-   I have the same issue.
There's no way a flat head screw driver fits in there, definitely not 2 of em (I tried, and I have really little flat head screw drivers meant for eyewear repairs).
Also I tried toothpicks, but they aren't strong enough. The SD card is really stuck in there, ductape doesn't work either, I just keep pulling the duct tape out without the SD card. The damn thing is really lodged in there, and it won't even move.-   aerh
May 09, 2009
-   Hey,
My friend insert a PSP memory card inside my laptop's memory card space. The space where u can insert handphone memory card and stuff. The thing is, she did not use the adapter and it's now stuck inside. I tried taking it out but its too deep.
I tried to switch on the laptop. It says " Pls remove ... " that sort of stuff. Do u think it is possible to remove the memory card stucked inside if i send the laptop for repair? Will any files be deleted? Pls help..
-   rasyidah21
Apr 06, 2009
-   SD CARD IS STUCK IN FRIENDS SATELLITE LAPTOP. IS THERE AN EJECT BUTTON ANYWHERE ON THIS BEAST? -   sftsand
Mar 16, 2009
-   tried everything so far still stuck sd card toshiba laptop -   pettitl
Jan 07, 2009
-   SD card is stuck in the microSD drive. It's really annoying. I've tried any object I could to get it out... but it's so far back there...
It's been in there for months.
I'm running a Toshiba laptop.-   psychospath
I had the same problem, read some of the proposed solutions and came up with one that worked for me! Here it is: (1) cut a piece of duct tape that is about half the width of the slot and a couple of inches long (2) use a small flat head screwdriver and depress the card down, so that a small gap is created above the card (3) take a second small flat head screwdriver and force the tape into the gap above the card - adhesive side towards card (4) continue to work the tape into the gap so that it covers as much of the card as possible (5) remove the screwdrivers and gently pull on the tape until the card is removed!
[Use] a piece of thick paper cut into a long rectangle finger. I slide
this underneath the card with the other end sticking out. You can
then angle your laptop until it just slides out. If that doesn't work
you can use a bit of sticky tape. Hold one end and try to stick the top
of the MS then gently pull out (the other piece of paper is still
underneath).
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area...
(More)
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area but
I have been getting this error: Error Message: PXE-E61 Media Test Failure Check Cable I have done...
(More)
I have been getting this error: Error Message: PXE-E61 Media Test Failure Check Cable I have done all the usual things, changed the boot order and made the hdd primary. I disabled the network adaptor boot from the bios set-up and checked that my hdd is recognised in bios setup and it picks up the wdc rom model scorpio --- (pm), so this means the hdd is working but when i save the changes and reboot all i get is a black screen and it does not boot anything. could anyone help with this? i have a compaq presario m2000. thanks.
ATT replaced my DSL Router with a Netopia 3347-02. Now my home network does not work. Can not see...
(More)
ATT replaced my DSL Router with a Netopia 3347-02. Now my home network does not work. Can not see any other of my 3 computers from each other. Is there a settig i need to trun on?? I am using DHCP from the Netopia.
SD card is stuck deeply in the card reader bay of my Compaq Presario 3000 laptop. I can't pull it out with tweezers as it is too deep in a very narrow slot. Pushing on it with a long narrow screwdriver doesn't cause it to pop out as is normal with my other devices. Laptop reads the SD card fine, but obviously can't reuse that in the camera it came from and it prevent use with other SD cards while still stuck there. Next attempt will be to take out tiny screws int he base and see if I can access the reader internally.
