Question about Pioneer DEH-P3700MP CD Player
Setting time Ican't seem to set the time using the source bottom.
1) Make sure that all CDs are out.
2) Hold down SRC button until radio turns off.
3) Hold the function button down until the clock appears with the hour flashing.
4) Press the left or right arrow to select the hours/minutes.
5) Press the up or down arrow to select the time.
6) When time is chosen, press the function button again to set.
Posted on Apr 06, 2008
1) Press the "function" button repeatedly until clock appears in the display. (The "function" button is the small round button just to the right of the arrow buttons.)
2) Press the left or right arrow to select the hours/minutes.
3) Press the up or down arrow to set the time
Posted on Apr 03, 2008
Where is the 8 digit pin located on the modem in order to set up a wireless connection?
Hi, the 8 digit pin is indicated on the serial sticker of the router. Just look at the bottom part of the router. and you should see the pin numbers.
Thank you for using Fixya, your recommendation is highly appreciated for the free support.
Jul 21, 2011 | Computers & Internet
I bought a Garmin 1450 but Ican't seem to register
  • To register your garmin you connect it to your computer with the mini USB cable
  • Go to www.garmin.com and select your country from the drop-down list
  • Click on the "myGarmin" tab at the top of the screen
  • Click on "Register your garmin product" at the left side of the screen
  • Click on "Automotive" and follow the prompts.
You'll be asked to create a username and password. Keep them safe as you'll need them anytime you want to update your maps.
If you want to set a PIN number on your satnav which it will look for each time you turn it on;
  • Press TOOLS on the bottom right corner of the screen which shows WHERE TO and VIEW MAP
  • Press SETTINGS
  • Press SECURITY
  • Press GARMIN LOCK
It will ask you for a 4 digit pin. Also you'll be given the option to set a secure location. Be sure to do so and use a place that you can get to easily and where you have around 20 feet clear space around you. If you forget the PIN number the only way to remove the pin is to go to this secure location. As the GPS is not 100% accurate when you return to this location the satnav may think you're a few feet out and you may need to move around for it to unlock. This is why you need the space around where you set it.
You can get a user manual from http://static.garmincdn.com/pumac/nuvi_1100_1200_1300_1400_OM.pdf
Jul 14, 2011 | Garmin nuvi 1450 GPS Receiver
Sp4805 turns on by itself, direct tv picture will run for a short while then dorps out. I can't seem to pick a source? I tried my dvd player and it seemed to work normally. menu options are not highlighted...
In the sources menu where you assign sources, the second selection from the bottom is where you enable/disable sources which can inhibit a source/input from working even if it is assigned. Also check mark the auto source enable box.
If the input you are trying to use is not assigned or enabled many of the menu items are grayed out.
A quick fix is selecting the "factory reset" in the menu as the default factory settings are such that all input's are set to work.
Good Luck!
SagerTronics
Nov 13, 2009 | InFocus ScreenPlay 4805 Multimedia...
Ican log into my account but then it will not open my mail it says yahoo not responding.
Try to check if you have security or anitvirus program that is blocking that page, try to open that page from different computer. it seems your computer setting blocking that page.
Thanks for using Fixya
Oct 06, 2009 | Computers & Internet
Sony ericsson 350i (using phone with flip closed)
under settings./calls ,scroll to bottom of page.answer on /off tab set to OFF you can use phone as normal then
Jan 18, 2009 | Lands Phones
Install setting for Clock and Calendar
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/429287552DEHP7900BTOperationManual0328.pdf
Your Owners manual
Setting the date
The calender display adjusted in this mode appears
when the telephone source is selected
or sources and the feature demo are off.
1 Use MULTI-CONTROL to select
Calendar.
2 Push MULTI-CONTROL left or right to
select the segment of the calendar display
you wish to set.
Pushing MULTI-CONTROL left or right will select
one segment of the calendar display:
Day—Month—Year
As you select segments of the calendar display
the segment selected will blink.
3 Push MULTI-CONTROL up or down to
set the date.
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select Clock.
select the segment of the clock display you
wish to set.
one segment of the clock display:
Hour—Minute
As you select segments of the clock display
put a clock right.
Note
You can match the clock to a time signal by
pressing MULTI-CONTROL.
! If the minute is 00 to 29, the minutes are
rounded down. (e.g., 10:18 becomes 10:00.)
! If the minute is 30 to 59, the minutes are
rounded up. (e.g., 10:36 becomes 11:00.)
Jan 01, 2009 | Pioneer DEH-P7900BT CD Player
Ican find the wireless router from ny laptop but i cant connect to it
For clarification, what OS are you using? If you are using Windows 2000 or later, it should ask you for a WEP key and the SSID. Both of these numbers are available on the bottom of your router if it was provide by your ISP (such as with Verizon, Comcast or Time Warner).
Oct 08, 2008 | Computers & Internet
Picture stretch top/bottom for 1080i HD input
First thing to look at would be the source, make sure that this source whatever it may be is set to display a 16X9 format. Your set may simply be showing what it see's and it may be seeing the 4X5 format and giving you a problem
Jan 02, 2008 | Toshiba 57H81 57" Rear Projection...
Pioneer DEH-P3700MP CD Player Logo
315 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
