Question about Canon Powershot SD450 / IXUS 55 Digital Camera
My camera wont even turn on
I go to the mall and movies and im taking pictures and then i put it away and my friend wants to take a picture and my camera wont turn on at all when i try to turn it on i have no clue on what to do
  • 4 more comments
  • MikeK128197 Apr 02, 2008
    i tried that and it still didnt work thanks for trying i appreciate the help though if i were to go get it fixed do you have any idea on how much it would cost? or would it matter on if the part was messed up?
  • MikeK128197 Apr 03, 2008
    umm im not sure i dont know much about cameras but on the sticker it says canon pc1158 dc4.3v made in.. yeah then the serial number
  • blueray123 Apr 09, 2008
    My camera wont turn on either. One day it was working fine and the next it didn't want to turn on. I bought a new battery but it didn't work either so I don't have a clue about what is wrong with my camera.
  • MikeK128197 Apr 10, 2008
    Yeah I tried that once before and just tried it again. It didn't seem to work.
  • lucille1 Jul 08, 2008
    my camera won't turn on
  • dhc421 Mar 19, 2009
    I have the same problem with the camera not powering up. I have 2 batteries which are fully charged. I check them with a meter and it reads 4.1v. Now I did read one of the solutions about the little tab on the battery door which breaks off causing this problem. I notice on my camera that tab is broken. I checked the little opening where the tab goes into and I do not see the tiny spring. All I see is just a hole with nothing inside. How can I repair this? Or this has to be sent in for repair? Does anyone know how much it will cost? Is it even worth sending it in for repair? Thanks in advance for any help.
  • 22 Answers
Try this: with the battery installed and battery door open, take a pencil, fine tip screwdriver, or anything long and skinny and push the tip of it into the little nub circled in the picture here. There's a spring inside that little nub... keep the spring depressed and try to turn on the camera. If it works, then either a small piece of plastic broke off the battery door or the nub got broken/pushed in too far for the battery door to trigger it. Try using a dab of hot glue to keep the nub pushed into the down position.
Posted on Apr 10, 2008
  • Michael Kaskey Apr 17, 2008
    Do you feel comfortable opening up your camera? How good are you with a soldering iron? There's a tiny fuse inside the Canon SD series cameras which, if blown, will cause the camera not to power up. Sometimes soldering a jumper wire to the two legs of the fuse will get your camera to power up again, but the fuse is literally about as big as this equals sign: =
    If you feel comfortable about opening up your camera and confident in your soldering skills, let me know and I'll go into detail about where to find the fuse, etc.
Solution # 3 posted by MeKiwi regarding the little switch behind the battery door was right on for my case. My is a Canon IXUS 55. At one point, I could not turn it on with a fully charged battery. Only after I pushed that little flap shown on the picture with a red circle that it turned on right away. After one more power cycle, the little flap disappeared, and a little spring came into view. My camera is now back in operation. Good tip! Thanks.
Posted on Jul 31, 2008
I sort of have the same problem, that is pushing on the on button flashes momentarily and the lens pops out a fraction then quits. The screen is blank and pressing on the on button again may retract the lens (which is out just a fraction) or not. The odd thing is that if you press on the display button while turning the camera on, it stay on and the screen goes to set the time. Pressing the menu button takes you to the use of the camera and it works, takes pictures and otherwise seems to work ok in this fashion. The problem is that it will only go on this way, and also nothing gets saved in memory. Setting the date and time, then setting it turns the camera off, then you have to go through this all over again. I think something came lose, or the connection to the internal memory must have gone bad, or perhaps the internal memory itself will not save anything thus for this problem. I don't know if anyone has run into this problem when you say your screen is blank or not, perhaps there is a solution to this problem that I am not aware of, thanks...
Posted on Jul 27, 2008
Where is the Fuse?
Posted on May 10, 2008
  • 477 Answers
Remove the battery for 24 hours make sure it is charged after 24 put the battery back in and see if that does the trick some times this works. hope this helps.
Posted on Apr 01, 2008
  • Mike Johnson
    Mike Johnson Apr 02, 2008
    whats the model number?
When I put it on M mode or auto mode it takes really horrible pictures, can't even see the picture, real bright.. When I put it on movie mode it takes great pictures but that is not good.
Usually when it is on M mode there is additional options you can adjust "manually" for good shots... It could just be that the options are adjusted not for the type of Pics you intend to make. Ex. It's set on low light when you are trying to take a high light exposure picture.
Apr 01, 2015 | Samsung Digimax S500 Digital Camera
My Powershot SX10IS will no longer take pictures. I don't know why.It turns on and the picture shows in the viewer, but when the button is pressed to take the picture nothing happens. There is a movie...
The movie camera icon means that you have put it into video mode. I don't know how you do or undo that on your camera, but on my Canon there is a slide sitch that selects still shots, video clips, or review pictures taken.
Nov 18, 2010 | Cameras
Wont take pictures
well , ive got exactly the same camera , and basicly when i take a picture i just press it down all the way , it seems to work for me and my friends who have the same camera
Dec 26, 2008 | Kodak EasyShare C713 Digital Camera
A630 clicks and wont take picture. Stays in preview mode.
Do you mean you are expecting it to show the photo that you just took for a few seconds before it goes back to preview mode? There's a menu setting which I think is called "Picture Review" and you can set it for something like 0, 2 seconds, 5 seconds, something like that.
I hope that was it.
-Vince
Oct 01, 2008 | Canon PowerShot A630 Digital Camera
Sanyo s650
put duracell batteries in it it will work mine did the same thing when i first got it
Jul 19, 2008 | Sanyo Xacti VPC-S60 Digital Camera
Photos are cloudy when taking pictures outdoor and some instances on indoor.
I had the same problem, but all of a sudden it went away. Did it go away for you yet?
Jun 17, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
How do I get out of Movie Mode?
Unfortunately it sounds as if that camera will need to be sent in for service. Call Tech Support at 1-800-828-4040 to do a little troubleshooting and get your possible repair options.
Hope this helps.
Sincerely,
HeavyDLB
May 24, 2008 | Canon PowerShot A570 IS Digital Camera
Problem
Two things to try...
A) If you have a card with some photo's on it then put it in the camera... Will the camera display the photos from the card in view/play mode? If so then the screen is working but the sensor in the camera may have died (the but that captures the image).
B) Try taking a picture with the camera (go through the steps to take one even though you can't see anything on the screen). Then put the memory card in a reader or a friends camera and see if the picture did get taken. If so then the sensor is still okay and the fault may be with the display.
If the display will show images from the memory card but doesn't show anything when in picture-taking mode but the camera does take pictures then the camera has a fault that isn't either the sensor or the LCD. It could then be an electronic failure or a problem with the mode selection switch.
Hope this helps to figure it out.
Cheers,
TS
Jan 04, 2008 | Panasonic Lumix DMC-LZ3 Digital Camera
Its how in the display format error.
Try this:
- Turn off your camera and take the batteries out
- Then take the memory card out
- Leave the batteries out for around 10 minutes
- Then put the memory card back in
- Then put the batteries back in and turn the camera on
- Try to see the pic/watch movie again
If this didn't work, check the memory card with a card reader...if it still gives an error then the card might have malfunctioned or needs a reformat.
Dec 14, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Best situation to use each of the shooting modes
Program Auto (Factory default setting) Program Auto mode is used for regular photography. The camera automatically makes the settings for natural color balance. Other functions, such as the flash mode and metering, can be adjusted manually. Portrait Portrait mode is suitable for taking a portrait-style picture of a person. The camera automatically sets the optimal shooting conditions. Landscape + Portrait Landscape + Portrait mode is suitable for taking photos which include both your subject and the landscape. The camera automatically sets the optimal shooting conditions. Landscape Landscape mode is suitable for taking pictures of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Night scene mode is suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both your subject and the night background. Indoor Indoor mode enables you to take pictures while indoors by allowing the flash to reach farther away. Beach & Snow Beach & Snow mode enables you to take pictures of scenery containing white sand or snow. Cuisine Cuisine mode enables you to take pictures of food by increasing the saturation, sharpness and contrast settings to take sharp, vivid pictures of the subject. Self-portrait Self-portrait mode enables you to take a picture of yourself while holding the camera. Point the lens towards yourself, and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the wide position and cannot be changed. QuickTime Movie QuickTime Movie mode lets you record movies with sound. The focus and zoom are locked. If the distance to the subject changes, the focus may be compromised.
Sep 01, 2005 | Olympus Stylus 410 / ? 410 Digital Camera
Canon Powershot SD450 / IXUS 55 Digital Camera Logo
379 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
