon AVR-3803 Receiver
Cable TV blinks on and off when connected to my Onkyo receiver.
I have the same problem.  It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video).  Video and audio cutout is random and drives the family nuts.  I am desperate for a solution.
Mar 21, 2010 | Audio Players & Recorders
Everytime i try to plug the hdmi cord inot the playstation it shoots sparks out and flips my breaker. 2 times, t different hdmi cords...what do i do!? I cant use it..
You might want to try connecting everything unenergised. Shut everything down (turn off buttons on both ps3 and breaker). You may even try unplugging the breaker from the power line. Now connect the HDMI PS3 to TV, audio cables, etc. Energise everything and turn on.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
A ps3 and tried hooking it up with hdmi to the 'vcr' connection on the vs-2 of the bose Lifestyle 48 but i don't get any audio (video is fine). hooked up the ps3 with hdmi directly to the tv and get both...
hook up computer straight to t.v with hdmi cable. then get two aux cables (usually red and white) and run them straight from tv audio OUTPUT to audio INPUT on bose system. them anytime you want surround sound even when your watching tv just press the aux button on the bose system controller. should be perfect.
Dec 27, 2009 | Bose Lifestyle 48 Series IV DVD Home...
No audio
if possible use the hdmi as a video feed and non-hdmi as a audio feed i am not sure if hdmi even carrys sound.45687d7.jpg
Jun 27, 2009 | Microsoft Xbox 360 Console
Lose audio unless projector is on or unplugging hdmi cable from sharp xr-32x projector. works fine when watching projector
Your receiver is sensing the video source. Try using optical, or coaxial digital audio for an input, this may work.
May 11, 2009 | Yamaha HTR-6160 Receiver
Suggestions to hook up HDMI cables
I'd suggest running all HDMI.  I believe your receiver has 2 HDMI in's and one out.  Run the out to your TV and run the components to the inputs on the receiver.  This way the receiver will control the video.  Works good for me!  Hope this helps!
Dec 27, 2008 | Yamaha RX-V663 Receiver
Setting up Cable with HDMI
Yes, the firmware on your hdtv box has an old firmware, I switched my old hdtv box with a newer one box and the problem was solved. It seems that it can't work if your hooking up with DVI to HDMI cable to your receiver to tv. Your hd box must have an HDMI out otherwise it causes problems. I also have rx-v661 and i finally hooked up everything HDMI to the receiver and then to the tv and it was having the problem you speak of. After I switched out the hd box for a newer one everthing worked fine.
May 13, 2008 | Yamaha RX-V661 Receiver
Televison & Video Logo
15 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
