Question about Dacor Preference RSD30 Gas Kitchen Range
Control Panel Problem
My control panel will occasionally show an F0 error message (touch pad stuck in depressed position), and t other times will beep many times with no error message. I do not want to replace the control panel ($400) as others have done this and the problem reoccurs. Can you offer any other advise?
  • 26 Answers
Sounds like a membrane issue and I would certainly call dacor corp and maybe they will assist in the costs. That is if you provide repeated service part replacements.
Posted on Apr 01, 2008
Getting error code F0 during oven cool down. During F0 keypad does not respond to clear error, however after waiting several hours error can be cleared. Next use is fine but error reoccurs during cool...
F0
Stuck touch pad Usually means that either the touch pad or the oven control
(also called clock or ERC) is defective and needs to be replaced. If this fault
code cannot be cancelled, replace the oven control (also called clock or ERC),
touch pad, or both.
Jan 31, 2011 | GE Profile JGS968 Gas Kitchen Range
I need Please a solution to F1 Error Code on GE/Kenmore electric ovens Model # 911.4658815 Thanks E-mail: elylimo@gmail.com I have the same model number. 9114658811 and plugged in the stove for the...
To my understanding error code F1 would indicate a faulty control board, possibly thermistor control. The only recourse is to have this replaced.
This of course would require a fair familiarity of electrical/electronic components/circuitry and safety procedures, use of a DVM and possibly a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 13, 2008 | Kenmore 46123 Stainless Steel Electric...
I keep getting an F0 error code on both ovens
F0
touch pad, or both.
Dec 29, 2010 | GE WPSF5170W Profile Performance
Dacor oven code FO means keypad is in depressed mode.....and then what?
Hi john56584,
The "F0" error code description is a stock function key. Here are basic test that will help you to determine if the ERC or touchpad is defective.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the code comes back.
7. If F0 comes back, replace the ERC. If it does not, replace the touch pad.
Hope it helps.
Sep 01, 2010 | Dacor Preference RSD30 Gas Kitchen Range
What does an error message "F0" mean for kenmore model 911.41185991?
for a maytag the F0 code means a function key is stuck, and recommends changing out the touch pad, or touch pad and oven control assembly if one unit. google your model number for error codes.
Jun 21, 2010 | Ovens
Does F0 code mean changing touch pad is fix & how to do that?
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Nov 27, 2009 | GE Kitchen Ranges
FO error message. Oven light stuck on. No buttons work.
The F0 is a Function Key Stuck error - Replace touch pad or touch pad and control board if it is one assembly. Refer to F1 Test for more information.
How To Perform A F1 Touch Pad / ERC Test
This test is easy to perform and will help you determine whether the Electronic Range Control (ERC, control board) or touch pad is defective when the F1 code is displayed.
Note: With some models, the ERC and the touch pad are one single unit and therefore this test is not necessary. The entire assembly must be replaced.
Warning: If you have any doubts in your ability or safety of the repair, please contact a qualified appliance repair technician.
1. Disconnect the power to the range by either unplugging the power cord, or turning the power off at the circuit breaker. Always make sure the power as been disconnected properly before beginning this test.
2. Access the control panel.
3. Disconnect the touch pad ribbon from the ERC.
4. Reassemble the control panel. Make sure to check for any additional defects such as frayed or lose wires that could be causing the problem.
6. Wait up to an hour for the F1 code to reappear. This could be accompanied by an alert such as a beeping sound.
7. If the F1 code reappears, replace the ERC. If it does not, replace the touch pad.
Nov 06, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
Jun 20, 2009 | GE JKS05 Electric Single Oven
The oven controls are not working. then FO shows
If your appliance is newer than 1996 F0 error code is a stuck key pad .
To verify turn off power and access the control panel and remove the ribbon connector that goes from key pad to control board .
Now restore power.
If the F0 code goes away you'll have to replace the key pad .
If it stays it means the control board is bad.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 11, 2009 | GE 30" Built-In Single Electric Convection...
Oven display not working
Hi iron451,
Hope it helps.
Mar 16, 2009 | Dacor Preference RSD30 Gas Kitchen Range
Dacor Preference RSD30 Gas Kitchen Range Logo
324 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
