I downloaded a software that was only compatible with windows 98 and now my computer only starts on safe mode. I can't delete the program in the control panel either. How can I unistall it?
    Problem Solver:
  • 5 Answers
Try Ashanpoo Magic Uninstall
ashampoo.com
May the Gods of Linux be with You!
Posted on Apr 01, 2008
SOURCE:
The Windows 98 or later program will not run on my Windows 7 computer
windows 7 is vastly different than windows 98. You should try compatability mode: http://windows.microsoft.com/en-us/windows/make-older-programs-run#1TC=windows-7
Mar 27, 2014 | The Learning Company Computers & Internet
I am trying to upgrade my windows 7 laptop to windows 8. The upgrade won't allow me to continue until I manually delete McAfee Security Suite from my computer because it is not compatible. When I
right click the mcafee icon on screen and run as administrator and try to uninstall like that it should give you the privage that you dident before
Dec 26, 2012 | Computers & Internet
Hp Vectra 6VL will only start in safe mode
Run the computer in safe mode and then go and shut down unnecessary startup programs, then restart the PC.
Dec 23, 2012 | HP Vectra VL420 PC Desktop
My wife has used Activision's
I would install it/run it on a 95/98 machine, print off all of your recipes and then use newer software that is windows 7 compatible. Here is one you may like:
http://www.dvo.com/
Thank you,
Lee
May 03, 2011 | Activision Computers & Internet
I am not able to install any antivirus in my pc.what to so ?
First, let's see if you can download and run your Anti-Virus Program in Safe Mode. Safe Mode is a diagnostic feature built into Windows to help diagnose problems - particularly problems encountered at startup. When you start windows in Safe Mode, Windows loads only the programs and files necessary to start and run Windows. All unnecessary drivers are not loaded, so certain Windows features may not be available, however, if Windows boots (starts up) in safe mode, you know that your machine is not "brain dead" and you have a basically functional computer.
To start Windows in Safe Mode, start tapping the F8 key as soon as you apply power to your PC. Continue tapping until you se a menu titled "Windows Advanced Options Menu". Using the arrow keys, scroll up until Safe Mode With Networking is highlighted and then press the Enter key. You will see a lot of messages scroll down across your monitor screen. After about a minute you should see a Desktop Dialog box stating "Windows is running in Safe Mode." Click on "Yes" to continue, and Windows will start up in Safe Mode.
Now try to download and run your Anti-Virus program. If it will not load or run, it's because a virus has control of your operating system and is blocking your attemps to remove it. You will have to take your PC to a Computer Technician who will be equipped with the necessary tools and software to remove your virus. Your only other choice is to use your System Restore CD to completely re-format your hard drive and restore your PC to the state it was in when you first got it. NOTE: This will delete all data on your hard drive and you will have to re-install all software programs that you installed on the machine since to first got it.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Feb 28, 2011 | Computers & Internet
I have several older pieces of software that I would like to use. However I need to dumb down my laptop from window XP to windows 98 Is there a cheap/free way to this?
most windows 98 software can be ran in XP using "compatibility mode", but you might have to adjust other compatibility settings to get it to work. i have never had problems running windows 98 software in xp, or even vista, even without compatibility mode, so your actual hardware may be to blame.
to access compatibility mode, right click on the program's .exe file or desktop shortcut and choose "properties" and then select the "compatibility" tab. there you will find options to run in windows 98 mode, and several video options. you may have to try several different video configurations along with windows 98 mode before you find the one that works.
if the compatibility options dont fix it, then the processor is probably too fast for the program, and you will have to download software (if available for your motherboard/model) to underclock, or slow down, your processor. to find the right software to do this will take quite a bit of research, and may be beyond your skill level.
there is also a free program called microsoft virtual pc that can run other versions of windows in a "virtual computer" inside your windows xp desktop. you can download virtual pc from the microsoft website, and i believe that it comes with, or has available for free, a windows 98 virtual os. if it does not make the windows 98 virtual software available for free, then you will, unfortunately, have to purchase a windows 98 cd on ebay.
to actually wipe xp and replace it with windows 98 may not be feasible because the windows drivers might not be available for your computer, and the proper drivers are necessary to access all of your hardware. there is no support for windows 98 anymore, so the drivers are quite hard to find, if they were even ever made.
Nov 06, 2010 | IBM ThinkPad T20 2647 Notebook
I have a pc pro camera with create and share software it is for windows 98 i now have a computer with windows xp is there software to make it useable
Try downloading the windows 98 software with a shortcut on the desktop
Right click on the desktop icon and select 'Properties'
Select 'Compatibility' tab
Check the box 'Run this program in compatibility mode for:'
Select Windows 98 from the dropdown menu
Click 'Apply' and 'OK'
By trial and error check the 'Settings' boxes as required. Starting with visual themes.
Mar 22, 2010 | Intel Pro PC Camera CS430 Webcam
Is there microsoft "Return of the arcade
Try installing and playing that using 95/98 Compatibility mode.
To install a program using Windows XP's Compatibility Mode, hold
down SHIFT as you insert the game CD, use My Computer to browse
to the setup program, and then skip down to step 1 in the list below:
To run an installed program using Windows XP's Compatibility Mode,
first right click the program and "Send To..." / Desktop (create shortcut).
1.. Right click on the shortcut to the program.
2.. Click on Properties.
3.. Click on the Compatibility tab.
4.. Click on Run this program in compatibility mode and select one of these:
a.. Windows 95
b.. Windows 98
c.. Windows NT 4
d.. Windows 2000
5.. Under Display settings, check mark the mode that you think that is best:
a.. Run in 256 colors.
b.. Run in 640 X 480 screen resolution.
c.. Disable visual themes.
Click on Apply.Click on Ok.Double click on the program.
Of course, let's not forget to check for any patches or updates for that game.
A good place to find them is: www.avault.com/pcrl/patches_list.asp?letter=a
If you'd like to learn more information about compatibility mode, you can click the
link in the Compatibility tab that reads "Learn more about program compatibility",
or watch this Application Compatibility Power Point Presentation:
http://support.microsoft.com/servi [...] 112202.ppt
Jul 16, 2009 | Microsoft Return of Arcade for Windows
I am using windows 98 .when ever i start my computers it is showing error A FATAL EXCEPTION 0E HAS OCCURED AT 016F:BFF8D18A AND COMPUTER REBOOT AGAIN PLEASE GIVE ME SOME SOLUTION.
Sounds to me that a program installed isn't playing nice with Windows 98. I would go into safe mode and remove what ever software was recently installed or do as the link says and remove Antivirus program. If you can't get into safe mode I would have to tell you to reinstall Windows 98.
Have a good day,
ArmyMason
Feb 26, 2009 | Microsoft Windows 98 for PC
Macromedia projector has stopped
You might try reinstalling Macromedia Projector (now Adobe Flash).
Sometimes if you use compatibility mode to run the game:
  • Click - Start, Programs, Accessories, Program Compatibility Wizard.
  • Follow the prompts to set up the compatibility mode.
  • Use Windows 98 compatibility, and disable visual themes.
Also you could change Apple Quicktime to run video in Safemode:
Quicktime Player > Edit > Quicktime Preferences > Advanced > and under Video Change from DirectX to Safe Mode (GDI)
You may need to reinstall Quicktime, but uninstall the old version first.
Nov 20, 2007 | Computers & Internet
Open Questions:
Computers & Internet Logo
23 people viewed this question
Ekse
Alun Cox
