Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23425
Upright Freezer self defrosting
I had a problem with freezer not sucking the air out when door is closed. I found that drain was frozen and deiced. It worked fine after that for about 1-1/2 years. Now it is not sucking out air again. I repeated steps again. check t- stat setting and coil not frozen and it is still not sucking air out. Need your HELP.
    Novelist:
  • 184 Answers
THE (SUCKING AIR) OCCURS WHEN THE TEMP IS VERY LOW IN THE FREEZER AND YOU LET WARM AIR IN BY OPENING THE DOOR. WHEN THE DOOR IS CLOSED, THE WARM AIR IS COOLED CAUSING A VACUUM IN THE FREEZER. IF THE DOOR SEAL HAS A LEAK AROUND IT, THE SUCKING SOUND WILL NOT TAKE PLACE. CHECK THE DOOR SEAL FOR A GAP AT ONE OF THE CORNERS OR ALONG THE SIDES,BACK, BOTTOM, OR TOP.IF THE SEAL IS O.K., HOW IS THE TEMP? IF THE TEMP SEEMS WARM, YOU MAY NEED TO CHECK THE SEALED SYSTEM. LOOK AT THE FROST PATTERN ON THE EVAPORATOR. IS IT COMPLETE AND UNIFORM? IS ONLY PART OF THE EVAPORATOR FROSTED BACK? IF THE ENTIRE EVAPORATOR IS FROSTED BACK UNIFORMLY, THE SEALED SYSTEM IS O.K.
Posted on Apr 05, 2008
My freezer is blowing but not cold enough to keep it frozen
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor.
Hope this help in solving the problem. take care....
Sep 15, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Everything in our freezer is frozen solid except for the ice cream which is soft and mushy, the freezer is only about 3-4 years old and we checked and it is turned up to the coldest setting, any ideas what...
If this is a self defrosting model make sure that you don't have frost build up on the back wall of the freezer causing the air not to circulate like it should. If you do have frost build up other items will eventually start thawing as well. If this is the case you have a defrost problem.
If this is not a self defrosting model then make sure it does not need defrosting.
You normally will notice ice cream being soft before you notice other things thawing.
Also make sure the door is shutting good and you may try putting the ice cream in a different location.
Jul 20, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Temperature Alarm
although you could just close the door and it should right itself,could it be the right time for a total defrost and clean.all the drains/vents.....auto defrost only does the inside of the unit,
Jun 24, 2010 | Frigidaire 13.7 cu. ft. Upright Freezer...
Freezer is not cooling to highest capacity; things in the door are not frozen very cool to touch. I have meat on the topshelf, middle, and they are still frozen not thoughed but the vegatbles are cool to...
Air flow is very important. Make sure the vents in the back where the air blows are not restricted. Check to make sure any of the food is blocking the door from closing all the way or in the way of the door seal.
Take a look at the back wall near the bottom of the freezer, if you see frost build up on it you may have a defrost problem. Look for frost around the door on the inside liner or door shelves, if this is found then you have a door sealing problem.
May 06, 2010 | Frigidaire 12 cu. ft. / 340 liter Upright...
Not sucking out air when door closes anymore
run your hand around the freezer gasket with the freezer closed slowly and see if you feel any cold air,also check corners they leak to,frost is caused by warm air getting into the freezer or the defrost system is failing,let me know what you find-mike
Oct 01, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Water
You have to unblocked your drain of the fridge & will work after.
Francois
Jun 06, 2008 | Whirlpool 15.2 cu. ft. / 430 liter Upright...
Freezer defrosting
need to defost the whole freezer get the door to close correctly...
May 27, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Whirlpool Freezer
your defrost drain is frozen remove the rear bottom panel on the freezer at the back insede the freezer and clear the defrost drain there will be a hole under the ice you just need to clear the drain not buy a new freezer
May 19, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Whirlpool FUF20DPARWH Freezer
Was the door left open for a long period of time.? Sometimes this causes so much ice that it re freezes and can't clear the drain. The only solution is to unplug and let sit with doors open for at least 24 hours. to get all the ice off the coils. Then use a pipe cleaner on the drain then use a turkey baster to force water through. then a mild bleach solution. Check the door gaskets if they are ripped or loose or the door warped and not sealing tight this will also cause this problem. If this still doesn' t solve the problem it is probably a defrost problem Usually the timer or defrost thermostat.
May 18, 2008 | GE 20.3 cu. ft. / 575 liter Upright...
Door seal
If the door was left open you may have frozen the evaporator (on a frost free). I would suggest defrosting it as soon as possible and make sure the door doesnt get left open again. If it is not frost free it may just be that it is still trying to recover the temp it had lost by an open door. Hope this helps.
Aug 09, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23425 Logo
474 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
