Question about Canon I960 InkJet Photo Printer
Canon i960 will not print in black ink
I just loaded my canon i960 with new set of canon ink cartridges.
It will print color and shades of gray but no black text.
Anyone experienced this?
Thank you,
Alex
  • 3 more comments
  • Anonymous Apr 01, 2008
    Yes. Today I had the same problem. I replaced the black cartridge, but still no black prints out.
    Dot
  • COgirl8 Jun 01, 2008
    I'm having the same problem -- just replaced all cartridges, cleaned and deep-cleaned several times, and no luck. Help!!
  • dannzann Jun 10, 2008
    Can't get the black to print.  Deep cleaned about 1000 times-still no good.
    Any suggestions?
    Dann
  • Anonymous Mar 21, 2014
    all colors print clearly except black, changed to a new black cartridge but still wont print black
  • Anonymous Mar 25, 2014
    print quqlity not cleared
I use a no. 4 pan head screw to drill a SMALL hole in the top of the ink cartridge, about 1/4" in back from the front edge, so you can reseal it with the screw when done.
Take a small syringe with a short needle and pull the plunger back.
Insert the needle into hole and hold cartridge in place, IN THE PRINT HEAD, while pushing the plunger down to "pressure feed" the ink into the print head.
Reseal the ink tank with the screw when done.
I think the problem stems from the new or refilled ink tank NOT making a good seal with the print head and then there is a vacuum leak at the joint.
I have done this many times with my various Canon printers with removable ink tanks and it almost invaribly works for me.
I also refil the ink tanks IN THE PRINTER rather than taking them out to help prevent the vacuum break between the print heand and the ink tank.
It also helps to use a photo printing program to "print" out a black, red, blue or yellow page (use whichever color you are having trouble with) to help start the ink flowing again as well.
It does not have to be a full 8 x 10 size, just something about 4 x 6 to help reestablish the ink flow.
Posted on Jul 17, 2008
Yep same as above. Black prints very light gray after 5 years of good printing. Tried every test, replaced black cartridges with different brands. Just wondering if somehow you can clean the heads. I'm convinced the black head is almost totally clogged. Does anyone know how to remove the printer heas to do this?
Posted on Apr 23, 2008
  • mexican999 Mar 03, 2011
    I solved this issue by "milking" the black ink..simply remove it, then press it a bit with your figers until it drops 1 drop..., after that it started prnting with strides, then i tried printing one big black circle several times until it came out completely black..now it works!! it also helps performing a deep cleaning, i did that several times, but it didnt work until the milking
SOURCE:
Canon Pixma 3600 I want black & white printing only for documents Question: How do i turn off the colour cartridges for black & white printing only?
The Grayscale print option optimizes the look of color slides for printing on a black and white printer by adding shading. The Pure Black and White option prints your slides in monochrome.
  1. Open the presentation you want to print.
  2. Click on the word File in the Menu Bar.
  3. Select the option Print.
  4. The Print dialog will appear.
example:
sayurisan20_3.jpg 5.In the Color/Grayscale section, choose the Grayscale option to print in black, white, and shades of gray. 6.Choose the Pure Black and White option to print in black and white only. 7.Click on the OK button.
Jun 06, 2011 | Canon Office Equipment & Supplies
Canon mp270 error code 5200
Hello and WelcomeError 5200 is a service error. Follow this solution step by step
  1. With the printer turned on,unplug it
  2. Open the top and bring the ink cartridge holder to the middle
  3. Raise the gray bar and remove the print head assembly with the cartridges in it
  4. Lower the gray bar with the head missing and close the top with the head out
  5. Restore the power,wait till the printer starts
  6. It will tell you to put in the cartridges, Put in the cartridge
  7. Restore the print head, close the top and the printer will resume working
Error will be removed.
If you have already tried all of the above and still you have error then it is probably that your Canon printer is in need of servicing by a service professional.
So go to the Canon Service Center. If you want to get support on Call then
Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
Please rate my solution as Four Thumbs if it was helpful. Thank you for using FixYa
Mar 10, 2011 | Canon Pixma MP270 All-in-One InkJet...
How do I open my canon printer to change the ink cartige?
Step 1
  1. Select the ink cartridge specific to your printer. Canon inks are versatile, so your selection may be as simple as choosing between black, color or a multi-pack with black and color cartridges.
  2. Step 2 Turn on your Canon printer. The switch is generally located on the top right hand side of the printer. Open the printer's lid.
  3. Step 3 Wait a moment. The cartridge carrier will automatically disengage.
  4. Step 4 Put your hand behind the existing ink cartridge and pull the cartridge towards you until it pops out. Dispose of or recycle the used cartridge.
  5. Step 5 Carefully pull the tape off the new cartridge.
  6. Step 6 Position the new cartridge into the cartridge carrier. Make sure it is facing the correct position.
  7. Step 7 Press the cartridge carrier gently until it clicks into place. Some cartridges have indicators to demonstrate that they are properly positioned.
  8. Step 8 Close the printer's lid. Print a test page to ensure everything is working properly. ....plz give feedback..
Nov 15, 2009 | Cannon Canon i960 Photo Printer
Canon i960 won't print black
You'll need a new printhead, once they plug that bad nothing gets them clean again. Make sure the tape is off the top of the cartridge as well
Aug 07, 2009 | Cannon Canon i960 Photo Printer
Canon MP830 printing with interlacing shades of black
your printer cartridge or head unit ink channel (some of color or black ink channel) constipated, you may try:
1) if your ink cartridge is not new, take out the cartridge put the bottom surface touch cleaner liquid(special for ink printer) or water for 1 hr (you can see ink spread water), then set back and test. refill enough ink maybe necessary.
2) still trouble, you need clean print head ink channel to do same thing above, if your print head is separated from the cartridge.
Feb 05, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Jan 13, 2009 | Canon I960 InkJet Photo Printer
Shades of gray printing as brown
does the black do a complete nozzle test print.if not clean several times and try nozzle test again
Dec 26, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Printing in green
Sounds as if one or more colors is out/dry in the ink cartridge. Have you tried a new cartridge or cartridges?
Jun 19, 2007 | Canon imagePROGRAF W8200 InkJet Printer
Canon large format W7200
Check the capabilities of the printer in the manual. But in general- to get black general purpose printers print all colours. This is the normal way to get a black black in the CYMK process. Some printers offer black only as a setting or a special black/monochrome ink. Some specialist ink suppliers[Lycos] will offer a 'black set' that is where the colour carts are replaced with a shades of grey. Where does your printer come in this scheme of things also take a look here www.fixyourownprinter.com
May 19, 2007 | Cannon Canon i960 Photo Printer
Canon I960 InkJet Photo Printer Logo
1,321 people viewed this question
Clive
Clive
old marine
old marine
Ekse
