Computer, kickes out of programs that, I am in. Also I will be working in a program, and the computer will just shut off. I have ans external fan under the computer. that I bought when I purchased the computer. I purchased the computer in 12/30/2008. I hsd to have the hard drive replaced because of the noise it was making
    Problem Solver:
  • 44 Answers
Check to see if you have enough RAM, and processor speed, because the program may take up too much RAM or processing speed and not leave enough for windows or what other operating system you have.
I hope this helps
Posted on Apr 01, 2008
YOU PURCHASED IT IN THE FUTURE?!?? OMFG!!! TIME TRAVELER!!!
I know the answer, but yoo haave two meny speling misstakes.
Learn english.
SOURCE:
Lenovo g550 laptop with an external monitor would only display of broken original screen after crash dump
Firstly you need to get your external monitor working. Have you tried pressing FN+F3 while turned on, (may take several presses).
If you can get the external monitor working then you'll need to run windows in safe mode and try removing any new drivers you installed. or try a 'Last Known good' on start up this depends on the OS version.
Nov 19, 2014 | Acer Computers & Internet
Frozen screen when hot
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
- Shut down your computer atleast two hour a day.
Most of the time, PC starts running slow and freezing by lots of reasons. Corrupt registry, unnecessary applications, as well as too many start-up items would be the major reasons contributing to this problem. Many PC users simply utilize PC yet never consider how to maintain and optimize PC performance. I would suggest you to download any reliable program to fix registry, to manage unnecessary applications & start-up items like am using Reginout since 2011. Many programs are available in market which can perform these steps, but don't believe on free products. Now its up to you. :-)
Good Luck.
Nov 12, 2013 | Dell Latitude E6510 Laptop
Toshiba satellite p300 shutdown
You also should change the thermal paste. If you want to play games, please choose normal PC. I think you are asking too much from your laptop.
Apr 15, 2013 | Toshiba Satellite Computers & Internet
Computer get hot and shut down
Clean the fan. The fan is probably getting hot and the computer has an automatic shut off. To help with this issue, update the bios of the computer. Just google your computer type and the newest bios.
Oct 19, 2012 | Sylvania G-Netbook
The program starts randomly and appears to be trying to retrieve
while booting the system, keep pressing F8, and login in safemode, whene your loged in, click start , the run, in run wright: msconfig
after that choose the bookmark startup, and unchek the programe that is loaded....(look at the files location u need to delete them), then hitt apply, go to the location , delet the files, and restart.
May 11, 2010 | Western Digital My Book Essential 1TB...
Can't turn off Hard Drive
The error means that you are using a file on the external hard drive and that it can not close that file when it is use. You have to close the program that is using the file first.
Example:
Lets go on the assumption that you have your music collection on the external. If you still have your music player running when you try to disconnect, you will be greeting with the same error message.
If the external contains any files that your Operating System uses, you will get this message anytime the computer is on. An example of this can be your "Page File".
Shutting the computer down correctly is your safest bet until you find exactly what file is being used and what program is using it. During shut down, the computer closes any running programs. With no programs running, it will safely disconnect from the external HD because there will be no files in use.
If you manually disconnect it while the file is in use, you could very easily corrupt the file and make it unusable. This is comparable to an Operating System getting corrupted from a computer not being shut down correctly (pulling the power from wall without doing a shut down).
Hope this helps.
May 02, 2010 | Western Digital My Book Essential Edition...
Okay i have an Acer BL50 with vista home on it that keeps shutting down without any warning just a blank black screen and then shutdown and then it restarts itself. I have done troubleshooting scanning in...
well you seem to have a program that restarts your computer, so run msconfig, and disable any program that might seem suspicious, most of the programs dont really affect anything if disabled, or can b reached by start menu. so you can try to disable any suspicious services or programs from msconfig and see if it works. hope it helps. goodluck.
Aug 24, 2009 | Computers & Internet
Unable to open a program
Hi, you will have to install a new and original operating system. But before that, I will advise you to get an external hard disk to copy all your files, because it could involve you formating the system. After that, load an active anti virus, then tranfer your file back. That's it. You can mail me for any question. abbeyglobe at yahoo.com. Good luck.
Dec 25, 2008 | Dell Dimension 4600 PC Desktop
How to connect a motorola DCH3416 to a computer Can I connect an external Hard drive to a DCH3416 USB or SATA port so that programs record to the externl HDD, or how can I tranfer recorded program to the...
Nope...
The eSATA ports are not configured in the device's firmware, and the USB 2.0 ports are useless except for charging your iPod or powering a USB fan. If you could connect an external drive to the unit, it would be partitioned with data encryption that can only be accessed by the particular DVR that formatted the drive. You can however stream local channels to a video capture card via the firewire ports but cable channels and DVR recorded programs would be encrypted. You can thank the MPAA for the grief...
Jun 24, 2008 | Televison & Video
Open Questions:
bxshhj AmaZon PrImE ReFunD PhOnE NuMbER +1-85O-812-4OO9 Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime? While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 20, 2019 | Amazon Computers & Internet
^%#@*& Amazon Prime rEfUnD pHoNe O*^%{+1++85O++8I2++4OO9*^ how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Computers & Internet Logo
42 people viewed this question
Ekse
Alun Cox
