Question about Panasonic KX-TGA650B Headset Phone
Open the handset to clean keypad
I have kids - need I say more!
My kids spilled something on the phones and now all the keys are sticking and hard to push to dial. Is there instructions to open the handset so I can get in there and clean this up?
thanks
Sue
    Master:
  • 518 Answers
Hi Sue,
Sometimes there's a screw or 2 inside the battery compartment, other than that they snap together.
Once you get the keypad out, wash it in warm water with a couple drops of dish liquid, rinse and pat dry. The Pc Board the keypad sits on can be cleaned with alchohol and Q-Tip.
Hope that helps.
Geno
Posted on Apr 01, 2008
GE 29280FE1-A
My bet will be to open it up and clean it with a alcohol solution ..most probably something spilled on it.
May 17, 2014 | GE Lands Phones
1 on the key pad does not work
maybe the keypad membrane is need to be cleaned, open the phone try cleaning the keypad membrane..
Sep 16, 2010 | Panasonic KX TGA400B Cordless Expansion...
My motorola v3s razr from cricket none of the keypad buttons work what should i do
1 of three things could be wrong.
1- Something got under the key pad and it will need to be taken apart and cleaned.
2- The boot-loader is corrupt and needs to be re-flashed.
3- the ribbon cable is broken and needs to be replaced.
either way you will need to send it to somebody unless you want to try it yourself if you spilled something on it and want to clean it.
Aug 06, 2009 | Motorola Cell Phones
Keyboard, #2, appears to stick.
The button seems to get stuck easyly, you have to take the keypad apart and see whats wrong with the button.
You will have to clean the button if something has gotten inside which makes it stick.
Jan 14, 2009 | Motorola Mobility RAZR V3
Certain keys not working
replace key board old one going bad mabey needs cleaning with dust out can
Jan 02, 2009 | Dell Computers & Internet
Key pad not operating well.
Something such as coffee or soda may have been spilled in the phone causing a loss of connectivity between the keypad and the contacts. The keypad is a rubber membrane with soft round nubs on the bottom that press against gold circuit board contacts when depressed. It would have to be disassembled and clean with q-tips and rubbing alcohol or similar solution. This is for a professional or handy person to perform only
Aug 10, 2008 | AT&T 2256 Cordless Phone
6233 keypad not working
plz open the phone case and clean your keypad
if it does not work then show in nokia gallery it will be done free of cost.
Mar 17, 2008 | Nokia 6233 Cellular Phone
Broken handset
The weakness with the handsets was that women using hand lotion or hair gel can get it on the front of the keypad. It then works it's way to the back side of the rubber keypad. The oil gets on the powder carbon on the keypad. The Carbon shorts the copper on the phone to activate the #1 or #2, etc. When the oil mixes with the carbon the key no longer works. I replaced many keypads until Sony Supplies ran out.... A cheap home fix would be to open the handset and clean the #1 key and the circuit board. You can try the keys but if they don't have any carbon on them you can buy liquid carbon at Electronic Stores OR just paper punch a circle of alumimum foil. Glue the foil on the key with thin glue. Works....
AL
Jan 03, 2008 | Sony SPP-A2780 Cordless Phone System
3 buttons on Keypad don't work
If You haven't already, open the phone remove the battery and SIM. I believe you can also remove the front face plate and key pad. Make sure the contacts behind the key pad are dry as well as the underside of the pad itself. Leave the cover and face plate off to allow to dry for as long as possible. If the phone was too wet it may not recover. If it does not you will have to replace it. The cheapest option is a go phone. You can get the Nokia 6010 refurbished online at Cingular for $29.95 and use your current SIM and will be good to go. When you order You will need to select a go phone plan but you do not need to activate it. Good Luck
Mar 19, 2006 | Nokia 3595
Panasonic KX-TGA650B Headset Phone Logo
132 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
