Question about Sony Ericsson P1i
Folder and File options
I upgraded the software for my P1i and post that I do not have the Hide option under properties for either a folder or a file.Please help me with that
  • Anonymous Dec 19, 2008
    same thing after update
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Well that just means that Sony removed it from the phone.
Posted on Jan 10, 2009
Recover hide file in usb
Make sure OS has Show hidden files, folders and drives is checked.
Open Folder Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_47.png, clicking Control Panel, clickingAppearance and Personalization, and then clicking Folder Options.
Aug 30, 2012 | BuffaloShop MiniStation Computers &...
What is the best method to hide a file in flash drive without any software?
The easiest method is change file to a hidden file.
Right click on the file - properties - tick on hidden
There is an advanced method, change file to a hidden file and as well as system file using MS-Dos.
I refer you to SmartUSB.net. It is a good source for flash drive users.
Hide a file or folder in your flash drive
http://www.smartusb.net/p/hide-file-or-folder-in-flash-drive.html
Change your flash drive icon
http://www.smartusb.net/p/change-flash-drive-icon.html
Insert symbols to your flash drive label
http://www.smartusb.net/p/insert-symbols-to-flash-drive-label.html
Add wallpaper to your flash drive background
http://www.smartusb.net/p/add-wallpaper-to-flash-drive-background.html
Change font color in your flash drive
http://www.smartusb.net/p/change-font-color-of-your-flash-drive.html
Jul 24, 2012 | Computers & Internet
Files hidden in memory card
open any folder in your pc. click on tools -- folder ---option -- view. select show hidden files and folders. deselect hide extension for known file types. de-select hide protected operating system files. Now you can view your hidden songs files. Kindly use attrib command with *.* option through command prompt with -s -h option to convert them back to normal files. Kindly do comment back if you don't know how to use cmd prompt. I'll post the complete procedure.
Sep 04, 2009 | Nokia 3110 Cellular Phone
Hello CyberGuru
its not from microsoft explorer, you have to be inside folder then hit tools and folder options and show or hide files.
Windows XP
To enable the viewing of Hidden files follow these steps:
Close all programs so that you are at your desktop.
Double-click on the My Computer icon.
Select the Tools menu and click Folder Options.
After the new window appears select the View tab.
Put a checkmark in the checkbox labeled Display the contents of system folders.
Under the Hidden files and folders section select the radio button labeled Show hidden files and folders.
Remove the checkmark from the checkbox labeled Hide file extensions for known file types.
Remove the checkmark from the checkbox labeled Hide protected operating system files.
Press the Apply button and then the OK button and shutdown My Computer.
Now your computer is configured to show all hidden files
if it doesnot work use spyware software to fix it.
Jul 08, 2009 | Acer Aspire One PC Notebook
Backup folder shows as empty
Have you tried showing hidden and system files?
In the Windows Explorer, go to the Tools menu and select Options or Folder Options.
In the View tab, scroll in the list and make sure show hidden files is selected. You can also unselect the 'hide system files' option.
That will show you anything on the disk!
Jules
Apr 02, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Asking
Hi Mykk
If you are using Microsoft windows then follow the following steps to hide any files and folder:
1. Right click the file or folder that you want to hide
2. Go to Properties
3. Now in the Attribute Section (Below the size of files or folder)
4. Now You'll be able to see two check box option i.e. "Read-only" & "Hidden".
5. Now check mark the Hidden Option in Attribute Section.
6. Click Apply Button.
7. Confirm the option to apply settings to Subfolder & files(This confirmattion is asked only if you are hiding any folder).
8. Click OK.
9Now you'll be seeing that the folder or file's color has been changed that means you have hidden file or folder Successfully.
10. Now Go to "Tools" in menu bar
11. Click "Folder options"
12. Go to "View" Tab
13. Now in Hidden files and folder optin below Select the redio box i.e. "Do not show hidden files and folders"
14. Click Apply button
15. Click Ok
To Unhide your files or folder follow the steps from 10-15, by just making changes in step 13.
You just have to select the radio box i.e. "Show hidden files and folders.
(Rate me after you have got ur solution)
-Thanx
-Romy
Aug 03, 2008 | Microsoft Windows Vista Ultimate Edition
My Windows Explorer does not show extentions
By default, file extensions for known file types are hidden in Windows XP. However, you can change this setting so that file extensions are shown for files in a certain folder or for all files on your hard disk.
To show file extensions, first open any folder on your hard drive, such as "My Computer" or "My Documents." Then select "Folder Options..." from the Tools menu as shown below.
545a526.gif When the Folder Options window opens, click the View tab. This will show the file and folder view settings.
95b32b0.gif One of the options under Advanced settings is "Hide extensions for known file types." If this option is checked, uncheck the checkbox and click Apply or OK. This setting is system wide, so unchecking this box will make file extensions appear in all folders.
If you decide to hide file extensions at a later time, you can check the box again and click OK to revert back to the previous settings.
Jul 16, 2008 | Computers & Internet
Recycle bin
1. Click Start, and then click My Computer. 2. On the Tools menu, click Folder Options. 3. Click the View tab, and then click to clear the Hide protected operating system files (Recommended) check box. 4. Click Yes when the warning message appears, and then click OK to close the Folder Options dialog box. 5. Click Folders on the toolbar.
Note If Folders is not visible on the toolbar, point to Toolbars on the View menu, and then click Standard Buttons. 6. In the left pane, under Folders, locate the Recycle Bin folder, and then drag the Recycle Bin folder to the desktop. 7. On the Tools menu, click Folder Options. 8. Click the View tab, and then click to select the Hide protected operating system files (Recommended) check box. Click OK.Note This procedure does not re-create the original icon. However, this procedure restores most of the features of the Recycle Bin, including the following: • Delete a file by dragging it to the Recycle Bin icon on your Desktop. • Retrieve a file that you deleted by double-clicking the Recycle Bin icon on your Desktop, right-clicking the file that you want to retrieve, and then clicking Restore. • Empty the Recycle Bin by right-clicking the Recycle Bin icon on your Desktop, and then clicking Empty Recycle Bin. When you use these step to work around the problem, you cannot right-click the Recycle Bin shortcut to access the Recycle Bin Properties. To set properties for the Recycle Bin, follow these steps: 1. Double-click the Recycle Bin shortcut on the Desktop. The Recycle Bin folder opens. 2. In the upper left corner of the Recycle Bin folder, right-click the Recycle Bin icon, and then click Properties.
Mar 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
Recycle bin got deleted
Folder hide
Open tools menu, on top bar of your folder, and chose option 'folder options'. Alternatively open 'folder options' from control panel.
In 'folder options' box use view files option. In view files chose display hidden files and display system file.
Here is the way to do this in detail
To change attributes click right button of mouse on folder, chose properies, at the bottom of properties box you have the attributes.
regards
Mar 19, 2008 | Microsoft Windows XP Professional
Sony Ericsson P1i Logo
60 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
