Question about Whirlpool GH6177XP Microwave Oven
NO POWER, POPPED CIRCUIT
THE LAST TIME THE MICROWAVE WAS USED (EARLIER IN THE DAY), IT WORKED FINE. THEN I WENT TO USE IT AND NO POWER. I CHECKED THE BREAKER AND IT WAS POPPED, SO I RESET IT. STILL NO POWER AND THE CIRCUIT POPPED AGAIN. I UNPLUGGED IT AND RESET THE CIRCUIT AND PLUGGED SOMETHING ELSE IN TO VERIFY THE PLUG WORKED. WHIRLPOOL GH6177XPS-0 1800 WATTS, ABOUT A YEAR AND A HALF OLD.
I CALLED AND THEY WANT A $75 TRIP CHARGE WITH NO GUARANTEES TO COME LOOK. ANY IDEAS?
THANKS!
WILL
    Problem Solver:
  • 9 Answers
1. Try plugging the MW into a normal wall outlet, if it trips then carry it to the repair shop for free analysis & perhaps manufacturer covered repairs
2. Try plugging a table lamp into the MW circuit, then a hair dryer set to different speeds.
3. Try to plug in night lights/etc. into outlets nearby, even if on other side of wall, then trip breaker to see what goes off.
4. Try to remember what new items might be on this "dedicated" circuit and plug them in elsewhere.
The answers to all this will really save you money in diagnostics charged by either repair shop or electrician home call. New houses don't mean ideal electricians - some run GFI circuits all over the place!
Posted on Dec 17, 2008
  • 725 Answers
If it pop when you plug it in you have a short in the power cord or control. you can ohm out the cord to check it ..I can also help you with the control...
Posted on Aug 10, 2008
Thanks for the input, but it's a brand new house and it has it's own circuit. The microwave came with the house from the builder so i'm sure it's rated correctly. It pops the circuit when it's plugged in, i can't even get the chance to start the microwave. Do you think it's worth looking at and fixing or just buy a new one?
Will
Posted on Apr 04, 2008
    Novelist:
  • 189 Answers
Two possible causes.
First (and most likely) the circuit is being overloaded. This kitchen circuit may be shared with another appliance (like the refrigerator) which is drawing enough power when both are running to trip the breaker. A Typical kitchen circuit is 20 amp with #12 wiring. So an 1800 watt microwave might draw 13 or 14 amps while a fridge compressor kicking in can surpass 7 amps before it levels off. If this is an older home the kitchen may have a 15 amp circuit with #14 wiring. If the circuit is a 20 amp you will have to split the appliances onto separate circuits. (Under code a kitchen must have a minimum of 2 separate appliance circuits). If it is a 15 amp you might be able to split them as well or may be looking up upgrading the breaker and the wiring from 15amp #14 to 20 amp #12 (but you could still have the same problem).
The other possibility is a short or loose connection. If splitting appliances onto their own circuits doesn't fix this you would probably want an electrician to come in and check for other underlying causes which could represent a fire hazard.
Hope this helps.
Posted on Apr 01, 2008
  • Dave Hart Apr 04, 2008
    It would **** to buy another microwave and still have the same problem.
    You might first try running an extension and plug the microwave into another circuit. That will tell you if it's the microwave which is tripping the breaker, or something on the original circuit which is causing the problem. If it's the former repair or replace the microwave, in case of the latter you'll probably want a qualified electrician to look at the circuit in question.
    Best of luck.
    BD
Whirlpool GH5184XPS Microwave Oven F7 error, trips circuit breaker
Check the high voltage capacitor, it normally shorts, "discharge with screwdriver" unhook one side and set meter to ohms. Check high voltage diode tied into one side of the capacitor, "unhook from chassis ground" set meter to ohms and check for short, sometimes cracks, "must be replaced" If the diode is open meter does not have enough forward bias to check.
Apr 01, 2012 | Whirlpool Microwave Ovens
Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Feb 02, 2010 | Sharp R-1874 Convection/Microwave Oven
Lg micorwave, lam1180st refridgerator and microwave were plugged into the same outlet. i heard a loud pop. circuit breaker popped. i reset and the frige works fine. Microwave does not have power. the...
It is possible that the interconnection link(s) between the two sockets in the duplex outlet have blown apart. Turn off power at the electrical panel for this circuit, remove the outlet from it's box, and check the interlink on both sides. If obviously burned, replace the socket. A better option is to run another duplex cable from the breaker box to the outlet from a new breaker, cut the interconnections on the new socket, and wire the new cable to the isolated part of the socket. This supplies full power to each half and allows both units to run at the same time.
Oct 19, 2009 | LG 1.2 Cu. Ft. Mid-Size Microwave -...
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Replace OTR Microwave
Thanks for responding. It is a EWave KOT-152UW. I think EWave is part of Magic Chef. I think it is the door switch. When I opened the microwave, the circuit breaker tripped. I reset the circuit breaker, and it worked for several days, but the last time, the microwave went dead. The reason I want to use the same bracket is it has through the wall (horizontal) venting to the outside, and I am not keen on trying to cut more holes.
Nov 04, 2008 | Microwave Ovens
Microwave will not cook
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Oct 27, 2008 | GE JE2160 Microwave Oven
Whirlpool microwave combo - has not power - model RM286PXV2
check the control unit and highvoltagae areaand megnetron , related circuit..
Sep 10, 2007 | GE XL1800 1100 Watts Microwave Oven
Shuts off, must reset clock
Sounds like you could have a fauly control circuit. Something like when you press the pad the processor does not interpret the information correctly and resets itself. Or the power going to this circuit is being interupted. It is VERY dangerous to work inside of a microwave. So you could get an estimate from a repair shop. But those control boards are expensive. Do not attempt to repair this yourself. For your own safety.
Aug 06, 2006 | Frigidaire PLMV168 Microwave Oven
Whirlpool GH6177XP Microwave Oven Logo
264 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
