No output from my receiver
Lights go on, all looks good, fuse is good, but nothing to the speakers. Is thgis worth fixing, is it a "tube" receiver, or just junk it? Nay ifo is helpful, thanks! sansui solid state 200 vintage receiver
    Problem Solver:
  • 44 Answers
Some of the older radios are worth money, seeing how they are antiques, so I would research yours, make sure how much it's worth, check tube prices, try to find one on ebay or some other place, and repair it, because chances are it could be worth money.
hope this helps you out
Posted on Apr 01, 2008
Blown 2 8a 125v fuses, replaced them and blown them again. I used this stereo for 10 years without any problems Can this be fixed, I threw away the last one with the same problem. The tech said it was...
Yes it can be fixed you have a short in one of the output channels. Probably needs two transistors. If you keep putting fuses in it will need more. You are looking at $100 to $125 for the repair.
Feb 12, 2011 | Sony STR-DE835 Receiver
When connecting my speakers one side of the receiver is not working any suggestions?
You have a bad output transister in receiver this is common for the 2 channel Sherwoods. Not worth fixing if your not inclined in the electronic field. It will cost more than the receiver to fix. Sorry for the bad news Good luck.
May 24, 2010 | Sherwood RX-4105 Receiver
Have a str-de 945,unit was working,sound stopped,still powers up.Replaced 2, 8 a fuses,blew again,nothing was connected to the unit.The heavy power supply unit in the front seems to have a hard orange...
Chances are you have shorted output transistors,check with ohm meter across all 3 legs,there should be no shorts if good.. cost on average around 150.00
Apr 16, 2010 | Sony STR-DE945 Receiver
I think i fried the power supply shorting against the chassis.. is it worth trying to fix it? touched bare speaker wire to chassis while it was on...
What leads you to think you fried the power supply in your unit? While touching the speaker wire to the chassis is never a good thing it should not have fried the power supply. Might have opened a fuse in the speaker circuit. Have you checked all the fuses yet? Try that first and get back to me and make sure the unit is unplugged before you open it up!!!
hardrocko
Feb 05, 2010 | Onkyo TX-8211 Receiver
Blown Stereo Receiver
If the output transistors are shorted they cause burns on the resistors and even even blow the AC fuse and your receiver will not come ON. I used to enjoy fixing, these AMPs this was many years ago. Any how, repairing this unit will be more than a $100.00 my advice to you is BUY a NEW 1.
Good luck
N Sabre
Nov 08, 2009 | Sony STR-DE535 Receiver
No sound out of left speaker
did the left channel work when u switched speakers, if so then the left speaker or wiring is a fault.if not then the output circuits on the amp are blown or the fuse is blown some amps have internal fuses in the output to protect the output transistors. unplug the power cord and take the cover off, look to see if u can find any fuses and check these for continuity u can hold these up to the light and u should see a fine filiment in one piece and not broken. these fuses sometimes blow just from age and use at high volume like a regular light bulb.If the fuse is blown replace with the same value else the output transistors will need to be replaced most likley along with the drivers.
May 19, 2009 | Sony STR-DE135 Receiver
Accurian AVR 31-5048 6.1
I power on the reciever and then it reads PROTECTION and then powers off. I initially thought that I blew out the reciever but I was wondering if it was as simple as a fuse. I can locate the product manual for this reciever.
Oct 29, 2008 | Accurian AVR-5048 Receiver
Channel mixer problem- No channel B output.
Probably time for an upgrade to a newer channel mixer. Your mixer is probably not worth fixing, but you could continue to use the mixer side for a while until you decide to upgrade that. If you happen to know an electronics tech, it could be a little project to check the power amp insert jack on channel B, but it wouldn't be worth spending good money after bad when you could put it towards more solid gear.
Good luck.
The dude.
Aug 07, 2008 | Peavey 32fx USB 32 Channel Mixer
JVC RX-884VBK RECEIVER
The JVC RX-884VBK is a great machine, I had it for over 5 years and had no problem at all. I came across the (NO SOUND at all) and I believe it is an easy fix. Check the Front left, there are 2 keys marked 1 and 2 for SPEAKERS output, sometimes you don't notice that you connected the speakers to 1 and the 2 key is pressed. You could have both keys pressed and you will get the sound. I hope that helps.
Nov 29, 2007 | JVC RX-884V Receiver
98 people viewed this question
 Grubhead
Grubhead
