Question about Canon PIXMA iP1600 Printer
Lexmark 29 ink cartridge
Can you reset these cartridges so the printer will use them after refilling them?
reset cartrige
  • Anonymous Apr 13, 2008
    Tried interchanging old with new and vice versa but did not work.Have now powered off the printer and removed the cartridge.Shal reinstall after 24 hours and see if I can fool the printer.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Is this still a current issue?
Posted on Aug 20, 2008
SOURCE:
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    I have a Lexmark x5470 & I get an error unsupported cartridge
    Ink cartriges have chips in them, if the printer does so many prints without getting the "I've had a new Original Cart fitted" it will stop untill,you give it one, regardless if there ink or not
    Im afraid it doesn't care that you only need to use the colour cartridge, it is designed to cost you money and make money for lexmark not refillers.
    Welcome to our modern world, manufactures make the ink hard to recycle by incorperation of expensive chips that makes refillers, unable to make a easy dollar, because if that want to make cartridges that work they must also fit the expensive chip.
    All empty cartridges have a little ink left in them because getting air in ink lines is not a thing we want.
    Nov 07, 2009 | Lexmark X4270 All-In-One InkJet Printer
    Where do you insert the ink cartridges on lexmark x4650
    These are the instructions for X2500 Printer
    1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
    2.Open the top portion of the printer to reveal the ink cartridges.
    3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
    4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
    5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
    6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
    7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
    8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
    Oct 25, 2009 | Lexmark X2500 All-In-One Printer
    Hi i have a lexmark x5650 printer, i have just refilled the cartriges and it wont recognise them keeps telling me to replace them, any ideas any one ? neil.
    I had same problem. I unplugged the unit, took a pink pencil lead and lightly cleaned the contacts, put the ink back in the plugged unit back in and it worked.
    May 01, 2009 | Lexmark Office Equipment & Supplies
    I just refilled the cartrige, but it says the ink is low, My printer brand is Lexmark2400.
    You may have a non refillable cartridge.
    Lexmark has an interesting development with their inkjet cartridges which they began some years ago with toner cartridges. A court decision required Lexmark to allow their cartridges to be refilled. However, Lexmark would naturally prefer that you only buy from Lexmark. Thus, Lexmark has developed the following system:
    • Lexmark offers for sale two different versions of the same cartridge:
    • The regular version (#23, #24, #28, #29, #41, #42) is not refillable. It is the "Return Program" or "Prebate" cartridge. Supposedly, when you buy this cartridge you agree to return the empty cartridge to Lexmark. In return, Lexmark gives you roughly $5 off the retail list price of the cartridge.
    • The "A" version (#23A, #24A, #28A, #29A, #41A, #42A) can easily be refilled. However, the price of the cartridge is roughly $5 higher than the regular version, so most people unknowingly buy the regular version.
    Jun 23, 2008 | Office Equipment & Supplies
    Ink levels on lexmark z1300
    I bought this same printer and after trying numerous things to refill the cartridges (which are detailed at fixyourownprinter.com), I have concluded that if you are using black cartridge #28 and/or color cartridge #29 you cannot refill because these are the "return program" cartridges. These specific cartridges cannot be refilled and technically any attempt to refill them is against Lexmark contract which you agreed to when you opened the sealed bag the cartridge came in.(Dont believe me? check the bag) I think the bag also said that there can be criminal charges filed against you if you refill these cartridges but I seriously doubt that lexmark would go after you since it has never happened before. My recommendation is to purchase the more expensive 34 and 35 high yield cartridges which I believe but cannot confirm will let you refill. What did you expect from lexmark? This printer is sold at a loss and do you really think that they would sell you a printer so darn cheap and not expect to make that money back somehow? These printers are usually picked up by cheapskates (such as myself) who have no intention to buy any more cartridges other then the initial one. Well ive learned the hard way that lexmark as well as other printer companies are now fighting back. If you want cheap ink I hear that KODAK is selling a printer that is a bit more expensive then the other brands but has very cheap cartridges. Oh and If you did buy the high yield cartridges then please reply so I can update the thread on fixyouownprinter.com and let everyone know.
    Hope this helps makes things a bit more clear. Thanks for reading!
    Mar 27, 2008 | Lexmark Z1300 InkJet Photo Printer
    For the record the lexmark 29 (18C1429) cartridge is a one time use cartridge (return program cartridge). If you want to get a Lexmark 29 cartridge that you can refill you must buy the 18C1529 Lexmark 29 cartridge. This cartridge can be refilled and reused. The catch, you can only buy this cartridge from Lexmark.com new. I know of one company that sells the remanufacture Lexmark 29 (18C1529) yourinksolution.com.
    Feb 07, 2008 | Office Equipment & Supplies
    X5470 Lexmark printer
    i refilled my lexmark 24 color cartrgide but now the printer does not want to read the cartridge, any help on resetting the thing before i chuck it trew the window
    Nov 12, 2007 | Lexmark X5470 All-In-One InkJet Printer
    Canon PIXMA iP1600 Printer Logo
    71 people viewed this question
    Clive
    Clive
    old marine
    old marine
    Ekse
