Fender bassman 200 producing fuzzy tone
When i'm playing through the amp, there is a strong fuzzy tone. occasionally there the signal goes into a wave, quickly going from loud to soft. occasionally it does work properly, producing a clear sound, but the instances where that happens seem to be getting less frequent. any insights would be much appreciated. thanks.
    Problem Solver:
  • 44 Answers
I would check all the connections, try switching different connections making sure it's not the jacks, if that doesn't work, try sending to company if under warranty.
hope this helps
Posted on Apr 01, 2008
Aa16630
What indicates the caps are bad. What does modded or come point to point saying?
Jul 09, 2014 | Audio Players & Recorders
110 volts 220 volts
If not, you can buy a voltage converter
Mar 08, 2014 | Fender Music
Play mac through Fender Frontman amp
Simple: connect the headphones out (3.5mm jack) to the input jack of your fender (6.3 jack). By doing this you will loose one channel so you better generate a mono signal inside your computer before. Electrically this is no problem, nothing will be damaged. Turn the gain and volume knobs down and apply a signal from your Mac. Gently increase gain and volume. Et voila wonderful mono sound through a guitar amp
May 24, 2012 | Fender Frontman 65R 65W 1x12 Guitar Combo...
My H/K 430 amp making a low frequency, very loud white noise that drowns everything out after it's been on for about 10 minutes
My strong, strong guess is that the large filter capacitors on the power supply have come to the end of their life. open chassis and remove (desolder) the power capacitors - large cans - and replace with new capacitors of similar ratings (voltage and uF). This "noise" will be more like a fuzzy tone of 100 (Europe) to 120 (USA) Hertz which are pretty low frequencies.
Jun 20, 2011 | Harman Kardon Audio Players & Recorders
1965 fender bassman. The Bb, B, and C on the E string have a phasing sound.BTW...I'm playing a P-bass thru the amp...
Seems that there are some harmonic distortions.
You can try to swap some tubes (12AX7), there could be just one tube who's messes up your sound.
If there isn't any change off this distortion, you must visit a technician.
Good luck,
Gerard
Dec 24, 2009 | Fender Audio Players & Recorders
No clean tone
Look for bad electrolytic caps in the bypass caps for the power to the preamp stages.
Jun 02, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Humming noise when amp is powered on.
check the heatsink, touch it with your finger feel it ,if you can hold it with in 15 sec, then your power amp. component might be working if not then probably you Power Amplifier IC or transistor is shorted.
May 31, 2009 | Infinity BASSLINK Car Subwoofer
My Fender Bassman 100 amp keeps buzzing.
Part of the power supply is a filtering stage that completes the conversion from AC current to DC. The "cap" is a capacitor that furnishes voltage to help smooth the alternating current that is left from the rectifier stage. These will start to fail over time. While it is a relatively simple repair for anyone that does this for a living, I would not suggest this as your first repair. Expect a parts cost inthe $20 range plus the local labor rate for the entire repair.
Dan
Dec 04, 2008 | B&K AVR-202
Feedback from bass amp
first check capeciter in rectifier stage.
Oct 16, 2007 | 3Com SuperStack II advanced RPS...
225 people viewed this question
 Grubhead
Grubhead
