Question about HP iPAQ HX2490 Pocket PC
Windows Mobile Device Center (Vista SP1 32bit) Can't sync with my IPAQ HX2490b
Windows Mobile Device Center is supposed to detect PPC's automatically. I plugged in my Ipaq 2490b, it says installing drivers, then finishes says drivers installed for Unidentified Device.
I've changed the usb sync to RNDIS and also tried USB Serial Sync Mode either one would not work.
  • 2 more comments
  • 2chima May 05, 2008
    Same Problem with QTek 8525
    Running Wndows Mobile 6, Vista 32bit SP1
    And the Win Mobile Device Center says "not connected" no matter what I do.
  • schwartzhq Jul 07, 2008
    I have the same problem with my xv6700 phone.
  • Anonymous Jul 09, 2008
    I have the same problem (samsung i760) AND found others too! NOW here is the kicker -- I and others have actually succesfully made instalation and connection...and for no apparent reason....it stops working. I and others are moderate above average technically speaking, so this is not a stupid problem, but a VERY bad bug and MS is NOT responding.
  • Don H4 Dec 22, 2008
    I have the same problem, windows says it is installing the drivers, then listgs my ipaq hx2795b as an "unidentified device" in conjunction w/ message "searching preconfigured driver folders", and nothing more happens. I DID find an iPaq listing under Device Drivers, but couldn't get it to do anything at all.
For the Samsung i760, disable "advanced network functionality" in the "USB to PC" setting by uncheckmarking it. Then Vista and WMDC will detect the i760 properly...
Posted on Aug 16, 2008
    Problem Solver:
  • 7 Answers
You can not be hooked up to the internet and sync the phone at the same time.shut down the internet it will connect.to the phone.
Posted on Feb 12, 2009
  • Anonymous Feb 24, 2009
    One word of advice, get rid of windows vista. It is a piece of ****!! Get windows xp. wmdc. is not worth the time. This is all I have read about on net and in the magazines, that it is no good. Muicrosoft get with the program.
I was having same problem with my Samsung i600. I installed Update for Windows Mobile for PC (KB949168) and now it wrks fine. Strange this was only supposed to fix some daylight saving time issues!
Andy
Posted on Aug 26, 2008
Ok. I have a samsung i760 and found others with mainstream, new pda's. This is NOT a problem with the device, it is one of Windows Mobile Device Center.
I have found others to get the exact same resulst, it says (in the same window) "Device ready to use" yet below says that it is searching for drivers.
ALSO, I and others have installed the furst time, and comunication is established...yet for some reason ...it just STOPS! So, I and those I have found are moderate to above average in computer skills, this is a big problem.
Posted on Jul 09, 2008
SOURCE:
I cannot access windows vista to sync with my hp 6310 ipaq
Greetings - I'm going to guess that perhaps you installed Activesync 4.5, For Vista or Windows 7 you have to install Windows Mobile Device Center which is available HERE.
If you are using mobile device center that isn't the problem and Microsoft has a dedicated section of their website dedicated to solutions syncing Windows Mobile device with Vista, way too much for me to go over here. There's a great deal of trouble shooting information about sync problems HERE.
Thanks for using Fix Ya
Mikeywaf
Mar 16, 2011 | HP iPAQ H6310
Window Vista syncronizing with iPAQ 3835 problem
In order to sync any iPAQ with Windows Vista, you will need to download and install Windows Mobile Device Center 6.1 from http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx.
Activesync will only work for XP Operating Systems and earlier.
Notes
  • To find out whether your version of Windows Vista or Windows 7 is 32-bit or 64-bit, click Start, right-click Computer, and then click Properties. The version is listed after System Type.
  • You can use Windows Mobile Device Center 6.1 only with phones running Windows Mobile 2003 or later. ActiveSync and Windows Mobile Device Center won’t work with Windows Embedded CE 4.2 or 5.0, Pocket PC 2002, or Smartphone 2002 devices. (To see which Windows Mobile operating system you’re using, and if your phone doesn’t have a touch screen, click Start > Settings > About. If your phone has a touch screen, click Start > Settings > System tab > About.) To sync content to any of these devices, you must use a USB or serial cable and your computer’s Internet connection and File Explorer.
  • You must use Microsoft Outlook 2002, Outlook 2003, or Office Outlook 2007 to sync your e-mail, contacts, tasks, and notes from your computer.
  • You must use a USB cable to connect your phone to your computer the first time you use Windows Mobile Device Center to sync.
Jan 11, 2010 | HP iPAQ H3835 Pocket PC
I have a Ipaq 2200 version 4.2 2003 will it active sync with windows7
In order to sync your iPAQ with Windows Vista or Windows 7, you will need to download and install Windows Mobile Device Center 6.1 from http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx.
Notes
Dec 30, 2009 | i-mate Pocket PC
I'm running Vista and I'm having trouble with my HX2415.I have Windows Mobile Device Center Installed. When I plug the unit into a USB port it doesn't find the hardware. It worked fine on XP with Active...
Hi
Thanks for using FixYa. HP ipaq HX2415 is compatible with Windows Vista Mobile Device center Version 6.1. Please check if you are using version 6.1, you can download the Windows Vista Mobile Device center Version 6.1 from this link--
Windows Vista Mobile Device center Version 6.1 Link
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 07, 2009 | HP iPAQ HX2415 Pocket PC
Is a compaq ipaq h3835 compatable with vista
No, you do not need an upgrade. You'll need to be download only "Windows Mobile Device Center" to your Vista PC instead of ActiveSync. (ActiveSync is not compatible with Vista, instead Microsoft changed the software a bit called "Windows Mobile Device Center" and can be downloaded from Microsoft's website.) Your Vista PC should also recognize your ipaq PPC without needing any driver CD. I hope it helps.
Apr 18, 2009 | HP iPAQ H3835 Pocket PC
HP iPAQ 2215 sync problems with Vista and Windows Mobile 6.1
I've decided to get a smartphone with Windows Mobile 6.1, so this issue has been "solved"
Feb 08, 2009 | HP iPAQ 612C Smartphone
Programs won't upload to my ipaq 111 classic ppc
I did not know that I needed to do a soft reboot on the PCC. Once that happened, everything loaded at once. I don't know where it came from, but it all loaded.
Dec 08, 2008 | HP iPAQ 111 Classic Pocket PC
HP Ipaq h1940 won't sync with Vista
use microsoft windows mobile device center
Jun 11, 2008 | HP iPAQ H1940 Pocket PC
HTC PPC-6800 Vista driver and/or WMDC install problem
hey u need to install windows mobile device center first, not its update, on ur vista, as activesync cannot be installed on vista...
download it from
http://www.microsoft.com/windowsmobile/devicecenter.mspx after a validation check..
Jan 26, 2008 | HTC PPC-6800 Smartphone
HP iPAQ HX2490 Pocket PC Logo
3,614 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
