Back to:
Tags:
Motherboards
Generic problem for all Motherboards
Laptop problems
posted by benno565 on Apr 01, 2008
only works with the adapter in but also keeps going of like it is shorting especially when i move the lead or laptop.
Comment by benno565, posted on Apr 01, 2008
laptop only works with adapter in battery says it isn`t present also goes off from time to time especally when i move it.thought it was the lead but tryed new one so it doesn`t appear to be that.
Comment by benno565, posted on Apr 05, 2008
tried ew adapter lead in my laptop ispiron 1300,not charging the battery but also switches of sometimes when i move it and it tends to get hot.this makes me think it is the connection inside how do i remedy this.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 02, 2008
Helpful (85)
map9966
Rank:Guru Guru
Rating: 89%, 1303 votes
Hi benno565, it's not shorting it's too loose from plugging & unplugging, hence your notebook is not getting a steady charge. You can bend the two prongs (every so slightly apart from each other), (carefully), this will give you a better connection or you can just replace the AC adapter. Your battery seems unable to hold a charge, that defenitly needs replaced.
Mike
Rating Locked! (?) benno565 has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on laptop problems:
I don't want to Accept this solution
Can you Help with these Motherboards problems?
EliteGroup P4M800-M7 Motherboard
Is P4M800-M7 mobo can support the pc333 sdram memory?...
AOpen AK77-600n Motherboard
Need to know which posts to hook the wires to , IE on/off...
Matsonic MS9158EP (DSMTSMS9158EP)...
Je n'ai pas de son apr?s avoir reinstall? mon systeme...
MSI Motherboard
ms-6570e(vi.x) atx mainboard fitted with amd athlon xp...
Intel Motherboard
hi guys n iwant to know that which motherboard should i...
Loading problems.
Repair Service
Find Motherboard Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
