Question about SanDisk Sansa e250 MP3 Player
Wizard can't find player to recharge - SanDisk Sansa e250 MP3 Player
  • Anonymous Oct 18, 2008
    need software to install on computer.
How can i get the software for my sansa
Posted on Apr 04, 2008
SOURCE:
How to recharge san disk mp3 player
try to find a different cord that has the same plug. i had the same problem with mine.
May 10, 2010 | SanDisk Sansa e200 MP3 Player
How do i recharge my slick 2gb mp3 music and video
Like most MP3 player with an inbuilt internal battery, your Slick 2gb mp3 music and video player will have an internal Li-Ion rechargeable battery that will be recharged via your USB Data cable while connected to an USB port on a PC/LAPTOP or USB charger.
Dec 19, 2009 | Audio Players & Recorders
Sandisk clip won't recharge
Make sure the lock switch is not engaged first.
Try another USB port on your computer.
If it still won't take, try this:
disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
-Tha Mp3 Doctor
Feb 28, 2009 | SanDisk Sansa Clip MP3 Player
Battery Low Message - Won't recharge
did u try connecting it to your computer like i do mine
Jan 24, 2009 | SanDisk Sansa e250 MP3 Player
Unable to recharge
Make sure the hold/lock is not engaged
Jan 06, 2009 | Philips GOGEAR SA6045 MP3 Player
After down loading music player went off won,t recharge
This player is effectively destroyed by using it on a computer that runs either Windows Media Player 11 or Vista. You can try doing a repair in Philips Device Manager, but this is very nearly an obsolete mp3 player.
Nov 27, 2008 | Philips GoGear HDD1830 MP3 Player
After a while of listening to songs my mp3 player freezes up.
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Nov 18, 2008 | Philips GoGear Flash MP3 Player
Difficulty charging my go gear
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Then recharge for 3-4 hours only - charging longer may lead to problems
Aug 23, 2008 | Philips GOGEAR SA6045 MP3 Player
RCA H125A
That could be a hardware failure - requiring replacement, but go to the RCA website and get the Recovery tool. I'm assuming that you already tried resetting the player. If RCA's methods fail, try this:
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard
Jul 06, 2008 | RCA Lyra RD2763 MP3 Player
Delstar DS 8013 MP3/MP4 Video Player recharging
Plug it in the wall and turn it on. Let it charged it that way
Jan 01, 2008 | Delstar DS 917 Digital Media Player
SanDisk Sansa e250 MP3 Player Logo
21 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
