Question about Toshiba Televison & Video
Tuning TV onto AV chanel
Cannot tune TV into AV channel to receive SKY
Unplugged every cable and then reconnected them - Bob's your Uncle - it worked!!!!
Posted on Apr 02, 2008
How do I get sky from my set top box to work in a different room, I am trying to get my sky to work on a TV in a different room ? I have wired up TV coax cable from my sky box in sitting room and run
Hi Jim,
Here In my place in India, you can attach only one tv to the sky set top box.That too with AV cables. The program or channel changing is done by box only. The tv works as a monitor and has no role in program selection. You can attach a second tv to the box not through antenna cable but through AV cables only. That too if the box is having second set of output sockets. In that case both the TVs will receive the same programmes. To watch different programmes on the second tv you will have to go for an additional box.
Feb 09, 2015 | LG Televison & Video
How do I get my Sky channel back on analogue after re-tuning freeview
Go in to analogue tuning. Tune just the analogue side of the TV.
Sep 05, 2014 | Televison & Video
I have a panasonic viera 42 in plasma. It has a built in freeview receiver. It is in the bedroom and receives a signal through a booster from the main sky box. I can get free view channels on it but can't...
switch tv to analogue tv and auto tune on tuning menu making sure sky is on. It should find it around channel 69. If quality poor then change output frequency to a lower channel. You do this with sky menu and instruction book. Info is changing RF output in book, or google it.
Apr 30, 2014 | Panasonic PV-M1349 Combo
AT EVERY POWER CUT MY TV SET LOSES SKY TUNING AND I CAN NOT FIND THE AV CHANEL
do you also lost color when the set is back on?
I advice to take it to the repair shop because there is something wrong with the memory of the set (EPROM).
Aug 26, 2010 | Televison & Video
Have a tv in bedroom and want to tune sky into it on one of the channels, how do i do this
you need a separate satellite receiver or an AV cable from another receiver (but this way you will see what's on the other tv without any control over it).
Oct 04, 2009 | Toshiba REGZA 32WLG66 32 in. Television
How do I tune it into Sky channels (lost manual)
i have tried to tune in a sky digibox that have not used for a couple of years,i can only tune in the first 9 chanels for some reason.any clues what i am doing wrong
Apr 13, 2009 | Televison & Video
Tuning Sony KDL 32U3000 for Sky TV
Hi Max,
I an not familiar with Sky TV, I assume it a Cable or Satilite Service.
Here are a few things to check.
  1. Press the INPUT button on the TV remote or on the TV control panel, cycle through all inputs and see if you get a signal.
  2. From the TV's Video Menu, set tuning band to Cable and not to Air or Antenna.
  3. From the Video menu Scan for channels, there should be a Auto Scan option.
Try these and let me know how it goes, I can be of further assistance.
Lone99star
Feb 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Technika tv lcd 19-907 tuning in to sky in bedroom.
Hi i had the same problem but i have sorted mine now. What i was doing wrong was i wasnt tuning in the analoge channels only the freeview digital ones. To do this you need to first turn your tv on. Then press the "source" button, this will bring up a little menu at the top left hand side. When this menu comes up press the "Programme +" button (the one that you use for changing channels near the volume button) press this until you get up to "TV", when T.V is highlighted just wait 3 secs and it will switch over. You will probably get a blue screen with a no signal message (you are now on analogue) when you get this blue screen press the "tune" button. It will automatically start tuning in all of your channels, at first they will be fuzzy but as it works they will become clearer. Your sky channel will also be tuned in. When mine tuned in it didnt tune them in on the right numbers though, bbc2 was on number 1 etc. If you ever need to use a playstation or something it goes into the scart connection at the side of the t.v and you need to press "source" and go up to "scart". To get back onto the digital channels just press "dtv/dvd".
hope i helped!
Dec 14, 2008 | Televison & Video
How do I get the TV screen back to an AV chanel?
I cant get a slide show to view on the TV screen.
Apr 01, 2008 | Televison & Video
Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Jan 30, 2008 | Televison & Video
Televison & Video Logo
157 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
