Kenmore kill switch
The kill switch on my Kenmore Series 70 washing machine is loose and I nned to replace. How do i get to this part?
Thanks much
  • 109 Answers
It's under the top panel, you must remove the two screws on the control panel (one on each side in the front lower corner of control panel), then roll the entire panel up and over the top on it's hinges. then there are two gold clips (one on each side) that loosen the back from the entire cabinet, stick a flat blade screwdriver in them and they will pop out. theres one plug with three wires in it going to the top re,ove it, then open the lid and grab the top panel and tilt to you about 30 degrees up and slide the whole cabinet away from the base and guts of the machine.
now you can access the lid switch to replace it.
Posted on Apr 01, 2008
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
How do i determine if my switch is working on my kenmore 70 series washing machine
i think there is some problem in wiring of spin and drain. thats y it works only for washing. current stops after washing. or otherwise click below link and check the manual may be its timer problem
http://www.askmehelpdesk.com/appliances/kenmore-washing-machine-70-series-repair-manual-479481.html
http://www.askmehelpdesk.com/appliances/kenmore-series-70-washer-manual-445690.html
Jan 04, 2012 | Kenmore Washing Machines
Hello, Have a Kenmore series 70 (capcity plus).
Note after reading a bunch of information. I went home and removed the hose from the Level Switch and "clean it", if you will and re-attached. Started a load, and bingo bango bongo, it work. Thanks for the insight.
Nov 30, 2009 | Kenmore 22422 Top Load Washer
I got kenmore 70 series. it doesnot spin but it
You have a bad lid switch . This is the piece , the lid actuator piece , goes down onto , in the hole on the top . Try putting a screwdriver into the hole , to activate the switch , to drain the water and to spin the clothes dry enough to remove , until the switch can be replaced .
Nov 26, 2009 | Kenmore Washing Machines
I have a Kenmore 70 series 28741
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82874120+
Go to the section on Top and Cabinet and you should see how the switch mounts to the cabinet.
You'll have to remove the cabinet first.
Please see GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
After you've removed the cabinet, the rest should be relatively easy.
Sep 28, 2009 | Kenmore Washing Machines
Kenmore washer 70 series how to replace belt
The belt is replaced by loosening the tensioner.
then slip it off the pulleys.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 09, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series filled and stopped...
Lid switch problem. Press down on lid and try to start machine. Reply.
Jun 15, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series model #11020712990 won't rinse
The TIMER is what is bad in this case.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Kenmore 20172 Top Load Washer
Kenmore 70 series
INLET WATER VALVE ON BACK BAD,THANKS-MIKE
Jul 06, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
