Question about Car Audio & Video
HYUNDAI SONATA CLUSTER LIGHTS QUIT
THE CLUSTER LIGHTS QUIT AND AFTER MESSIN WITH THE RADIO WIRING THE LIGHTS CAME ON FOR A MINUTE THEN BACK OFF AGAIN
    New Friend:
  • 113 Answers
You probably wired the dimmer control wire from the car to either a power wire(red or yellow) to it or you wired it to ground- unplug the radio and look for a bad fuse in the car's fuse block- if the lights come on after unplugging the radio your fuse is okay and you have the dimmer control wire wired to the wrong wire
Posted on Apr 02, 2008
SOURCE:
How do U replace dash lights on 09 Sonata?
take off outer trim molding usually clip on or few screws and that should open up to mounting brackets or more screws to the instrument cluster. once you have the instrument panel or cluster out you should see access to the lights.
Sep 27, 2014 | 2009 Hyundai Sonata
I NEED A RADIO WIRING DIAGRAM FOR A 1998 HYUNDAI SONATA 6 CYL
hope this helps http://www.modifiedlife.com/1998-hyundai-sonata-car-audio-wiring-diagram/
Feb 20, 2013 | Hyundai Motor 1998 Sonata
What would make my 2004 Hyundai Sonata run hot when i stop at red lights drive throughtsect but cools back down when i start driving again
my 2003 just stopped running as i made a left turn everything works on it lights alarm ect it just wont start now it trys but wonk and one can help please and thank you
Jun 30, 2010 | Hyundai Motor 2003 Sonata
How to remove 2001 hyndai sonata audio system
Instructions
Things You'll Need:
  • Screwdrivers
  • Wiring harness adaptor
  • Hyundai radio adaptor kit
  1. Open the coin holder and remove the two screws at the front. Pry the trim from around the gearshift lever and unhook the power wire to the cigarette lighter.
  2. Locate and remove the two screws from the bottom of the radio trim panel. Look for the screws, attached to a rod, below the glove box. Unhook the cable from the rod and pull the rod free.
  3. Place the shifter into "D" and slide the radio trim panel away from the dash. Locate the four screws at the front and sides of the stereo and remove them.
  4. Pull the stereo out of the Hyundai Sonata dash and disconnect the wires from the back of the unit. Connect the wiring harness adaptor to the original harness.
  5. Slide the new head unit into the Hyundai radio adaptor kit. Attach the wiring harness adaptor and antenna wire to the back of the new head unit and push the entire assembly into the dash.
  6. Secure the stereo in place with the four front and side screws and turn it on. Verify all of the speakers and features are working. Reattach the radio trim panel, insert the rod back into cable assembly and secure the trim around the gear shift.
In here you can find tips about remove radio...
- Hyundai Car Stereo removal
- Stereo Removal Hyundai (buy)
I really hope help you with this (remember rated this help). Good luck.
Oct 01, 2009 | 2001 Hyundai Sonata
I need help with a wiring layout for a stereo.
Forget it...go to a car stereo installation shop and buy a wiring harness for your car ($20-40) and you're done!
Good Luck
P.S. might as well buy a dash kit ($30) to make installing the radio simpler as well...if you DON'T have a car stereo shop nearby, order parts from crutchfield.com
Jun 23, 2009 | 2007 Hyundai Sonata Limited Sedan
2000 Sonata - Radio quit working
you need to go to the Hyundai service center they can reset the radio I believe this is a security feature, you may be able to call the service center to find out the procedure to reset the radio, it is the original right ?
Apr 07, 2009 | 2000 Hyundai Sonata
04 sonata stereo wireing diagram
Battery ORANGE (+) RADIO HARNESS
Accesory YELLOW (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
LF Speaker (+) BROWN/WHITE
LF Speaker (-) BLACK/WHITE
RF Speaker (+) BROWN/YELLOW
RF Speaker (-) BLACK/YELLOW
LR Speaker (+) BROWN/RED
LR Speaker (-) BLACK/RED
RR Speaker (+) BROWN/WHITE
RR Speaker (-) BLACK/WHITE
Jan 01, 2009 | 2007 Hyundai Sonata Limited Sedan
Lost car radio code
i need a radio code for 1995 Hyundai Sonata radio v#kKMHCF24F6SU446697 thanks
Aug 15, 2008 | 1999 Hyundai Sonata
Car Audio & Video Logo
132 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
