Question about Roxio Easy Media Creator 7
Disc copy program not working
I have a library of DVD's that I've made and finalized. All are DVD -R or DVD-RW. I have used Roxio 7 to make copies using the Disc Copy part of the program and it has worked well. Now suddenly, it is not working. I recently downloaded the update at the Roxio site, and then tried to copy a DVD again, but it did not fix the problem.
    Scholar:
  • 130 Answers
Try uninstalling then reinstalling the roxio program
Posted on Apr 02, 2008
SOURCE:
Recorder works great but cannot play DVDs recorded from television on my computer. These recordings were made of several films over six hours on DVD-RW discs. I have Windows 7 and have tried all types...
Recordings made on DVD-RW discs cannot be played in other players, including many PC DVD-ROM drives; incompatible format. If you had recorded your TV/video material onto a DVD-R in the recorder, for example, then finalised the disc, it would work in your PC and any DVD player.
But since you used a re-writable video/data DVD, it won't work outside of the recorder - that's why you can't play it (or if it was written on your PC, your recorder won't read it - incompatible disc).
If you don't wish to finalise the RW disc (I don't recommend it - plus I wouldn't blame you for not wanting to do that), you could copy it from one recorder to another, unless your PC has a capture card - which allows the outputs of your DVD recorder to connect to the PC inputs. Using relevant DVD software (for example, ULead DVD factory), you may be able to 're-author' the contents of your recording, and create a DVD-R copy which WILL work in all players that way - use DVD-R (or DVD+R if your PC and other players allow that format) for 'permanent' video recording - use re-writable discs for backups, test recordings, temporary stuff, and PC data files. There are many inexpensive software programs available. Have a look sometime at your leisure. See what they are like.
Even if you could copy the DVD contents in a Windows program, regardless of the software used, there is no guarantee that the copy you make will work outside of the player and/or original recorder, because it would require a lot of time and effort to achieve, and unless you know what you're doing with the program, you could waste a lot of time (and blank discs) in the process - it only adds to the frustration.
I am glad to hear your recorder has no major faults at present - that's great. No expensive workshop repair cost headaches; just frustration with discs (especially if they become drink coasters).
DVD-RW is ideal for test video recordings and PC data, but is limited when it comes to compatible playback/usage outside of the device it was written/recorded on.
DVD+RW discs on the other hand, when titled/ top menu created, can be played on a PC or player without finalising. You can even direct copy a DVD+RW straight to a DVD-R - it works in most cases.
The upshot of this is you haven't lost anything, and with the exception of perhaps a few dollars for a pack of either DVD+RW, DVD+R, or DVD-R discs (any brand), it didn't cost a fortune. You can also retain any DVD-RW discs you have previously used.
The simplest and cheapest options are often the best ones.
Mar 24, 2011 | Panasonic DMR-ES10 DVD Recorder
D: Toshiba DVD-ROM SD-R2102 ("Write error - Medium error")
Yo' Sam!
Start by checking your WINDOWS CONTROL PANEL. Be sure there are no errors for your drivers. IF you have your proper drivers for your DVD Drive, totally remove ALL drivers and then restart your system... still have problems?
Next TOTALLY DELETE your Roxio program... somewhere on the Internet there is a tool that will do just that. You want to try your best to CLEAR and ALL hard drive and REGISTRY traces of ROXIO program(s)!
Just ONE bad ROXIO/REGISTRY problem can have you chasing your tail for days/forever.
With ROXIO deleted, try one of the FREE DVD burning programs to assure it's not really a DVD problem?
I just did a GOOGLE check and there are tons of hits for you.
Hope this helps!
Anthony
Apr 16, 2010 | Toshiba SD R2102 CD-RW/DVD-ROM Burner
When it comes time for me to copy my dvd...it prompts me to insert a blank dvd-r...i insert a blank dvd-r and it kicks the disc back out telling me to insert a blank dvd-r. Do i have to do something...
This is a common problem. RW DVD are different types. You need to read what type of RW DVD you need there will be either a nimber, leter or symbol at the end of where it says RW DVD or DVD RW and you CANNOT use just any disc.
Mar 16, 2010 | Roxio Easy CD & DVD Burning
Sony DCR DVD108 not finalizing disc, lost data
I noticed that too with my "VR" (and NOT "Video") formatted disks. I don't think you can finalize the VR ones. Instead you have to use the Sony Import tool to grab the videos. If you are like me you probably remember using the import tool with Video formatted disks BEFORE finalizing them and it takes forever to copy them. They must be finalized to view on other devices, copy using the import tool quicker, etc., but VR formatted disks seem optimized for importing (and can be edited on the camcorder directly.
Sep 26, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Have just downloaded Roxio 2009--have a computer purchased abour a year ago using Windows XP--has a RightScribe DVDMulti RW Disc player as E drive--never before tried to burn a disc--just tried and when...
Are you sure the DVD-R disc you are trying to use is brand new and never written on?
Try using a DVD-RW disc or a different DVD-R disc...click on this link to learn more about DVD-R DVD-RW differences and troubleshooting
http://club.cdfreaks.com/f7/cd-r-will-burn-but-dvd-r-will-not-214531/
Another thing is to try a different program like NERO...click on the link to download it:
http://www.nero.com/enu/downloads-backitup-and-burn-trial.php
Jul 25, 2009 | Computers & Internet
Trying to copy disc, having problems
Yes, it can be a pain. There are a lot of programs that conflict with roxio. Have you installed anything new since last it worked? Also, try getting newest drivers.
Dec 11, 2008 | Roxio Easy CD/DVD Creator 6.1 Basic VCD...
Disc copier
try re-installing the roxio program, sometimes programs get corrupted and need to be re-installed
Apr 01, 2008 | Computers & Internet
Adding data file to existing CD-RW disc in Roxio
First off, for your information your Roxio is OLD, they now have Roxio 9.
But that will not solve your problem. Can you open the CD and copy and paste anything? Or is the CD "Read Only"? If read only, it is because when you "Finalized" the CD you optioned the "Write Protect" making writing to the disk impossible. This protects the disk from erasure too.
You will need to use another disk.
Otherwise you can just use the same method you used before to write to the disk, or Copy and Paste, or Drag and Drop.
The Write Protect is specific to the program you are running.
However, Roxio 7 and 9 program I have used ask, "Do you want to be able to write to this disk again?" or words to that effect. All you need to do is just put a check in the box (or not, if you want to write to disk again). This happens when you are ready to remove the CD or DVD from the drive. Then the program runs a "Finalizing" program before the disk automatically ejects.
Nov 07, 2007 | Roxio Easy CD & DVD Creator 6...
Roxio Easy Media Creator 7 Logo
100 people viewed this question
Top Roxio Computers & Internet Experts
Peter Dragonetti
Thomas F. Schneider
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
