Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
A question about the IC chips
I recent bought a PT-53WX53G with hopes of fixing it myself, could you recommend a site to order the IC chips from, P.S. I'll probably be having more questions. Thanks
  • 58 Answers
Try vance baldwin, they have good prices and will sell to non service shops. Hope this helps
Posted on Apr 03, 2008
SOURCE:
I have a Panasonic HDTV Model PT-53WX53G. I am getting a 3D / Double screen effect.
This is the convergence chips. They are 18 pin Amplifier IC Chips that control your three tubes to line the colors up. They are only about $20 each (there is two of them). They are difficult to replace if you dont know how to solder/unsolder. There is usually at least one resistor or fuse that will blow when the chips go out, you must replace this also. If you have no experience in electronics then i'd suggest you take the set to a pro.
Aug 27, 2010 | Panasonic PT-53WX53 53" Rear Projection...
PT-53WX53G still shutting off-3 blinks
have you checked the 2.2 ohm 2watt resistors? If the led blinks three times the resistors will almost always have at least one that will be blown and need replacement.
Jul 27, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Tv still turning off blinking three times after hori ic replaced
Three blinks is short protection.
97% of the time it means one or more of the 2.2 ohm blue resistors around the two convergence IC's is OPEN.
There should be 8 or 10 of them: light blue in color and will have 2.2 printed on them ------look for any that are slightly discolored or white in the middle.
What happens here is if one opens====one of the two convergence chips got it----they can be tested in place like testing a fuse===no reading across any of them and it is gone-----set detects no voltage reaching the chips(Usually STK-392-110---black in color and on metal heat sinks with fins side by side.)
DO NOT JUST REPLACE THE RESISTOR IF YOU FIND ONE BAD=ONE OF THE CHIPS GOT IT.
I have start to finish, step by step instructions showing what is needed and the best way to replace the chips etc.
FIRST: LOOK TO SEE IF any OF THE RESISTORS ARE GONE. (BAD)
If you want the instructions let me know and I will post them here for you.
Regards, SD TECH
FYI= Whoever told you to replace the output transistor does clearly not know these sets very well as it will produce a 5 blink error code.
Jul 26, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Location of convergence chips in Toshiba 57H81.
hello if you can use a soldering iron you shouldn't have any problems but you will need to test the resistor in front of the ic and the capacitors at either end of the ic ! the ic usually located to the right hand side of the tv behind the tuner board connected to metal frame called a heatsink 2 big black chip good luck
regards
shaun
Mar 27, 2010 | Toshiba 57H81 57" Rear Projection...
Panasonic pt-53wx53g vertical output ic
IC451 (Vertical Output) LA78045 part number is C1AA00000521
Available in Part Store.
Above info are taken from related service manual and an image of s.manual is given below...
Jun 19, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Can I Fix a Color Seperation Problem Myself On My Television?
The convergence Ic's need to be replaced. This is not easily done unless you have a good soldering station and some technical experience.
Mar 30, 2009 | Televison & Video
Panasonic PT-53WX53G power problems
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
The 3 blinks symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-150ICs and it's associated resistor,this resistor automatically chagne value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Hope this may help you;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic pt-53wx53g tries to turn on but goes right off
That is indicating that the convergence circuits have shutdown the set. You will need new Convergence ICs. They should be STK392-110 or STK392-120 either number works the 120 being the better chip. I will post a link where you can get the new ICs and they provide step by step instructions with pics so you can do the repair yourself. You will find your IC numbers under the section titled Convergence ICs just click on that and you will find your STK numbers.
Mar 30, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Converange chip-Where can I order one
This is very strange coincedence it seems the more I search this problem the more people I am finding with the same issue. This morning Aug 3 2007 I turned on our Panasonic PT-47WX42C to find this convergence problem! (distorted colours-off alignments) I, like yourself Hultsie would love to get the schematic diagram for our unit and change out the IC(s) myself. If we work together I believe we can accomplish this task! Please contact me at [email protected] if you would like to give this a go! I certainly will try to exhaust all avenues before I part with hundreds of dollars for something I know I can service myself. Oh, the defective IC(s) will more than likely have the values you need written on top of the chip...once you know the ones that need changing your local tv repair or even panasonic (if there close by) will sell them to you.
Jul 28, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
64 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
