Question about Car Audio & Video
Audiosonic Tv The red colour on the tv disappeared, that has been fixed and colour is fine now but there is the word factory in the top left corner that won't go away. Since this word has appeared the remote won't work either unless you turn it off and then back on.
Get the guy who fixed the tv to do it
nigel knows everything
Posted on Aug 22, 2008
Try hitting the RETURN button - that is the one with two arrows chasing each other just above the DISP button. This turned off the FACTORY text on my Audiosonic KMC TH68.
Posted on Jun 22, 2008
I have audiosonic colour television KMC TH68. The word "Factory" appear on the top just on the middle.The worse part is that is locked. One symbol like "lock" is on the left buttom in...
finally have a solution for this problem. Finally got my tv back to normal. Try this: Make certain the TV is receiving a signal.
Press in sequence on the remote [MENU] > [6] >[4] > [8] > [3].
[FACTORY] is displayed.
Press the above sequence again to enter [White Balance] menu.
Press the above sequence again to enter [Adjust] menu.
Press the above sequence again to exit service mode.
Dec 09, 2010 | Televison & Video
Colour wierd in corners of screen
do you have any speakers or magnets on top or near the tv.......if so move them away from the tv...thanks
Jan 04, 2010 | JVC AV-20F476 20" TV
Tv gone green/blue and sometimes red in top right corner
If you have a Sony rear projection LCD TV then you have a failing optics block. LCD TV's are not affected by external magnets like CRT TV's were. The optics block issue will only get worse and needs to be repaired by a technician.
Sep 10, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Audiosonic TV - Word "Factory" appears on top left corner
Try pressing the RETURN button (above the DISP button - number 6 on the button list in the manual). The button has two arrows chasing each other. It worked for me on our Audiosonic KMC TH68 TV.
Apr 02, 2008 | Televison & Video
26PF5521D wont show menu after reseting factory defaults
Switch the TV to analogue mode (if possible)
Press and hold the "MENU" button on the side of the TV. The settings menu should appear. Continue to hold the menu button until this menu disappears. (If you let go before the menu disappears, start again)
The TV should now go blank for up to 2 minutes, and then revert to factory settings and intitial installation screen.
Procede as per original installation.
Oct 26, 2007 | Philips 26PF5521D 26 in. HD-Ready LCD...
Wharfedale TV/DVD combo
Contact agent for the unlock code.
Menu and 4 digit code unlocks factory default.
Problem is caused when wrong sequence of keys on remote is pressed, part of parental control.
Oct 15, 2007 | Televison & Video
32" Zenith Television
This is due to electromagnetic field affected in the corner area. Check whether there is any magnetic components in surrounding area if found keep away from TV. And then switch off the TV and remove the mains plug also. Switch on the TV after 30mins. The colour will disappear. Even you got the same problem call technical person. Because the decaussing section is not worked.
Sep 05, 2007 | Apex Digital AT2008S 20" TV
Car Audio & Video Logo
150 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
