I connot delete a programe as the hard drive freezes
Dont ask me allright
Posted on Apr 01, 2008
My Acer Aspire One D257-1679 Laptop Constantly Freezes. Maybe Windows 7 Drivers out of Date and is not compatable.Should I do factory Reset?. Thank you
I just fixed a laptop with windows 7 freezes
windows 7 support has ended
all you need ot do is reduce the number of programs the computer is running
C drive needs lots of free space
if you want to keep the computer ..these things help
first store what you want to keep on to usb sticks
documents ,pictures ,files ,
not on the hard drive
delete all the unwanted items off the c drive
look into the users ..remove "Temp "
go through all the programs on c drive and uninstall
as many non windows 7 and unused microsoft programs and also unwanted computer games and printer drivers
clear all the downloads
clear the memory cache
defrag the c drive
scan for virus and troguns
if using versions of office above 2000 will slow /freeze the pc
windows 7 when released was based as a 32 bit and some x64
window 10 can be uploaded only if window 7 has upgraded to stage 3 but it will be slow
stuff that is X 86 will slow windows 7
Jun 29, 2016 | Acer Aspire Computers & Internet
Connot select, create, or delete partitions through diskpart.
If you want to create a new partition, there must be enough free space to put it. If the whole of the flash drive has been formatted, you cannot add a partition to no free space. Most flash drives will not accept more than one partition.
Mar 07, 2014 | Fujifilm 32 GB USB 2.0 Flash Drive
Computer slow and freezing
your System may be slow due to following reason
- Too many programs running at startup or in the background
- Data Corruption, hard disk fragmentation
- Missing Windows updates or outdated drivers
- Not enough hard drive space, too many unused programs
- Left over programs, old cached and temporary files
So Follow these steps to fix computer freezes problem::
- Delete all the temp files
- Remove unused programs
- install latest drivers from the manufacturer site
- Install and run antispyware software
- Free up wasted space with Disk Cleanup tool
- Defragment your hard disk drive
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
Sep 02, 2013 | Acer Aspire 5500 5570-2609 Laptop
Freeze of asha200 what componet ost that promblem in the borld
Fix Computer Freezes
A computer freeze, where the mouse and keyboard become unresponsive and applications hang, can have many different possible causes.
To fix a computer which freezes on a regular basis you must first attempt to identify the source of the problem, and target your troubleshooting efforts accordingly.
An issue with a specific hardware device, a particular software application, a lack of system resources, or a problem with the Windows registry settings file can all potentially cause computer freezes.
Fixing Hardware or Software Issues
If the freeze happens every time a certain hardware device is plugged in or switched on, the device itself might be to blame.
Check the manufacturer's website for updated drivers for the device, and download and install them to erase any bugs that might exist in your version.
Similarly, if the freeze only happens when using one particular application, that program might also be the root cause.
Check the developer's website for updates. If the problem persists, uninstall and reinstall the program.
This process replaces any software files or settings that may have been damaged or deleted.
Fixing Issues with System Resources
Overwhelming a PC's processor or memory by requests can also lead to the computer freezing up.
If the issue occurs when large files or complex applications are being handled, shut down any running application or background utilities you don't need for the project you're working on.
This frees up CPU time and RAM space.
Within individual programs, avoid opening up multiple files or websites at the same time.
If the problem persists and if opening multiple large files simultaneously can't be avoided, consider a hardware upgrade
Fixing General Windows Issues
General Windows issues are more likely to be to blame if the computer freezes at seemingly random times in a variety of applications.
A key Windows file may have been erased or corrupted, or there may be a problem with the Windows registry settings file.
Run the System Restore utility from the System Tools section of the Accessories folder on the Start menu to roll back WIndows to a previous version of the registry.
This will fix prior registry issues without affecting personal files and settings.
Fixing virus or spyware infections
A virus or spyware infection on your computer might also be the source of freeze issues.
If you don't have an antivirus or antispyware tools on your system, purchase and install one; otherwise, check the program's website to make sure that you're running the latest version.
Run a full system scan to check for problems and remove any potential threats, and be sure to repeat this process regularly to prevent future issues.
Fixing internal hardware issues
A damaged internal hardware component, such as the hard drive or memory modules, might also be causing freezing issues, in which case that component will need replacement.
A number of system diagnostics tools are available which can check for problems, including Hard Drive Inspector and PC Pitstop.
also
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
if you see something running that you does not need to be running select end now then you might you might uninstall that particular program
and some unnecessary programs
you should also check leads from motherboard to hard drive for secure dust free connections
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now
click start tick in both boxes this will schedule to on restart
do not have any input while chkdsk utility is in progress any might damage your computer
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
then defragment your hard drive
adding more ram is the best way of speeding up a computer
If youre not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible
you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs
This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have.
Delete the files using Disk Cleanup
If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup.
It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need.
Open Disk Cleanup by clicking startall programs accessories system tools and then clicking Disk Cleanup.
In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer.
If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK.
Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete.
When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation.
Disk Cleanup proceeds to remove all unnecessary files from your computer.
Watch the demo (1:00)
Jun 05, 2013 | Computers & Internet
Freezes on boot
INSTALL FRESH OPERATINGSYSTEM
Jan 14, 2013 | Dell Inspiron Computers & Internet
My computer is running so slow need help please
Registry Fragmentation Registry is accessed by almostall the installed programs and your operating system itself. Why is computerslow and freezing has to do with the fragmented registry data. You have todownload a PC Optimizer software that includes Registry Defragmenter tool suchas Reginout to perform system maintenance tasks. b> Too Many Programs areInstalled Installing too many programs makeyour computer slow and freezing. You have to uninstall the unwanted programs. 1. Click Start ' Control Panel.
2. Click Programs ' Uninstall a Program.
3. Select a program to remove.
4. Click Uninstall button.
5. Follow the wizard.
6. Reboot the computer after completion. b> Insufficient RAM Sometimes computer runs slow andstarts freezing due to an insufficient RAM. You have to install additional RAMsif required. b> Lack of Proper Configurations You will feel that your computeris slow and freezing if you haven't set Windows for best performance. 1. Right click My Computer.
2. Select Properties.
3. Click Advanced System Settings.
4. Click Advanced tab.
5. Click Settings button under Performance frame.
6. Select the option Adjust for best performance.
7. Click Apply ' OK ' OK. b> Junk Registry Keys Storing junk entries in theregistry makes your computer slow and freezing. You have to delete such junkentries using a Registry Cleaner and PC Optimizer software.
Feb 25, 2011 | Microsoft Windows XP Professional SP2
Seagate Barracuda 7200.7 ST380011A 80 GB stop working, it would not work properly, keeps freeze up
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Nov 28, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Emachine 250 does not have a disc drive. It will get to the blue screen where I click my use name and then it just freezes
press delete during boot up process enter BIOS then f1 for general help then run chkdsk/f which will automatically fix any corrupt files on your hard drive then
try uninstalling a few unnecessary programs type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
Sep 13, 2010 | E-Machines emachines (emachinees) CD-ROM...
Some help
you cant delete a folder you can delete all files in your folder in new mp4 in some mp4 you can delete a folder.if you need more information mail me on this id:ghulamxp@yahoo.com.thankyou
Dec 09, 2007 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
