Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Mp3 mishap
How do you make the screen on a digital mp3 player that is a small usb portable, work. My screen comes on blue but there are no words...etc... thanks
  • 37 Answers
On this piticular device, it is NOT a screen, merely a way of lighting up to indicate device activity.
You are thinking of a different device, sorry.
Erik.
Posted on May 16, 2008
SOURCE:
When I turn on the tablet it's stuck on the infotmic screen. What do I do?
factory reset it look up the process
you may need to use the companies software and usb too do it
adivce is to fully charge it and then factory reset it
some tablets has a small switch place on the back to poke a pin in
but check with the makers advice first
use google type the model the 'factory reset process'
this will work
Nov 28, 2014 | Sylvania 7-inch Portable Tablet Dvd/cd/mp3...
Im trying to charge my mp3 player on my computer but it wont charge
you facing this problem because your mp3 player do not match your computer/charging plug is not working/your computer do not load that thing.
Jan 06, 2013 | HP Portable Mp3 Player With Micro Sd Slot...
HOW DO I PUT MOVIES ON MY MP3 PLAYER
Hi mary_harbaug
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
Coby is an electronics manufacturer. It offers a wide range of portable devices including portable MP3 players and portable video players. These devices are small and can play audio files, video files, FM radio and display photos. All media can be added to the device easily using a simple drag and drop method on your computer. You can also use that method to delete files from your device. Supported video formats include WMV, FLV, and AVI.
Instructions
  1. Connect the Coby MP3 player to your computer using the supplied USB cable.
  2. Click "My Computer." Select "Removable Disk."
  3. Select the "Videos" folder.
  4. Drag and drop the video files you want on the device into the Videos folder associated with the MP3 player's disk.
Jan 24, 2011 | Coby MP-705 Digital Media Player
How do I charge my 1808L mp3 8gb portable media player
You should have received a short USB cord with your 1808.
First, turn the mp3 player OFF.
Next plug the small end of the cord into the bottom of the 1808.
Then plug the other end into any USB port of your computer.
You should get a popup message saying that your computer has found a new device, if not, after one minute, turn on the 1808.
The mp3 player charges any time it is plugged into the USB port,
Jun 07, 2010 | Eclipse TCH828 Digital Media Player
Player isnt turning on , it flashes blue and turns back off , but theres still a dim blue light still on
Try resetting the device it’s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds
or
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer’s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Oct 31, 2009 | TruTech SMP-1 GBL MP3 Player
Generic chinese mp3 player not recognized by computer
your MP3 player probably shorted. Try to drain the battery and charge it. Hopefully this solves the problem. If it doesn't your mp3 player is probably dead.
May 01, 2009 | Audio Players & Recorders
The screen of my 1gb mach spped lyric doesnt work correctly
probably if u charged it with the charger upside down it overheated and malfunctioned, happened to me and part of the screen is visible
Jan 11, 2009 | Mach Speed Trio Portable MP3 Player
USB Connection Problem
I have the same problem. If you have a large library try letting it stay hooked up for a long time. It seems like it is taking inventory of device then it should work after a while. Sometimes this works. Sometimes I have to unplug then try again in a few minutes.
Aug 31, 2008 | Toshiba gigabeat MES60VK Digital Media...
Not working:
iv also got the same problem with the a215 i plug it into my computer even when playing music and i turns off soon as i plug into the usb drive please help me ?
Nov 08, 2007 | AIGO DIY MP3 Player
My ilo mp3 of 1 gb
no you don't need the SD, its just extra :) let your computer boot up, plug in the USB cord, and you should hear that famous little "bo-dunk!" sound that tells you something just got plugged in and windows freakin' found it. then a screen may or may not come up asking you what you want to do. if so, its pretty self explanatory from there. if you don't want to use whatever it asks for, go to WMP and go to Sync. Add your songs to the list by copy and paste, and it should say its adding the files to the device. also, if you watch the screen of the mp3 player, you'll see it flash "USB Transferring", showing that its gobbling up the songs you're feeding it (in a good sense) lol. After all the songs are copied, boot up the player (you might have to unplug it first) and make sure they work. Sometimes they freeze, sometimes they dont. For me, when they freeze i just get rid of em. I don't know how to fix the freezing, i guess its just a mishap of technology...they're everywhere. Anyways, try this and let me know what happens. hope this helps :)
Aug 14, 2007 | iLO MP3 Player
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
20 people viewed this question
Top SanDisk Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
