Back to:
Tags:
Washing Machines
Generic problem for all Washing Machines
WATER IS NOT DRAINING (by 2 users)
posted by HeReigns777 on Apr 01, 2008
water isn't draining after wash cycle ends
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by wfelecia, posted on Jul 25, 2008
The water will not drain out of washer after wash cycle. All the water does is slosh around in the tub.
Solution #1
posted on Apr 01, 2008
Not Rated (0)
boff1
Rank:Guru Guru
Rating: 87%, 166 votes
Most likely the pump has failed or is blocked or jammed. Coins and buttons become trapped in the impeller. Suggest you check the pump drain inspection point - there is always one somewhere at the bottom of the machine. See if you can rotate the pump motor - ISOLATE THE POWER FIRST!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on WATER IS NOT DRAINING:
I don't want to Accept this solution
Can you Help with these Washing Machines problems?
Roper RAX4233PQ Top Load Washer
Roper RAX4233PQ Will start and fill with water but then...
Miele Touchtronic W1213 Front Load Washer
The main wash light was blinking. I called customer...
Frigidaire FWSB5700DS Top Load Washer
My washer won't spin any more.any help is appreciated. I...
Washing Machines
took rubber seal of beko washing machine cant get back on...
GE WBSR3140DW Top Load Washer
My GE top loading washer seems to have all the problems...
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
