Question about Nefertech Diamond MP3 Player
Diamond MP3 Player Model # DSM921SD-1G Manual needed
Lost manual. Cannot get the music section to open so I can choose one of the file folders to play. Am stuck with the one folder that it comes on with and it repeats.
5 Suggested Answers
  • 3 Answers
SOURCE: Diamond MP3 1G digital audio player
It is either toast or the music is not compatible with the mp3 player...
make sure your music file isn't broken and it is either a .mp3 or .wma file.
Posted on Oct 13, 2007
  • 3 Answers
SOURCE: can't find files in music folder
First, try this. Delete all the music that you have in your Sansa while it is connected to your computer (BESIDES Angel, Return of the Champion, Cobblestoned Waltz, and Babylon of the Orientals). Then, put in your CD's again and copy them all into a folder on your computer, and save them. Hit My Computer, and go into the folder with the CD's imported songs in it. Next, open Windows Media Player. Highlight by Shift+Clicking and Ctrl+Clicking the songs you want in the folder and right click on them and hit "Add to Now Playing List" in the drop-down menu. Then, go to Windows Media Player and hit the Sync tab, go to "Views" menu, click on the "Now Playing List" option, and drag all the songs into the Sansa tab on the right.
THIS IS FOR VIIIISTTTAAA. If you do not have Vista, I am sorry but I cannot help with that. (Maybe get Vista :-))
Thanks,
Big Tony
Posted on Jan 25, 2008
HELP_ME_3
SOURCE: Diamond MP3 DSM956-1G
This is how first go to you control panel and click mouse then look if you locked your mouse to delete things if not use the right click of your mouse on the folder and delete it.
Posted on May 23, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: RCA Pearl TH1101A duplicate folder problem.
You have to use Audible audiobooks only
Posted on Jan 09, 2009
SOURCE: i deleted the music folder and nt able to play the songs in mp3
When I had the same accident this is what worked for me. I disconnected my sandisk player from my computer. After waiting until the sandisk software completed it's termination programming, I re-connected it to the computer.
Because I use Microsoft Windows XP, a window pops up asking if I want to open the device in Windows Explorer. Answering "yes" and then selecting the "Folders" from the tabs at the top of the window will display the sandisk along the left column as "Sansa e250". By double clicking on the folder labeled "PPI NAND" a drop down list of subdirectory folders should be displayed. If the folder "MUSIC" is not there, you will need to create a new folder and label it "MUSIC".
Here is how to create a new folder.
With the folder "PPI NAND" highlighted, move the cursor up to the upper right hand corner of the "Windows Explorer" window and select the tab "File". From the drop down menu select " New Folder ". This should cause a folder to appear in the window to the right of the "Sansa e250" window. The new folder should be highlighted and labeled "New Folder". Select the "New Folder" and rename it "MUSIC". When renamed, select the PPI NAND folder and the new folder "Music" should be listed as one of the folder in the subdirectory. If so, you can select it to see if the Music folder contains and music files. If not, you will need to copy or drag your files into the new "MUSIC' folder.
Once I did all of this and disconnected my sandisk player, the player and let the software complete the programming work before shutting it off, it worked fine. My original problem was caused by shutting my sandisk player off after disconnecting it from the computer before the sandisk software completed its work.
Hope this helps.
Posted on Mar 16, 2009
How to put music
To copy music files onto your device:
  1. Connect your MP3 player to your computer using your USB cable. Switch your MP3 player to the MTP mode by pressing the power button located on the top of your player. When the USB symbol disappears your MP3 player is in the MTP mode.
  2. Opening your GPX audio player folder by clicking 'Start' on your computer.
  3. Click on 'Start'.
  4. Double Click on the 'GPX MTP Device' icon.
  5. Double Click on 'Removable Storage'. Minimize your 'Removable Storage' window.
  6. Open your 'My Music' folder by again clicking on 'Start' and then click on your 'My Music' folder. Choose an album or individual songs from this folder. With both your 'My Music' and 'GPX MTP Device Removable Storage' folder open. Drag an album or individual song from your 'My Music' folder into your 'Removable Storage' folder.
Here is a link to the whole user's manual:
http://www.gpx.com/owners_manuals/ML648B-IB.pdf
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this answer. Happy holidays!
Dec 05, 2010 | GPX ML648B MP3 Player
I don't see list of music in windows media player Sansa mp3 240 1G - I want to delete some songs and add a few others - how do i delete some of the music
just go to my computer open up your device, it will probably be removable disk, then if the music files are not there look for a music folder, or do a search for music files and identify which folder the music goes in, if its not the root folder
thanks, dont forget to vote
Aug 03, 2009 | SanDisk Sansa m240 MP3 Player
Trying to down load music from CD to mp3 player
Make sure your MP3 player is connected to the computer, if for some reason it does not want to sync, go to My computer, open the dialog that shows your mp3 folders. If there is a Music file open it the go to the file on your computer that has the MP3 music files and open up the file until you see the individual music folders. Click in the screen (not on any folders though) then press ctrl a which selects everything, then ctrl c which copies everything then click in the MP3 folder and press ctrl v which pastes everything to it. If you only want a few of the items in from your computer music file then choose the folder you want, right click on the folder the choose copy then click in the MP3 window and right click then choose paste. I have had the same problem with a few MP3 players but this should work.
May 08, 2009 | SanDisk Sansa c240 MP3 Player
Have to individually play the songs
Rather than load to the folder, load to the device it self, outside of the folder.
Jan 19, 2009 | Nefertech Diamond MP3 Player
Mp3 player dsm961 1g
can you tell me how turn on the mp3
Jul 01, 2008 | Nefertech Diamond MP3 Player
I have Insignia 1g mp3 player lost derection on how to download music please help.
good u just shove the mp3 in your *** and it will automaticaly download music straight from your booty
Jun 03, 2008 | Insignia NS-DV2G MP3 Player
Feb 24, 2008 | Nefertech Diamond MP3 Player
Diamond MP3 player Model DSM921SD-1G LECTEUR MP3/WMA PLAYER manufactured March 2006
there should be a hold button on top of the mp3 player...
turn that to OFF, that should solve your problem...
To turn the mp3 on press the play button and wait a couple seconds...
Sep 21, 2007 | Nefertech Diamond MP3 Player
Erase Memory
same thing happened to me
Sep 02, 2007 | Nefertech Diamond MP3 Player
Aug 31, 2007 | Nefertech Diamond MP3 Player
Nefertech Diamond MP3 Player Logo
48 people viewed this question
Top Nefertech Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Nefertech Audio Player and Recorder Expert? Answer questions, earn points and help others
