Question about Refrigerators
My hotpoint FFA91 fridge freezer no longer gets cold in either the fridge or the freezer, There is no noise coming from the compressor. the digital display still shows the correct temparture and the audio alamrs still bleeps now and again to let me know its not at the right temp unless i swicth it off and back on
  • 5 more comments
  • Joanne Picton
    Joanne Picton Apr 16, 2008
    my fridge freezer ffa91 has suddenly started bleeping , i have adjusted the temperatures for both the fridge 4 deg and the freezer -18deg but the freezer keeps jumping back to 1 deg, the fridge is also warm, there is no noise coming out at all.
  • john 1 w Apr 21, 2008
    the thermostat flashes and the reading says -2
  • Anonymous Jun 11, 2008
    After an electricity cut off my FFA91 Hotpoint fridge freezer doesn't get cold. It bleeps very at frequent intervals and the display is Ok but ..
    can you help
  • squidgey_4 Jul 29, 2008
    My fridge is warm, the freezer is working fine although it seems to be frostier than normal. The temps are set to fridge 4 and 28 for freezer. Lights are working makes a noise as its working. We have tried turning it off, also removing the back of the freezer compartment and clearing it of frost from around the fan it worked a little after this but has now given in again.
  • CORONATION Oct 05, 2008
    My Hotpoint FFA91 fridge freezer no longer gets cold in either the fridge or the freezer.
  • Gary Davd
    Gary Davd May 11, 2010
    need the model number as well
  • Gary Davd
    do you get a hum and a click noise from the compresser area??are all the fans running??
I've got a hotpoint ffa91 fridge/freezer but there is this tempature symbol flashing and a bell that beeps !! Nothing is going cold lol
Posted on May 23, 2012
3 Suggested Answers
walterkunesk
  • 683 Answers
SOURCE: Hiya,i have a hotpoint fridge freezer ffa91 and
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this
Posted on Mar 12, 2011
SOURCE: My Hotpoint frostfree fridge freezer
black sticky stuff underneat refrirator door
Posted on Jul 31, 2011
Hotpoint ffa91 My frige is freezing everything I put inside it.
sounds like the door between the freezer and cooler is stuck open
Jan 23, 2014 | Refrigerators
No power to freezer fan on hotpoint ffa91
On some of theses units the fans are connected through the defrost bi metal. When the bi metal gets cold the fan comes on. Check and replace bi metal. Should solve your issue.
Aug 18, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hiya,i have a hotpoint fridge freezer ffa91 and the fridge is no longer getting cold.The compressor seems is hot but cant hear the normal noises coming from the fridge.The digital display shows an arrow...
4. Wait one hour.
try this
Mar 12, 2011 | Hotpoint Refrigerators
I have a hotpoint fridge bottom freezer and after I had filled the freezer with my shopping yesterday, it started making a shreeking noise, I thought maybe it needed defrosting, which it did, so I...
If both section are not working as required then its compressor fault.The noise you noticed must be from compressor related parts,that are fan,the motor and relay.But If freezer is getting over cold and friezed and fridge section not getting cold then Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Jan 31, 2011 | Hotpoint FFA45 Bottom Freezer Refrigerator
My frost Free Hotpoint FFA91 keeps freezing in the freezer. I take the back off (from in side the freezer) and the bottom of the element is frozen solid. If I defrost it then it will be the same again in...
Sounds like you have either a bad defrost heater or a bad defrost control timer, however I can not provide part numbers, as I can not find any model numbers which begin with FFA91
Jul 06, 2009 | Freezers
Refridgerator and freezer no longer cold!
Try disconnecting the fridge for a few minutes and then listen for the compressor to come on not just the fans.
Jul 02, 2009 | Refrigerators
Fridge freezer not working after power cut
if its a ge i would say itsyour main board not compressor boards about 200
Mar 19, 2009 | Refrigerators
HOTPOINT RLA30 FRIDGE
is the noise like a hum? touch the compressor if it is really hot, suspect relay/overload combination defective touch the little line that comes out of compressor if cold, suspect the above. if you change the relay/overload combination, and works fine there's your problem. hope to se of some help.
Apr 21, 2008 | Hotpoint RLA30 Compact Refrigerator
Refrigerators Logo
1,543 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
