Question about Dryers
Heaters not coming on and heaters live on both sides.
  • Marc White
    Marc White May 11, 2010
    what kind of dryer is this
  • 184 Answers
Posted on Apr 03, 2008
When i turn on my hot water most of the time it is fine but some times the water comes out scalding
You might be experiencing stacking.
Stacking can be caused by crossover
Other things can be in play, for example bad thermostat.
For more information on thermostat replacement, add a comment with information from the label on side of unit.
Label will say if water heater is tank-type or solar-assisted, tankless, and if water heater is gas or electric.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 30, 2011 | Water Heaters
I live in an old building and today there is a strong gas smell coming from my base board heater in the living room. I'm not sure if it is electric or gas. There is water like knob inside of it but there...
The heater you're concerned about is an Electric Heater. So, I'm not sure why you're smelling gas. Is it a rotten egg smell or more of a plastic burning smell?
Feb 25, 2011 | Fahrenheat LFP6152 Halogen Baseboard...
I have a 1999 Jimmy, the heater just blows cold air ownly, temp. knob works but somthin is stuck, the AC work great, but I need heat, where should I be lookin, to make it work right? I live on the west...
Sounds like the heater cor is plugged. I belive yours is under the hood. Look for a set of 3/4 inch heater hoses going into the firewall. Remove the output hose(bottom)and start the engine to see if water comes out of the heater core. If it does, it is a stuck blend door inside the duct work of the heater, which is under the passenger side dash
Sep 25, 2010 | 1999 GMC Jimmy
I live in a 2001 mobile home and my heater come
Please reply with make and model number of furnace. Does the pilot light?
Apr 26, 2010 | Heating & Cooling
Rear window not heated at all i`ve checked fuse all ok
Check for a live feed to the thin metal strips that run accross the screen near the edge (i think the left side is live, but check both sides). The opposite side should have a good earth. the earthing point is underneath the rear shelf behind the rear seats. this shelf can be removed, you will see a wire bolted to to the frame, check it is tight.
Nov 11, 2009 | 2001 Volkswagen Passat
My refrigerator model #hmg6414 will freeze for
if the rear frz back wall frzs up id say you have a defrost problem. 3 things it could be a heater, a defrost thermostat or a defrost timer .
if the unit runs for 2 weeks good then stops and doesnt come back on. id say your timer is bad. usually located behind ref in rear btm.part # 68233-3 roughly 55.00-100.00 depending on were you live. if works 2 weeks good then rear wall freezes up then your heater or thermostat is bad. heater # 61001874 roughly 39.99-69.99 depending were you live and who u use. if defrost thermost part # 52085-29 roughly 29.99-49.99. again depending on who u use. labor between 85-175 .hope this helps you . the heater can be tested if you have a ohm meter touch each end of meter leads to each side of heater if you get a reading on ohms its good, no reading means bad heater thats if the rear wall freezes in back only. defrost thermostat cannot be tested properly.
Sep 16, 2009 | Admiral Refrigerators
Fan relay or sequencer.
If it were the sequencer, the heat wouldn't come on at all but the fan would blow. It's the fan relay but it could be the t-stat again. If you get a power surge when the unit is running, it can short out that portion only but typically, it will short out either the heat or the cool side depending on what is running not just the fan.
Feb 28, 2009 | Better Living SPP High Efficiency...
2000 Jetta Tdi Cold start
most the time they don't. unless you said to. i live in Alaska, and when people buy new vehicles they say they can't put them in. if your not familar with cars than you should have it professionally done. sometimes it can be a pest. on the side of your engine block you should see an indent a little bit bigger than 50cent piece USD. it is a plug. you have to purchase the block heater (which is just an element) remove the plug and VERY quickly put the heater back in. the block heater keeps the coolant warm and is through the coolant duct. all the coolant will immediatly pore out. if it is installed wrong you will have a coolant leak. you should have it done professionally done to avoid future problems
Feb 17, 2009 | 2000 Volkswagen Golf
Knocking noise coming from Whirlpool Gold refrigerator
Mine does it too. I know what it is because I repair them for a living. That is the sound of ice expanding as the defrost heater comes on to melt the frost on the evaporator. The next ime you hear it make a note of the time. Every 8 to 10 hours it will go into defrost mode. The ice box will also quit working for 21 minutes.
Dec 02, 2008 | Whirlpool GD5SHAX Side by Side...
Dryers Logo
115 people viewed this question
Top Dryers Experts
