Viewsonic airpanelv150 after being online wirelessly.. for 10 to 30 minutes it looses the connection.. we have to reboot.. to reconnect.. what do you suggest.. thanks mark
  • 180 Answers
Reinstall and reboot. try and wait to see.
Posted on Apr 20, 2008
Was having problems w/ internet connection. Brighthouse tech just left. Replaced modem and fixed a loose wire at box outside. Still won't hook to wireless and says that it is probably my router
If you have a separate modem and router turn both off and reboot only modem till all lights up the reboot router till all lights up in that order sounds simple communication problem between router and modem. If router modem combo unit disconnect either dsl or cable from router/modem leave diconnected for a short time then reconnect and reboot till all lights up. Hope this helps.
Sep 01, 2012 | EnGenius ESR-1221 EXT Router
My lexmark x6650 printer will not connect back online
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. If your printer is connected via USB cable to your computer, simply disconnect the printer from your computer, reboot your pc and unplug/re-plug the printer into the power source to reset it. When everything turns back on, reconnect the printer into the pc. Wait for the computer to fully recognize the USB connection. Try to print again.
If you're printer is wirelessly connected to your computer through your wireless network, please refer to this article for a more comprehensive instructions on how to identify and fix the communication problem - Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products
Jul 06, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
I just rebooted my toshiba laptop and when i connect to the wireless router it says local only however when put the wire in from the moderm it conects fine i neeed help straight away thanks
Try unplugging both the router and the modem for 2 minutes, then plug them back in. Wait for another 2 minutes and try to reconnect to your wireless network. This usually resolves the problem 99% of the time.
While you wait check all the connections to your router and modem.
Regards.
Apr 19, 2011 | Toshiba Computers & Internet
WRT120N---I keep having to disconnect my linksys, unplug all 3 wires on the back of the router, wait 30 sec...reconnect the router...try to get online...when it works then reconnect the linksys....what am...
Please disconnect and internet link and try to access the the Linsys WRT100 management page and see the logs why the router is loosing the connection. If you dont get anything then it might be some issue on the device. A reset may solve your issue.
Please be aware the if u reset the wireless Router you will loose all your configuration and you have to reconfigure the wireless Router.
Please press the tiny black button at the back/beneath of the wireless Router and keep pressing for 2 minutes. The sys light will start blinking slowly and then rapidly. then release the button and wait for 2 minutes for the device to boot up with factory default settings.
Once you are done you can connect to 192.168.1.1 ip address and it will open the your Linksys Router management web page where you can reconfigure your wireless router again.
Hope this will fix the issue.
Best Regards
Jan 01, 2011 | Linksys RangePlus WRT100 Wireless Router
What does it mean when the far ethernet light is flashing fast and the cable light is flashing slowly. the power light and on line light are on steady. I have internet access when connected direct to...
Try this:
  1. Disconnect power to modem
  2. Disconnect power to router
  3. Shut down PC
  4. Wait 2-3 minutes
  5. Reconnect power to modem, and wait ~ 1 minute
  6. Reconnect power to router, and wait 30-60 sec.
  7. Reboot PC
  8. Try to reconnect to internet...
Jan 15, 2018 | Arris Touchstone 450a (CM450) Modem
It wont connect to internet on wireless,ive enabled wireless
The wireless drivers may be corrupt.
This method will hard reset the wireless drivers back to default settings, but before you perform this remove power from the modem and router for 2 minutes reconnect power and wait another 2 minutes for them to settle down.
Right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "uninstall" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again. Also please remember to turn on the switch or use a keyboard toggle to turn on the wireless radio.
Good luck.
Nov 17, 2009 | Asus Eee Pc 701Sd Notebook
Connected to wireless network, but cant browse internet.
I think there might be lost in the packet sending.
You said the PC is still connected to the network but not able to go online.
Is there any other wireless computer which is able to go online wirelessly and working fine.
If yes then try to uninstall and reinstall the adapter.
If not then check the router wireless settings.
Click Here for more info about networking.
Oct 08, 2009 | Computers & Internet
I can only get a local connection when connecting wirelessly and cannot connect to roadrunner if i connect the ethernet cable
Good luck.
Aug 20, 2009 | Toshiba Satellite L305-S5921 Notebook
Wireless USB fails after 5 minutes
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your laptop may have problems from the broken parts or damage to your Windows/OS.1st will check the parts may be possible the start of problem. This are only two parts, 1st is the memory clean net connection small feet, 2nd try to fix windows / OS by re-formatting the Hard Disk with OS CD..Good Luck
Jul 16, 2009 | Dell 1450 (D1450U) Wireless Adapter
Keep losing wireless network on laptop. completely disappears and can not find it to reconnect
Hi..
I was having the same issue with my notebook. I was losing connectivity to the internet at both home and office through my browsers and outlook consistantly after boot up for approximately 10 minutes. The only way to get more connectivity was to reboot my machine (ten more minutes). Emachines help desk was no help. Their fix all response was to format the harddrive and start over. What I did to fix it was:
Start
Control Panel
Network Connections
There, I disabled the wireless network connection and waited for the hourglass to go away. Then reenabled it and have had wireless connectivity since.
Good Luck ;-)
Dec 04, 2008 | Computers & Internet
Computers & Internet Logo
341 people viewed this question
David Payne
David Payne
