Question about Kenmore 4.5 cu. ft. Oasis Canyon Top Load Washer
Kenmore oasis washer
Electronic board says the lis is open so the washer wont work.
  • kickstandm Feb 12, 2009
    i think the lid switch is not working
  • 41 Answers
Top loaders use the same motor for wash pump and spin to spin the clothes the motor direction is reversed and a solenoid releases the drum brake allowing the drum to rotate this is governed by a set of clutch shoes in the pulley if these are worn then the machine wont spin at full speed but ol on the display indicates overload so check the solenoid is releasing the drum usually heard as a loud clunk on spin start
Posted on Jul 13, 2008
SOURCE:
My Kenmore Elite Oasis HE model number: 110.27072603 washing machine shows LID error code. It wont work at all.... went half way through cycle... help.
Greetings,
this washer has a lid switch problem...or possible main board failure, but lid does concentrate on the lid safety switch. If you remember when you open the lid it stops..well, its a safety feature and prevents tub from spinning with lid open...this one is more difficult to service if your not use to working on washers...try unplugging machine and leaving off for awhile...does the door lock? check switch for lid fault
Nov 25, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Oasis HE 27082 Stainless Steel Top Load Washer: I have KENMORE ELITE Oasis He and it kept repeated...
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!
May 18, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Oasis HE 27082 Stainless Steel Top Load Washer: my kenmore oasis shows the f1 upon starting the ma...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!
Washer wont spin
Here is a tip that will help you with the not spinning or agitating problems....
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
May 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore oasis washer F1 code
Jun 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My kenmore top load oasis washer has an f50 code
Today (4/3/09) I got a letter from Sears. They will replace the electronic control board (you know, the F-51 business) for FREE, in warranty or not. Serial #s for the Bad Board begin: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083. The voices of all of us have finally been heard! There is a class action attorney firm in San Francisco looking into a legal remedy.
Mar 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis HE F1 Error
Im sorry to tell you but you have a bad control board. This was a faulty board from the factory. There is a class action lawsuit agianst whirlpool (whirlpool made the oasis). Try calling to get whirlpool to fix it. Maybe try joining the lawsuit. They have remanufactured the part so the new one wont do that again. Its a great machine when it works right.
Nov 18, 2008 | Kenmore Oasis HE 27087
Kenmore 4.5 cu. ft. Oasis Canyon Top Load Washer Logo
121 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
