Question about Onkyo TX-DS474 Receiver
Right channel is out
My right channel is out for both "A" and "B" front speakers. Is this something worth fixing?
  • 682 Answers
Please confirm that connection between your receiver and front speaker is ok(every thing is connected in right place no open cables.
please do setting again and make sure that front speakers are on.
Posted on Jul 07, 2008
I have lost all sound from my left front speaker on my AVR 135 They are Bose spreakers The system is 13 years old. Is it woorth fixing?
anything that works well is always worth investigating for a repair
it could be a simple fuse for that side amplifier, loose , broken speaker wire
have it checked out and then decide if it is worth repairing
Sep 25, 2016 | Harmon Kardon Harman/kardon Avr 130 5.1...
Left speakers do not work
As power amps are just two amps joined together all you need do is identify the left channel and compare it with the right. Ignore any parts common to both channels. The first thing to do is a visual check. If something looks broken burnt, or odd compared with the right channel then you have probably found the culprit. I suspect you could have a power output failure. It might be that the output devices are separate transistors. They might need to be replaced.
By the way just follow either the internal speaker leads or the connections to locate the right and left channels.
Nov 10, 2017 | Yamaha HTR-6130 Receiver
Having trouble with a jvc kdr610. Just purchased from best buy. Hooked up with a gm wiring kit so all color codes are right. The left front channel is ''dull'' I tried switching the speakers from left to...
Well, very common with JVC's to loose channels, JVC's tend to burn out or, skip, or their channels die out. Easiest fix is to replace it with a Sony or Pioneer but if not an option then use the rear left channel to run both left front and left rear speakers. Wire the left front + and left rear + to the solid green rear + wire on the car harness adapter and the left negatives to the green w / black rear negative channel wire. This will be a temporary fix but you need to fix or replace the radio otherwise the speakers will draw aheavy load from the rear left channel of the radio and probably overheat or burn out on you with long time hearing or at high volumes.
Good luck.
Please rate and vote if I helped. Thanks.
Jun 17, 2010 | Car Audio & Video
I have distortion coming out of my front right channel of my AVR
Yes, sounds like your DSP chip has an issue. Not an inexpensive repair if that's the culpret. Around 400-500 to replace the chip. It's an awesome receiver and worth 300-400 in repair, however, a 3800 or 1800 can be had for 600-800 depending where you look. If you need more help, post a comment and I can help you some more.
Aug 10, 2009 | Yamaha RX-V2600 Receiver
One channel not working onkyo tx-sr04
You might have to take a look into the unit, there could be some damage or a bad solder connection on the front left speaker connector at the circuit board, possibly also on any other component (power amp chip / transistors, internal connectors, etc.), also loose or broken wires or oxydized connector contacts inside the unit.
It could be something else as well, but i guess it's worth checking the above mentioned.
Hope you can fix it
regards
3rq8 (Triarcuate)
Aug 08, 2009 | Onkyo TX-SR604 Receiver
Channles are going out one by one. Fixable?
Plug one of those speakers into a different channel. Like if you plugged the center or rear channel into one of the front channels and vice versa. This will narrow down if the actual speaker is bad or the channel on the amplifier inside of the sub is going bad. If the speaker is bad, you can see if AL sells replacements, if the amp is bad, a repair shop will probably charge more to fix it than what it's worth. I use a 5.1 Logitech that goes for $69 that's great. It might be time to check into another setup.
Nov 20, 2008 | Altec Lansing ADA995 Speaker
If one channel is out, the output transistors are probably open rather than shorted. It is possible that there are other problems. If you have no experience with electronics, I would not suggest you start here. This is a simple repair for a shop and should cost about $20-$30 in parts (or less if not the outputs) plus the local labor charge.
Dan
Apr 01, 2008 | Onkyo TX-DS474 Receiver
Red light 2
Probably not, as i said there are no user serviceable parts inside this unit. If the units worth it to ya take it in to be estimated. Good Luck
Jun 13, 2006 | Sony Xplod XM-554ZR Car Audio Amplifier
Onkyo TX-DS474 Receiver Logo
79 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
