Question about GE WBB4500EWW Top Load Washer
GE top load washer will drain but not spin
We have a GE top loading washer (model S3700E4WW) that is exactly two years old. It is going through the cycles, but when it reaches the spin cycle, it will drain the water, hums as though going through the cycle, but does not spin out the clothes. My husband feels that it may be the timer (the dial doesn't seem to be "catching" right when setting the machine), but we would like some additional insight before ordering the part. He has checked the belt, which is tight. Any help would be appreciated!
  • Anonymous Apr 21, 2008
    GE MDL# WBB2090F1WW
    I am having the same problem. I had a serviceman come out and he stated that when the lid is opened during the wash cycle the clutch trips or freezes up. He took the front panel off and clicked some kind of switch below the motor and plugged it back up all in less than 5 minutes and $150. Now I have the same problem again and i never opened the lid during the wash cycle. Could something else be causing this problem?
I ge washer S3700Goww doesn't spin, I lossen the bottom plate and the belt is find but I have ground up metal peieces .
Posted on May 04, 2011
    Genius:
  • 1,224 Answers
You both need to have the switch replaced or you can open top of washer and combine the lid switches wires together as a bypass and electrical tape
the lid switches are put in the washers to keep kids from opening the washer machine this is automatic shut down
for xenazoe
you require this part for your washer
Part Number: WH12X10065
SWITCH PRESSURE
Posted on Jun 13, 2008
  • Christophe Thompson
    Christophe Thompson Jun 13, 2008
    oh by the way guest you got ripped off that was not someone who was certified to work on your washer
    i would have done it for 20 dollars plus the cost of part in the future becareful who works on your appliances
    get at least 3 estimates before someone works on your appliances you would be amazed
  • Brad Jensen
    Brad Jensen Jan 26, 2012
    completely wrong. if you are charging $20 for a labor fee then you are doing illegal side jobs. Those of us that have business insurance, and state licensing and gas to pay for have to charge a bit more to cover overhead, not to mention employees. You must be riding your bike to get these repairs done and selling used parts.
Water does not drain from te washing machine. Can I do anything to addrfess the problem. I don't have the exact model. It is a GE top load.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 25, 2010 | GE Washing Machines
GE S3700E4WW DOES NOT FILL AND SPIN. I HEAR LIKE IT WANTS TO SPIN BUT DOSNT SPIN OR FILL.
It sounds like the complaint of the units board which is located beneath the unit. You may take it out from the unit, but it can be repaired only by a professional. Sometimes, it should be replaced which may seem costly.
Aug 07, 2010 | GE WBB4500EWW Top Load Washer
GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
Water in clothes after spin cycle
need to open washer and check the DRAIN MOTOR PUMP , usually gets clogged with lint and debris , usually located at the bottom side , small motor w/ propeller ,where the drain hose is connected, AJ
Nov 11, 2009 | GE WJRR4170E Top Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
GE washer eill not drain or spin.
if the unit is at least 4 or 5 years old, most likely the pump is clogged with the same hair.....that clogs vacuums. you probably can fix it yourself provided you can get to the pump without too much trouble. i'm not familiar with all the brands designs. maybe someone else on this sight can help. if this is not the problem than most likely some of the timers points are burned. if the unit is more than 10 years old and/or the unit has been used unusually alot there is the possibility that the transmission has problems, but that is pretty unlikely. hope this helps.
Mar 05, 2008 | GE WDSR2080D Top Load Washer
GE Top Load Washer 10 yrs. old, used for 3 years, stored after that
the water must drain out of the tank b4 it can spin make sure the pump is working ok
Nov 17, 2007 | GE WBSR3140DW Top Load Washer
GE WBB4500EWW Top Load Washer Logo
1,295 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
