Question about Garmin eTrex Vista GPS Receiver
BlueChart MicroSD map will not display
I purchased an eTrex Vista Cx along with a BlueChart preprogrammed data card that shows the map of the part of the Caribbean I live on (northern Venezuela). The map showed up great for about 3 months, lots of detail including all the small islands off the coast and local marinas and gas stations. Then one day the map was not there. I opened the back of the case and removed the SD card and put it back in and the map was back. That happened a couple times, and now the map just does not appear at all. I'm afraid to clean it or mess with it. Any suggestions? The SD card was expensive, I don't want it to go to waste.
  • 4 Answers
Get program MapUpload from after that go to Piratebay find Bluechart Atlantic 9.5 torrent.Mout it to Mapsource and with help of MapUpload send it to sd card
Posted on Aug 24, 2008
My garmin 530hcx has locked up on the opening there a master reset sequence? I have removed the batteries and still won't work! Also, it won't shut off once turned on and locked...
f a device is locking up and has a long noise or beep when powering down, this is due to hidden data being transferred to the microSD data card. These hidden files and folders are being created by the computer and sent to the data card in addition to the maps, waypoints, routes, tracks and pictures that were selected. The following GPS units could experience this issue.
  • eTrex Legend Cx
  • eTrex Legend HCx
  • eTrex Venture Cx
  • eTrex Vista Cx
  • eTrex Vista HCx
  • GPSMAP 60Cx
  • GPSMAP 60CSx
  • GPSMAP 76Cx
  • GPSMAP 76CSx
  • Rino 520HCx
  • Rino 530HCx
To prevent this issue when the device is shutting down delete these extra unused or hidden files and folders from the data card. Examples of these folders are: .Trashes and .Spotlight-V100 folders. Since the Mac OS adds hidden files and folders to mounted removable drive volumes this process cannot be done on a Mac and will need to be done after every time the data card is mounted as a volume on a Mac.
To delete these folders the device will have to be placed into USB Mass Storage mode. To do this:
  1. Connect the device to the computer using the USB cable
  2. Go to the Main Menu
  3. Select Setup
  4. Select Interface
  5. Select USB Mass Storage Mode
The device is now in USB Mass Storage Mode. At this time a window should open on the computer desktop displaying Removable Disk at the top. The Garmin folder will be displayed. Open the Garmin folder.
Do NOT delete the the following files:
  • gmapsupp.img
  • gmapsupp.unl
  • gmapsupp.gma
These files contain supplemental mapping. If delete will cause the mapping to be erased or unviewable.
If there are other folders or files on the data card, delete these. Some of these files or folders may be hidden and therefore will need to be unhidden*. Once you have done so, please disconnect the device from the computer and power it up.
*Note: To Display a file folder that is hidden:
  1. Select the Tools option on the window that appears on the computer when the device is in USB Mass Storage Mode
  2. Select Folder Options
  3. Select View
  4. Open the Files and Folders folder
  5. Open the Hidden Files and Folders folder
  6. Select Show hidden files and folder
  7. Select Apply
  8. Select OK
Once all of the hidden files and folders have been removed from the microSD Card the unit will not
Sep 18, 2011 | Garmin GPS
Garmin etrex ledgend c: When track log is turned on, "breadcrumbs" mark the path I've traveled. I don't save the track but the breadcrumbs remain on the unit's map....forever.
Check both your track and map settings. Make sure that "show track on map" is not selected in your map settings, and in your track settings try erasing all previous tracks.
Hope this helps!
Dec 09, 2010 | Garmin eTrex Vista Cx GPS Receiver
I' used my Etrex CX on my off road motorcicle, but few time by now I'd noticed problem using memory card map. I'd open device box, found a broken flat cable. I'd like have assinstace on where can purchase...
Got a credit card? If you do then try this place, they seem to have a few things for those things.
Hope that helps.
Apr 25, 2010 | Garmin eTrex Vista HCx Handheld GPS...
How do I install maps from the Garmin US Topo 100K to my Garmin Etrex Vista HCx? I've put in a microSD card, then what?
You need to install the map software on your PC. From there, using the map select tool, select the maps you want to add to your GS unit and then send them to the microSD card which will show up in the SEND window.
Mar 29, 2010 | Garmin eTrex Vista HCx Handheld GPS...
I have inserted a preprogrammed data card in to my Garmin Legend HCx but cant find the maps
Main menu > Setup > Map
Scroll across the icons to the fifth one (an i inside a blue circle). Press left bottom button on the side of the GPS. Scroll down to Show None, press the enter button, then scroll down again to the maps you want to show and press the enter button again. The new maps should now show on the screen.
Hope this solves your problem. If so, please come back and tell us, and rate our solution. Thank you.
Dec 27, 2009 | Garmin eTrex Legend GPS Receiver
I can't put maps on my Garmin etrex legend HCx
Your MicroSD card may be full just from the basic maps. Try larger card for additional maps. The vendors supply the minimum to keep the cost low and then force the customer to upgrade the resources at their own expense.
Dec 22, 2009 | Garmin eTrex Vista HCx Handheld GPS...
Compatable marine maps Australia for garmin etrex legend
You can purchase the Bluechart Marine maps for your area online at They will sell you an unlock code for a specific area.
Dec 27, 2008 | Garmin eTrex Legend GPS Receiver
Unlocking a Garmin etrex venture cx
The unit comes with a base map. You will need to purchase City Navigator software if you want more detailed maps which will show all roads. If the box contained a copy of the City Navigator and you threw away the code, you'll have to purchase another unlock code from Garmin.
May 22, 2008 | Garmin eTrex Venture Cx GPS Receiver
Freeze up
I have been having the same issue. I have both the Topo and City Nav software. I seems more consistent when using the City Nav data. Changed microSD cards brand and still the same issue. I was told to also update to 2.60, but it did not help
Feb 18, 2008 | Garmin eTrex Vista Cx GPS Receiver
Have problems with the loading of the map XPC415S. Australia East coast. Will this map work with this unit?
Any bluechart that has been preloaded on an SD card should work.  Did you purchase your chip with the data preloaded or did you download it yourself?  If you downloaded it yourself, try erasing the sd card, format it, then insert the blank card in the 420 and power it up. This somehow preps the chip for the data download.  Then download the bluechart onto the chip and try again.  There is some ambiguous wording in the download screen that makes it look like some kind of error, try the download anyway and most of the time it will work. After the download is complete it should list the bluechart software version on the screen along with some other software info.  If the operating system software is not v2.5 or higher, you may need to download a software update first.
Oct 25, 2007 | Garmin GPSMAP 420s GPS Receiver
Garmin eTrex Vista GPS Receiver Logo
145 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
